Question about Lexmark X5470 All-In-One InkJet Printer
Printing promlem I have just put two new ink cartridges in my printer and the red light to the right hand side is still flashing to say they are empty???? And will not alow me to print???? What can I do????
  • 2 more comments
  • fultime Jan 04, 2008
    I have the same problem but not flashing light a message on the lcd panel tells me to check black and colour ink and UO51 code. I am using compatible cartridges which I have used before with no problem. I removed them and put back the original cartridges but I am still getting the same problem. I have tried cleaning etc, re installing printer, turning off then on again but the message is permanently there and I can't do anything at all with the printer while this message is there. Help!
    I am not getting a flashing light but a message on the lcd that I should check ink also UO51. I am using compatible cartridges which I have used before with no problem. I have tried replacing the original cartridges but get the same message. Have tried re installing printer, cleaning, etc etc but the same message is there and I can't use the printer at all for anything while this message is there! Help!
  • NotSavvy Feb 20, 2008
    Put in new cartridge and system says it is empty
  • geovany Feb 20, 2008
    i have put new ink and the red light is flashing??????????Wat can i do?
    Problem Solver:
  • 24 Answers
Fiend your solution direct from Lexmark. Here is your solution
http://www.lexmark.com/printer/prob676ijt65/solution
891
Posted on Mar 02, 2009
  • 82 Answers
Clean the electrical contact of the cartridge AND the cartridge holder with a lightly moisten lint-free cloth. Use only water, not alcohol or solvents, dry up with a new cloth.
If contacts seems oxidized, use moderately a pencil rubber.
Do not rub nozzle plate ! You only can touch it with a heavy-moisten cloth in case of bad printing.
Generally the cartridge is refused by the printer because bad contacts OR bad cartridge chip, more rarely because bad carriage...
Posted on Dec 03, 2007
Hi I have just put in ink cartridges and the reg light check print cartridges keeps flashing is there anyone there to help me
Hello and Welcome to FixYa!
Sir/Ma'am If the Check Print Cartridge message is shown and Red Light Flashing then it means that Either ink Cartridge is not installed properly or the function for detecting the ink level is disabled. For it Make sure that you install ink cartridges at correct position as indicated by the label on the print head holder. Press push mark until ink cartridge click into the place.
If you are sure then you have installed ink cartridge properly then try following to stop the flashing of red Light.
  1. Lift the lid to the printer (cartridges are on the right side.)
  2. Turn the printer off, then power it on again.
  3. Unplug the power cable from the back of the printer when the grinding noise starts.
  4. Move the carriage towards the middle of the printer (this procedure may take a couple of tries to get the timing correct.)
  5. Take out the cartridges and close the top cover.
  6. Reconnect the power cord. The power and the resume lights (green and red) should be on.
  7. Open the top cover, reinstall the cartridges, and close the top cover.
Now Turn On the printer, Mostly this issue is resolved by this,
But if still you get the message and red light still flash then surely its an issue of Ink Cartridge, your ink Cartridge is defective, You need to change the ink cartridge, Your problem will be solved.
I hope this solution helps you.Don't hesitate to let me know if you still have some confusion in your mind.
Please Rate my solution as "Maximum Stars" and then give your Words of Appreciation as a Feedback.
Thank you Sir/Ma'am for taking my service and fir using FixYa
Concerned: Muhammad Uzair Team : FixYa
Nov 05, 2011 | HP DeskJet 920c InkJet Printer
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
Please tell me how do I change the ink cartridge in my Epson TX650?
1) Looking at the front of the printer/scanner there is an indent on the left hand.
2) Lifting up on this portion should reveal the inside of the printer.
DO NOT touch the flat cable inside the printer, DO NOT force the lid, it should open easily.
3) The ink cartridge is underneath the plastic cover in the back right-hand side of the printer. Gently pull up on the cover until it swings open.
4) pinch the clips holding the ink cartridge in the printer and pull up.
5) Unpack the new ink cartridge.
6) Remove the tape that is on the ink cartridge.
(If you forget this step the printer won't print. If that happens, remove the new cartridge, remove the tape and then reinsert the cartridge)
7) Insert the ink cartridge and push gently until it clicks into place.
8) Close the cover over the ink cartridges, and then close the printer cover.
9) Follow any direction on the front display (hit OK)
May 07, 2011 | Computers & Internet
Red light stays on and printer won't print
My C60 Epson Stylus printer is not printing. First of all the paper jammed, I pull the paper from the front and since then the catridge holder is not going to the middle to print. also the green light keepon flashing and the red light stays on. I need your help.
Jan 16, 2010 | Epson Stylus C60 InkJet Printer
Changing color cartridge on my epson stylus color 980 printer.
If you need to replace an ink cartridge in your printer, please follow the instructions below:
To confirm which ink cartridge requires replacement, please use the printer's control panel (there is a black ink out indicator, as well as a color ink out indicator ), or the Status Monitor in your computer.
Red light flashing - Low ink
Red light solid - Out of ink
1. Open the printer cover and press the INK (Cleaning) button for 3 seconds. The print head moves to the center and the lights flash.
2. Lift up the ink cartridge clamp. The cartridge rises up from its holder.
3. Remove the cartridge and dispose of it carefully. If ink gets on your hands, wash them with soap and water. If ink gets in your eyes, flush them immediately with water.
4. Unpack the new ink cartridge and remove the yellow tape. You must remove the yellow tape from the top of the cartridge. Do not remove the clear seal underneath the cartridge. Do not touch the green circuit board on the back of the cartridge, or you may inhibit normal operation and printing.
5. Tilt the new cartridge toward you slightly as you insert it. Lower the cartridge so that the tabs rest on the hooks. Do not place the cartridge tabs under the hooks.
6. Press down firmly on the ink cartridge clamp until it snaps in place.
7. If you need to replace the other ink cartridge, repeat steps 2 through 6 before continuing with step 8 (to move printhead over to color (if black was replaced first) press the cleaning button once).
8. Press the INK (Cleaning) button once, and close the printer cover. The printer begins charging the ink delivery system.
9. Wait until ink charging is finished (the power light stops flashing and the red error light goes out).
May 11, 2009 | Office Equipment & Supplies
Epson C46, changed coloured ink, won't print flashing red light
If the red light is flashing by itself, it means the printer thinks a cartridge is low on ink. Have a look at what the Status Monitor thinks (right click the printer Icon in the bottom Right-Hand corner and select Ink Monitor). This will show which cartridge it is. If it's the new colour cartridge, it means the cartridge is faulty (then replace it), or it is a refilled cartridge that hasn't had it's chip reset to "full". For this you will need a chip resetter, available on E-Bay very cheaply. If it's the black cartridge then replace it.
If both green and red lights are flashing, it usually means the Waste Ink Pads in your printer are saturated with ink and the waste ink "protection" counter has exceeded its limit. You can restore your printer to a working condition immediately by using the SSC utility - download from:
http://www.ssclg.com/epsone.shtml
Install it, and double click the ssc printer icon in the bottom right corner (System Tray). Choose Configuration and set your printer type (C4x), then close the ssc window. Now right click the ssc icon in the sytem tray and choose Protection Counter. You should see that the current count is above the limit; then choose reset to set it to zero. You will need to fib about having changed the waste ink pads! Turn the printer off then back on again. This will stop the lights flashing and restore normal operation.
However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer.
If you decide to have a go at replacing the ink pads yourself, report back and I will provide further help. It is a pretty simple job once someone explains how to get the case apart!
Mar 11, 2009 | Epson Stylus C46 InkJet Printer
Put in new ink cartridge -- won't print
Try lifting up the cover. If the ink level is low in a print cartridge, the Print Cartridge Status light stops flashing. If the problem is not related
to low ink, the light continues to flash after the cover is opened. It might be that the new cartridge is defective. Check the connections and see if there isn't anything keeping it from making contact.
Jan 26, 2009 | HP DeskJet 920c InkJet Printer
Ink issue
Normally if it's an ink cartridge problem, you will see there is a small cartridge symbol being shown in the right hand side window. If there isn't a cartidge symbol then it doesn't need a new cartridge. Normally when the red light flashes, it means there is some other problem such as paper jam or no paper! To change the cartridge, open the top of the printer, you'll see the cartridges on the right hand side, they should hopefully just pop out when you pull them GENTLY. To insert a new cartidge, follow the pictures shown and make sure you hear a 'click'.
I am not a techie at all so I hope this helps
Oct 06, 2008 | HP Photosmart 7850 InkJet Printer
Carriage hits the right inside of printer - will not print
if the lights are flashing along together there is a cariage stall. The ink cartridge craddle is hitting something. Find out what and remove it if doesn't belong there. First of all remove and reinsert both cartridges. One of them may be inserted wrong.
Mar 19, 2008 | Office Equipment & Supplies
Overiding Empty Cartridge error for Dell A10 962
Red flashing light on '8BK' small black cartridge on left hand side.
If this indicates 'low ink' then it is not alerting me on the monitor. I think this is something different because my printing has been interrupted. Aileen
Dec 13, 2007 | Office Equipment & Supplies
Lexmark X5470 All-In-One InkJet Printer Logo
121 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
