Question about Jet 354166 Jdp 15MF 15" Floor Mount Drill Press
Same problem - broken return spring
Where do you find a replacement?
    Sergeant:
  • 384 Answers
Hareware store in the spring department
Posted on Jul 29, 2009
Z71. shift lever return spring broken
Sounds like it needs to be replaced.
May 13, 2016 | 2002 Chevrolet Avalanche
I have a 2002 Honda Shadow VT750c won't shift
Hi, Anonymous and the usual suspects are:
1. Clutch not disengaging.
2. Bent shift shaft.
3. Shift fork bent or seized.
4. Gear seized on the shaft.
5. Gear positioning lever binding.
6. Shift return springs weak or broken.
7. Shift return spring pin loose
8. Shift mechanism arm spring is broken.
9. Shift mechanism arm is broken.
10. Shift drum is broken.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
83 Shadow VT750C Shifting Issues
Help 1983 honda shadow replaced startor wont shift Motorcycle Forum
Honda 1998 VT750C Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda VT750C Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Sep 27, 2013 | 2002 Honda VT 750 DC Shadow Spirit
2007 Honda VTX 1800 C shift pedal does not come back up
Gear Shift Return
http://www.allworldauto.com/comments/2002_HONDA_VTX1800_comments_and_complaints_21-9566-2002-1.html
Honda VTX1800R Owner Manual service manual, not owners.
https://www.partsfish.com/page/oem-parts-for-honda
Jul 11, 2012 | 2007 Honda VTX 1800 C
Hydrolic clutch pedal sticking
Hi, Look in the foot well (where you normally have you feet) you should see a return spring attached to the clutch pedal, if missing or you can see broken spring you need to buy another spring, you will see parts of broken spring where they fit not a very hard job to replace. Please leave me feedback thanks, Malcolm Campbell.
Feb 16, 2012 | 1983 Nissan 280ZX
Rg 150 kickstart not returning
The spring must be "wound" to be tight and make the kickstart lever return..
Jul 07, 2017 | 1998 Suzuki RG 150 Gamma
Shifter Not returning to start postion after shifting gears.
If the shifter is not returning to it's "center" position, the shifter pawl spring is probably broken in the transmission. With the engine off and the bike on the kickstand with the transmission in neutral, gently depress the shifter lever down until just before it shifts. Then, let go of the shifter and see if it springs back up. Do the same thing lifting the shifter towards second gear. Make sure there is no binding in the linkage. If you don't feel the spring pressure on the shifter, this is an indication that the return spring is broken. Harley had a problem with this on their 5-speed transmissions. Fixing the problem is a major job. You have to disassemble the entire primary drive and pull the trapdoor with both transmission shafts out of the transmission to get the shifter pawl shaft out. I strongly recommend the purchase of a service manual if you plan on doing this job yourself.
Good Luck
Steve
May 20, 2011 | Harley Davidson XL 1200 C Sportster Custom...
Bostitch N60 finish nailer. The driver will not return. into gun and blows air out by trigger. How to fix?
You will need to replace the trigger valve, the one you need is a P/N- TVA6. As far as the driver not returning, it could be a broken head valve spring,(spring in the back cap under the head valve) or possibly a broken driver blade.
Feb 03, 2010 | Air Tools & Compressors
Return spring keeps on letting loose and doesn't work
Spring is broken. Sometimes hard to see. Hopefully is is at the end or close where the spring hooks to the housing. All you will have to do in that case is bend the spring and place back in slot. If broken in the middle, you will have to replace spring. Spring may be hard to find but you may find one on ebay or one of the saw forum sites. Just type McCulloch + the model no in google.
Apr 16, 2009 | McCulloch Garden
Poulan 3400 chainsaw throttle trigger
Its a missing or broken spring in the handle(trigger). If you look inside the handle you should see a circular spring around the post of the trigger. This spring returns trigger to idle position. If its missing or broken the trigger won't spring back.
Oct 12, 2008 | Poulan Garden
Jet 354166 Jdp 15MF 15" Floor Mount Drill Press Logo
97 people viewed this question
Top Jet Drills Experts
Tom Chichester
ray gallant
Are you a Jet Drill Expert? Answer questions, earn points and help others
