Question about Maytag Neptune MAH5500B Front Load Washer
My Maytag Neptune washer was 2 minutes into a normal cycle when it stopped. I tried unplugging it, waiting a few minutes and plugging it back in and starting it. The door immediately locks and unlocks and the cycle does not start again. The clothes are wet and there is water in the washer from the initial, abbreviated cycle. There are no codes displayed.
  • adshantz Jul 29, 2009
    Where is the drain?
  • adshantz Jul 31, 2009
    Vey helpful. Thank you. We are back up and running (or rather washing)!
    President:
  • 2,777 Answers
Well, since you have already tried unplugging and replugging power then inspect the drain hoses and remove any kinks. Take a look at the drain, too - if it's clogged, call your usual drain service person.
Then close the washer door and firmly press the START/STOP button. In a few moments, after the door locks, the washer should begin to spin. (For your safety, the washer will not tumble or spin unless the door is closed and locked.)
You should also try to verify that the power outlet is getting full power, you may want to try flipping the circuit breaker to reset it.
If this doesn't work, please contact Customer Service at 1-800-688-9900 for toll-free assistance and service scheduling if necessary.
Hope this helps! Sorry to hear about your problem, those are very good units so this is quite unusual.
Tim
Posted on Jul 29, 2009
  • Tim Grayson
    Tim Grayson Jul 29, 2009
    The drain is on the back of the unit, usually with a hose attached to it going into a physical drain in your wall / on the floor.
    Also I just checked and there is a possible recall on your unit. This issue could be related to the recall, check it out at:
    http://www.washerrecall.com/
    Let me know!
    Thanks
    Tim
Wash cycle are running to long
FIXED Maytag Neptune, Timer Problem - ApplianceBlog
www.applianceblog.com/.../23387-Maytag-Neptune-Timer-Problem
Mar 4, 2011 - 8 posts - ‎3 authors
My countdown timer is stuck at the 33-minute level in the "wash cycle", and repeatedlyruns for a 30-40 seconds, then stops, then runs, then ... Maytag Neptune TL Washing Machine stops in spin cycle ...
Jul 25, 2013
Maytag Neptune Washer Won't Spin/drain
Jul 4, 2013
Neptune TL Washer FAV6800AWW - DC and UC ...
Jul 3, 2007
MAYTAG NEPTUNE WASHER CONTROL PANEL ...
Jun 29, 2005
More results from www.applianceblog.com
Troubleshooting a Too-Long Wash Cycle - whirlpool washingmachine ...
ask.metafilter.com/233920/Troubleshooting-a-TooLong-Wash-Cycle
Jan 25, 2013 - We have a Whirlpool Duet washing machine (about 2 years old). Thecycle is taking WAY too long to complete. The load that's running now ...
Maytag Neptune washer repair: motor/motor control circuit ...
? 12:10
https://www.youtube.com/watch?v=ITTbDh8CFEU
Dec 11, 2013 - Uploaded by daytonaturbofreak
Maytag Neptune washer motor/motor control circuit board ... my board just fried - is your washer still working? wondering how longthe conversion fix will last. ... Other times it will run a completecycle without any malfunctions.
Jan 11, 2016 | Maytag Neptune MAH5500B Front Load Washer
Maytag centennial washer
Put some water in the washer tub, a few gallon should do it. Then turn machine back on, it will recognize when the water has drained out and stop that cycle.
Aug 05, 2017 | Washing Machines
May tag Neptune showing codes
Error codes appear when there are problems with the door, the inflow and drainage of water and the motor.
Do
Your Maytag Neptune washer displays the "do" help code when the washing machine is trying to start a cycle, but the door is open or not locked properly. If this message is displayed, close the door securely and restart the washing cycle.
FL
The "FL" code indicates that the washing machine was unable to lock the door after you closed it. Open and close the door tightly, then restart the washing cycle.
Sd
The "Sd" code indicates that you have added too much detergent to the washing machine and your laundry has too many suds. The machine will stop displaying this code if it has successfully run the suds recovery cycle, which removes the excess suds from the wash load. If the code remains, reduce the amount of detergent in the load. Use less detergent for similar loads of laundry in the future.
PF
The "PF" code indicates that a power failure has occurred. Restart the wash cycle. If the code still appears, check that the washing machine is still plugged in to the electrical outlet.
Nd
The "nd" code indicates that your Maytag Neptune is not draining as it should. Check that the drain hose isn't kinked and that the stand pipe isn't clogged. If you find either of these problems, fix them before restarting the washing cycle.
LO
The "LO" code appears when the washing machine has finished the selected wash cycle, but cannot unlock the door. Verify that the door is closed properly, push the "Off" button, and wait two minutes. The door should unlock and the error code will disappear. If the error code remains, unplug the washing machine, wait two minutes and plug it back into the electrical outlet.
Lr
The "Lr" code indicates that the washing machine's motor is not running as it should. Have your Maytag Neptune washing machine serviced by a certified Maytag repair professional. Maytag Neptune Priority One Service: (888) 462-9824
NF
The "nF" code appears when the washing machine has tried to fill with water and has failed. Verify that the inlet hoses aren't kinked and that the faucets are fully open.
Od
The "od" code appears when you must open the washer door. The Maytag Neptune washer requires that you open the door between cycles.
Other Codes
* If your Maytag Neptune washing machine displays any codes that are not listed above, contact Maytag Neptune Priority One Service for assistance. Maytag Neptune Priority One Service: (888) 462-9824
Hope this helps (remember to rate and comment this answer).
Apr 03, 2011 | Maytag Dryers
Machine wont restart after inadvertantly hitting the stop button instead of the pause button
I believe the final solution was to unplug the machine for several minutes. When it was plugged in again I hit one of the wash cycle buttons and after a minute or so the button indicating that the door was closed properly lit up and then the machine resumed it's cycle.
Aug 29, 2009 | Maytag Neptune MAH5500B Front Load Washer
Can't interrupt the washing cycle on coin operated Mah21pddww
Unplug the washer, wait three minutes for the door to unlock then do what you need and plug it back in. Should still have the time left on it that was there when you unplugged it.
Aug 17, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune front load washer says control lock and wont start and buttons wont work
unplug the washer for 15 minutes then:plug it back in and, restart a few times in a different cycle canceling each time until the door opens. Do this only if the tub is not full of water if it is let me know and, i'll show you how to drain the washer first before we try to open the door.
Jun 09, 2009 | Maytag Neptune MAH6700A Front Load Washer
Wont start
Try unplugging the unit for an hour allowing the microprocessor to reset. Plug it back in and use as normal. Let me know if this helps.
Waiting to hear from you,
Eric Campion
Feb 14, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Epic-Z F-28 error code
F28 is a misc error,
most of the time it is because the washer is NOT LEVEL.
1. Unplug waher,
2. Relevel washer. (make sure all legs are equally distributing weight, so as to ensure no shaking). See owner's manual.
3. Plug in, and use.
Hope this helps.
Jay
Aug 26, 2008 | Maytag MAH6500 Neptune Front Loading...
Maytag Neptune MAH5500B Front Load Washer Logo
42 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
