Write down the name and model number. Using your computer go to repair clinic.com they have a search engine where you can search for thousands of different parts. Type in you appliance name and model number and the part you are needing. I have used this site many times and have always found my parts. They are very reasonable price wise and usually have fast delivery. I have even searched hard to find parts. I have been well satisfied. I hope this helps with your problem.
SOURCE: Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
hope u find this useful. thank you.
SOURCE: Kenmore electric stove heating element how to replace
A replacement is usually around $40. There are usually 2 screws holding the element in the back of the stove. Turn off the power and remove the element. There are usually only 2 wires. It really doesn't matter which goes where. Install the new element and see if it will shut off when oven reachers temp. If it continues to heat, there is another piece that needs to be replaced. If there is a contactor or relay replace it, If not the thermostat needs to be replaced. Sometimes when the element burns out it shorts to the ground and fuses the contacts forcing the element to stay on. Sometimes you actually have to turn off the power to the stove.
SOURCE: replacing electrolux eob944 fan oven grill element
...If you can help me to remove the grill element from my EOB944, I will be able to tell you the wirings.
SOURCE: Top oven and grill of my Diplomat ADP4520 double
there is a problem in the wire connection that can cause a short circuit.
SOURCE: Dead oven despite element replacement?
If it has a timer, then make sure it is set to manual, and not auto, otherwise the oven will not come on.
What usually happens is, if you have a power cut, or switch the oven off, then the timer automatially goes to auto when the power is on again.
Please rate my solution.
Thankyou.
