Question about Brother HL-2040 Laser Printer
Brother 2070 - putting in second cartridge, can't get paper light to extinguish
  • jerbedn Jul 29, 2009
    Adding more info - first cartridge OK
  • jerbedn Aug 29, 2009
    My explanation of the problem was quite vague.
    I have two drums.
    Drum #1 works with both toner cartridges.
    Drum #2 has a blinking red light(paper) when I insert this drum in my printer. It starts up normal and then the red light starts to blink.
    Is there a senser or pickup on the drum? No paper in the drum. There was a paper jam once. I cleared it and printed afterwards.
  • 46 Answers
Do you mean a Drum Unit? If you put a drum cartrige called a DR-someting in the unit you must reset the counter. The step by step instructions comes with the drum unit. If you don't have it open the front door and push each button on top of the machine. one of them should reset it then close the door.
Posted on Aug 28, 2009
Tried 1) reducing amount of paper, 2) cleaning corona wire, 3) checked for jams in toner cartridge and back door, 4) blew dust out of tray with compressed air. Any suggestions?
Check the paper flag in the cavity where the tray goes. If you are getting a constant no paper message that flag might be broken. Here is the Brother explanation of errors What do the LED indications mean Brother
Sep 04, 2016 | Brother HL Office Equipment & Supplies
PAPER LIGHT FLASHING RED BUT MACHINE HAS PAPER IN IT
Paper light flashing could mean several things on this machine.
There could be a paper jam in the machine. Open the front cover remove the drum and toner and look in the machine. Open the back cover and look for a Jam as well.
Try putting a piece of paper in the manual feed tray which is right above the paper tray, sometimes on certain documents the margins are too big and asks to go into the manual feed slot.
Apr 07, 2010 | Brother HL-2040 Laser Printer
Brother HL-2070N Laser Printer Will Not Print
First of all, I checked the answers given here, but nothing worked; everytime I turned on the unit, the red light flashed that the printer was out of paper.
From the Brother's HL-2070 manual, in the troubleshooting section: take out the toner cartridge from the front of the machine (be careful, any black toner powder that come off may be very difficult to clean up). I took the toner cartridge to the sink.
There is a blue slide along the top of the unit that will clean the corona wire if you slide it back and forth, from one end to the other (toner/dust can become caked on the wire over time; sliding the slider back and forth simply knocks the caked off 'stuff' off of the wire).
Replace the toner cartridge; it worked fine for me. I was immediately able to print.
Mar 11, 2010 | Brother HL-2070N Laser Printer
2070 printer shows red, flashing 'paper' lcd when there is paper in the tray. I have done the usual, checking tray, removing and restoring toner cartridge etc etc. I have tried a manual feed as this...
  1. Remove left cover (where the USB connection is located);
  2. Remove big black gear with a spring on it (you may need to unscrew the PCB that partially covers it);
  3. There is a clutch that sticks to the rubber pad behind this gear. You may put a piece of scotch tape towards to a rubber pad, so the plastic from clutch mechanism would'n stick anymore. http://www.phillycopiers.com/fix/hl-2040-2070-fix.jpg
Oleg Andrukh IT Specialist
PhillyCopiers.com 215 364 3774
Dec 01, 2009 | Brother HL-2070N Laser Printer
Brother MFC 240C has error message ''NO BLACK CARTRIDGE'' even though new cartridge is installed.
I learned this one from a Brother tech, and it usually works:
  1. Put your machine where you can easily reach the power plug.
  2. Lay a few layers of paper on the desk beside it to protect the desk from ink.
  3. With the machine plugged in, remove all four inks. Stand them upright on those papers you laid down.
  4. Close the top.
  5. Unplug the machine and wait 15 seconds before plugging it back in.
  6. Of course, the machine will complain that there is no ink installed. It should tell you which color it want you to install first. Raise the top and install all inks, in the order it asks.
  7. Lower the top when all the inks are in, and the machine should return to normal.
These machines detect ink by shining a light through a clear rib in the cartridge. What you've done resets the machine's threshold between light and dark, so it recognizes full cartridges again.
If it doesn't work, try it once more, and you might still get lucky. otherwise, you may have a defective cartridge, or you may need a new main board$$$.
Nov 08, 2009 | Brother MFC 240C All-In-One InkJet Printer
Repeated paper jams from the brother hl2070n after remove toner
Apr 26, 2009 | Brother HL-2070N Laser Printer
Brother HL2070N printed 1 page fine,then nothing but light streak
turn off printer, remove cartridge and drum and clean internally.
reinstall drum and cartridge and do a test print, hopefully all will be better.
Jan 18, 2009 | Brother HL-2070N Laser Printer
Not recognizing cartridge
myprinter tells me"noblack ink," they are both b it is brand new cartridge why?this is the second black ink cartridge i have bought it says the same thing.i always buy "BROTHER"
Oct 27, 2008 | Brother MFC 420CN All-In-One InkJet...
I have a brother HL-2070 laser printer and have just inserted a new toner cartridge. When I turn on the lase printer it is coming up orange light toner & will not print. Its as if its not recognising...
Have you tried shutting down and restarting after the cartridge was in?
Also at Brother there is a new driver download for your model, and other info.
http://www.brother-usa.com/SiteSearch.aspx?sk=hl-2070%20manual
May 01, 2008 | Brother HL-2040 Laser Printer
Brother HL-2040 Laser Printer Logo
85 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
