I have fussion led tv 32 inch tv i pressed reset it turned picture upside down how can i fix it
SOURCE: picture is upside down Samsung HLR 4667W 46 inch
Enter service.....go to engine and change engine type. This work
SOURCE: Magnavox Color TV Model #27MT3305/17
The problem I was having was that the vertical deflection was
collapsing on itself from the top. I'm a tech and I am visiting web
sites who experience similar problems with the Magnavox 20 MT4405 in
hopes of saving them time and money."Starsong" has the right answer.
Replace electrolytic capacitor #2465. It is a
10 microfarad electrolytic capacitor rated at 160 volts. Although the
existing capacitor appeared good,in circuit and out, the
charge-discharge time was flat as compared with a new capacitor. Plus,
when the capacitor is in circuit with full voltage applied, the
capacitor leaks too much. The cost of the capacitor should be under $2.
It should take under a half an hour to replace. Be certain to let your
set rest, unplugged, for at least a half hour before attempting to
replace this capacitor. There are high voltage present around the crt
even after the set is turned off. The high voltages can cause serious
bodily harm. I would suggest a tech discharge the anode on the crt with
a high voltage probe passing through a volt meter and running to
ground. You will need a soldering iron, solder ******, solder, and I
like to use a little flux for good adhesion of component to board.
SOURCE: PUSH THE RESET SWITCH PROBLEM
hmm...maybe:
You need to know in which position was camera turned of.
So try turning it on in RECORD OR PLAY position.
It will work then...
SOURCE: Samsung 32 inch LCD delay in start up
I had a technician fix this exact problem today it is the POWER SUPPLY the TV is not getting enough power to the main board, i have been searching for weeks and no one ever post a solution here it is guys get them fixed $200 only
SOURCE: 32" Samsung TV, No Power or Sound, power LED on, flashes 3 times
Most likely the set has lost vertical sweep or the feedback from that circuit. This will shut the set down to prevent a horizontal line from burning the face of the CRT. This will have to be looked at by a technician.
