Question about Mitsubishi WD-52725 52". Rear Projection HDTV
Can't get 1080
I have a comcast cable signal running through their DVR .. best picture I receive is 720p .. What do i need to do to get 1080 ?? thanks
  • 39 Answers
Re: Can't get 1080
Posted on Nov 30, 2007
0 characters
3 Points
How do I get my tv to scan the digital channels? I have used the channel scan and it will not let me scrowl over to scan them . I do not have a digital box but was told that this tv has one bilt in.
Although your TV is hd ready, it does not come with a digital tuner built into it.
You will have to add an external tuner box to receive digital broadcast stations.
I don't suggest getting one of the cheap ones, as the only provide an SD signal at 480p, clear compared to old analog tv, which was usually 320, but still a far cry from 1080p.
A good tuner box should only run around 60-70 dollars or so, and the picture quality will amaze you on your 51F510.
The tv has a 1080p engine built into it, so if it receives an input with a 1080 signal, it can display it properly.
Cheaper boxes may only offer 720p as it's highest definition output, so get the better box.
You can find them at all major electronics stores, like Fry's and Best Buy.
Hopefully, you do get a digital box for your set, it would be a shame to not get the most out of what is arguably the best quality rear projection tv that was ever made.
I hope this helps you out.
Feel free to give me a top rating if I helped you out, it helps to keep my status up on Fixya.
Thanks, and have a good day !
Apr 07, 2011 | Hitachi 51F510 51" Rear Projection...
2004 hlp4663w component and hdmi signal error message
Chances are the analog board ( One with the Inputs) need replacement. You can get one at the following link.
Jan 02, 2010 | Samsung DLP HL-P4663W 46" Rear Projection...
Will my Mitsubishi Projection TV process HD signals?
the TV doesn't need to process the signal...the receiver will and send analog to the TV
Apr 11, 2009 | Projection Televisions
COMP 1 and 2 are for 480i/p sources. Hook it to the 1080i capable on the back. Also make sure the HD DVR is outputting 1080i not 720p. The Mits can not disply 720p and will show a scrambled screen if you try to.
Jan 31, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Picture not to edge of screen
That is because you are watching the picture in the 4:3 aspect ratio. This is normal when you are watching a channel that is being broadcast in 480 or digital. But once you tune to a station that has 1080 or at least 720p which is true high def then the picture should expand to 16:9 aspect ratio. It will switch between the two automatically as it determines what type of signal it sees. You can force the resolution to change by pushing the format or aspect ratio button on the remote but you will lose picture quality.
Jan 11, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Just set up a samsung 67in hdtv--all is fine except the image is cropped at top and bottom regardless of the picture setting at 16:9 or 4:3 or wide or just scan which should adjust the signal sent from...
We have the 61" Samsung. WE LOVE IT!!! We have a DirecTV DVR box. On the DirecTV remote there is a "format" button. It cycles through all the different options. (Pillar Box, Stretch, 720p,1080p, etc.) Adjusting the picture setting with the Samsung remote is not the same thing. Try using the cable remote......see if it works the same as mine.
Sep 04, 2008 | Projection Televisions
I have the NS-PDP42 42" PLASMA 720-P and I would like to know how to change the screen resolution for hdmi devices. In the user guide it says to change it to 1280 x 720p but it does not tell how to...
There's no way to tell the HDMI input whether it should take 720p or 1080i input on this set. The best thing to do is experiment. Set your Comcast box to 720p and watch it that way for a while, then set it to 1080i and watch it for a while. The PDP42 has to do a little picture manipulation in either mode, but I think you'll find that the 720p mode will work best for you. I have this set with Verizon FiOS and I have the FiOS output set to 720p. Looks great, no complaints.
Jul 23, 2008 | Projection Televisions
  • HDTV capable: Yes (up to EDTV, 480p)
  • Jul 10, 2008 | Akai PT5492S 54" Rear Projection...
    No picture
    It's likely the Ssb is out, Philips p/n# 319801634710 which on a difficult scale of 1-10 is about a 6 or 7 for repairs. That is a DPTV310 chassis and somewhat tight quarters inside. It's not so bad taking the strappings loose to get at the board but a tight area to work through getting the standup board unplugged from the signal board. One noteable caution: unplug the set for at least 10 minutes before opening the back VERY STATIC SENSITIVE..
    Apr 02, 2008 | Philips 60PP9352 60" Rear Projection...
    How do i get 1080p
    How did you get 720p? I have having trouble viewing anything above 480p. When using my directv HD DVR, the screen goes black when it tries to show anything above 480p. Is it the tv or the DVR?
    Jan 04, 2008 | Mitsubishi WS-65905 65" Rear Projection...
    Mitsubishi WD-52725 52". Rear Projection HDTV Logo
    110 people viewed this question
    Top Mitsubishi Projection Televisions Experts
    matt martin
    matt martin
    Jaime Hernandez
    Are you a Mitsubishi Projection Television Expert? Answer questions, earn points and help others
