Question about Lakewood Dryers
How to lubricate my Lakewood window fan? - Lakewood Dryers
    Problem Solver:
  • 14 Answers
All you need to do is take off the cage and blade. There should be a little space in between the shaft and the hole it goes through. That's the front bearing of the fan. Put some oil(3-in-1 blue can oil or zoomspout) in that area and if you can take off the motor and oil the back opening. Reasemmble the fan and run it for a little bit.
Posted on Mar 31, 2013
It's probably not a good idea to lubricate your fan, as a wet lubricant will cause dirt to bind to moving parts in the motor which will in turn act as an abrasive causing the motor to prematurly fail.
The fan it's self should be sealed at the factory and provide years of mantenance free use.
Posted on Jul 29, 2009
  • mline27 Aug 10, 2011
    My 22 year old fan is screeching it needs a lube. even if it kills it it will die anyhow if I don't do it. what is the best thing to use and how do I do it.
Do you bypass the run capacitator on a lakewood model hv-18 fan with a 2.4 motor
More than likely it's not the start capacitor why your fan will not run this more than likely it's not the start capacitor why your fan will not run this lubrication try turning the fan motor by hand if it does not turn freely it's lubrication I have answered this another post.
more than likely it is lubrication spray WD-40 into the oil holes after you have unplugged the fan of course Keep turning the fan and you'll notice will start turning more freely apply more oil to the rear of the motor as this is an oil bushing you're putting more oil into
hope this solves your problem
May 03, 2012 | Lakewood HV 18-c Floor / Box Fan
Troubleshooting lakewood fan model hv 18
This one the best brands on the market that I have ever owned.
If the fan motor will not turn on or hums and/or turns slowly more than likely its a lubrication problem.
1. Unplug the fan from the wall remove the 516 screws to the cage
2. Try turning the fan blade by hand if it is tough to turn more than likely it's a lubrication problem
3. You will have two oil holes one in the front one in the back spray WD-40 into these holes, turn the fan blade if it starts to free it up apply more WD-40 and keep turning the blade add more WD-40 until the blade turns freely. Especially in the rear oil hole because this is an oiled bushing that you are adding oil to. Once the fan is turning freely replace the front cage with all the screws plug the fan and I hope this solves your problem. You may add 3 in 1 oil or some other very light lubricating oil periodically.
I hope this solves your problem Mike
Mar 03, 2012 | Lakewood HV 18-c Floor / Box Fan
How to lubricate
Selecting the proper industrial gear lubricant is important to the long-term efficient operation of the gear drive. There are many factors to consider when selecting an industrial gear lubricant for a particular application. These factors are summarized in Table 1.
Oct 24, 2010 | Lakewood (r) Industrial Drum Fan (MC-24)
Are replacement motors available for these fans? Lakewood HV 18 Lakewood HV 21 Lakewood HV 21T
mcdevito75 here, If the fan is not too old I would figure yes, but a replacement motor will cost as a new fan, if not more, then you have to install and the blades are a presss fit to the motor.
Jul 27, 2010 | Lakewood HV-18 Floor / Box Fan
Fan blade is not rotating but there is noise
The rotor is stuck and the fan blade will not rotate then a humming noise can be heard. It is due to a bushing problem. It may be stuck due to a hardened accumulated dirt.
  1. Remove the fan blade guard.
  2. Remove the fan blade.
  3. Remove the 4 screws holding the stator assembly.
  4. Pull out the front plate of the motor and the rotor.
  5. Clean the bushing and the rotor.
  6. Lubricate the busing and rotor assembly.
  7. Reassemble in reverse order.
Nov 27, 2009 | Lakewood 16" Stand Fan
Does the lakewood fan have a fuse that can be replaced?
No, it is either the speed control, capacitor or motor. You can get parts, if it worth your time, try nelsonappliance.com and part # LW007JRMOTOR
Aug 26, 2009 | Lakewood HV 18-c Floor / Box Fan
Engine trouble
clean bushing and check alignment and lubrication..
Jun 22, 2009 | Lakewood HV 18-c Floor / Box Fan
Dryers Logo
445 people viewed this question
Top Lakewood Dryers Experts
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Lakewood Dryer Expert? Answer questions, earn points and help others
