Question about NEC MobilePro 900 Handheld
Mobilepro 900c won't sync
Hi, Guys,
I purchased my mobilepro 900c on EBay. It seems to work just fine. On my PC (working under XP) I have installed Outlook, I have installed Winsync 3.8, I have installed nec\WinXP USB Driver-- serial-over-usb host driver for WCE USB devices (recommended by another site). Nothing works. I get the audio beep on both machines when I connect but don't get the USB system tray icon. Winsync3.8 does its search for a usb device and can't find one. It says nothing is connected. The USB port works fine with other devices. I have tried deactivating the firewall and anti-virus. Nothing works. I have seen similar letters of dispair on other fourms. It must be a common problem--but is there a common solution?
Thanks, Richard
Re: mobilepro 900c won't sync
I'm having the same problem. Sorry man. I'll let you know if I find something out!
Posted on Feb 10, 2008
0 characters
3 Points
Active sync
Do you have the proper drivers installed? Try here for USB to Computer Drivers if you have Windows XP: Also make sure that you have Activesync 3.8 or other version of 3. You can find it here:
Feb 26, 2008 | NEC MobilePro 900c Pocket PC
NEC Mobilepro 900c will not connect w/computer
Are you using the NEC Mobilepro 900c drivers? I'm sure the drivers are different. YOu can find the XP drivers here: In addition, you should make sure that you have Activesync 3.8 or older. You can find it here:
Dec 25, 2007 | NEC MobilePro 900c Pocket PC
Mobilepro 900c Ethernet Card
I use the AVAYA wireless card. It needs to be wireless B. Dowload the driver for it when you sync. Then it should work.
Aug 21, 2007 | NEC MobilePro 900c Pocket PC
Getting connected
What kind of Drivers? USB sync Drivers or Orinco Wi-fi Drivers? Try here for USB to Computer Drivers if you have Windows XP: The full CD contents that come with the Mobilepro can also be downloaded from the same page. For Wi-fi Drivers, I THINK the Agere Wi-fi Drivers will work, although I may be mistaken. Try them Here:
And any MiniUSB cable will work with the Mobilepro
Aug 12, 2007 | NEC MobilePro 900c Pocket PC
Device not detected
download the usb drivers
Jul 29, 2007 | NEC MobilePro 900c Pocket PC
Display problem on NEC MobilePro 900
I just bought a 900C on eBay and had the same problem. According to the seller "the video cable on the right under the hinge cover gets loose..if its reseated it will be could just press on the bottom of the hinge cover right and it will make it go away but best to reseat the cable." I haven't tried his solution yet. Mine seems to intermittent since it is working fine right now.
May 30, 2007 | NEC MobilePro 900 Handheld
Nec Mobilepro 900c
right clik my computer,go to properties,click on properties,click on hardware devices you will see the list of all the hardware components installed on your computer,check to see if your network adapter is installed,if not installed you will see a yellow balloon attached to the adapter icon,then try and install the device.if the device is installedbut you can't browse,i think that has to do with you internet configuration.try using the a unique computer name and the correct workgroup name,good luck.
Feb 27, 2007 | NEC MobilePro 900c Pocket PC
NEC MobilePro 900 Handheld Logo
418 people viewed this question
Top NEC PDAs Experts
Jay Seifried
Level 1 Expert
Are you a NEC PDA Expert? Answer questions, earn points and help others
