Question about Hoover Vacuums
I have a hoover pure power and I am wanting to change the belt I have removed he screws at the bottom but what do I do now
I have removed the screw at the bottom but how do I get the belt on
SOURCE: screw rusted; cannot remove
nut, is attached to the motor ( armature) the plastic housing is a cheap replacement but the nut that is attached to the motor is not, crack the plastic housing (looks kinda grayish right) AND ATTACH A VICE TO ONE AND A NEEDLE VICE TO THE LOWER THIS SHOULD WORK,,,,,DO NOT STRIP ANYTHING DONT WORRY ABOUT THE BOLT IT IS A CHEAP REPLACEMENT TO
Posted on Jan 26, 2008
  • 107 Answers
SOURCE: water leak under my hoover steam cleaner
Sounds like you have a bad solenoid.
Posted on Dec 09, 2008
SOURCE: Hoover Flair S2220 cleaner w/power nozzle disassembly instructions
With the head flipped upside down, take a flat tipped screw driver and carefully pry up the rollers on the front the head. Underneath, you'll find a screw. Remove the screw under each roller, and the front cover will come off with ease. The rollers are just friction fit.
Posted on Jan 03, 2009
SOURCE: Eureka model 4335 - belt removal (top cover)
loosen two screws on either side on top of the housing lifts off the top. exposing the roller and the broken belt.
Posted on Mar 25, 2009
SOURCE: How to replace power cord on Hoover WindTunnel upright vacuum
The aforementioned solutions probably never even attempted this fix on this model. The handle does NOT need to come off. but the 5 screws on the front housing DO: 2 above the light and 3 below it. Then to get the colored housing off you need to access 2 screws on the underside that are beneath the agitator roller. To do that, obviously the 4 screws holding the bottom plate need to come off too. Here's a link to a schematic that might help as you attempt to do this, (assuming that you still do!) http://www.elkypro.com/hoops2005/vacuum_parts/hoover/U5461-900.html
Once you have the main body housing cover off, then you can access the 2 screws atop of each trunnion cover that holds the motor assembly cover halves together. If you've made it this far, then gently pry apart the motor halves keeping even as yo do. Now you can see all the wiring necessary to cut and splice. Happy cord replacing! As for me, I am headed for the store, as I am not so sure I can remember how to get the darn thing put back together. But it was fun taking it apart!
Posted on Apr 29, 2010
HOW DO I CHANGE BELT ?
Hello! Below are step-by-step instructions for changing the belt on your Hoover S1147.
1. Rotate nozzle to the vertical position. Lift off front cover.
2. Remove the two bottom plate screws.
3. Pivot off bottom plate making sure to unhook center tab on inside edge of nozzle.
4. Remove agitator and used belt from nozzle.
5. Put new belt on agitator. Position agitator in nozzle orienting agitator end caps with slots on both sides of nozzle. The belt should line up with tab on inside of nozzle.
6. Attach belt to motor pulley.
7. Replace bottom place by first hooking it to center tab on inside of nozzle.
8. Reposition screws and front cover.
Hope this helps!
Jun 02, 2014 | Hoover S1147 Twist Vac Handheld Vacuum
How do I change the belt?
To change the belt on a Hoover Flair Stick Vacuum, remove all 6 screws from the bottom of the beater bar. There are 2 screws hidden under wheels. You must pop the wheels off with a screw driver to remove the hidden screws. The cogged belt is on the left side of the beater bar. Be careful not to pull the wires.
Jan 22, 2013 | Hoover S2220 Flair Bagless Upright Vacuum
The bottom of the hoover wont work. its not picking anything up and not spinning round.
You most likely will need to replace the belt on this model. There are 4 screws in the corners of the bottom power nozzle. DO NOT remove the 3 that are grouped together (these are the motor screws). once the top is removed then remove 3 roller cover screws. replce belt and reassemble in reverse order.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Oct 28, 2009 | Hoover S3639 WindTunnel Bagged Canister...
there are two screws undeneath unfaseh those then the bottom plate comes off then prise the roller out then the belt fits over the motor spindle first then over the brush then reasemble
Aug 23, 2009 | Vacuums
I have a Hoover TurboPOWER 7300 Windtunnel V2-belt change
1. Remove the 4 screws holding the bottom plate.
2. remove roller and old belt
3. install new belt on motor spindle first and then on roller.
4. pull roller, stretching belt, set into roller cavity.
5. turn roller by hand to center belt.
6. reinstall bottom plate.& screws
Feb 26, 2009 | Hoover U5444-900 5100 Wind Tunnel 15 Inch...
Hoover sweeper model U4263-930 belt change
undo screws on bottom of vac take out brush and belt put belt in then manewver brush in
thank you for useing fixya please rate me
Feb 07, 2009 | Hoover Vacuums
Changing the belt
If this is a Savvy, then take out the screws for the bottom plate, then remove the screws that hold the top on, turn the vac over, and remove the Hovver emblem, there is a screw there, then the top cover comes off and you can replace the cogged belt.
May 31, 2008 | Hoover U8185-900 Upright Vacuum
Hoover US8174-900 Savvy Bagless
It uses a cogged belt, turn it over, remove the bottom plate, remove the other screws from the bottom, turn vac back over and remove the Hoover emblem, there is a screw there to remove and the top comes off, then you can get to and replace the belt.
May 26, 2008 | Hoover U8145-900 Savvy Bagless Upright...
Belt change on savvy upright
Take off the bottom plate, also remove the screwsfrom the bottom to remove the top cover, also there is a screw under the Hoover emblem on the top cover, with these removed you can get to to brush roll and belt.
May 11, 2008 | Hoover U8171-900 / U8172-900 / U8173-900 /...
How to change the belt on a Hoover High Performance upright vacuum cleaner
Generic problem for all Vacuums
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Most of the Hoover upright vacuums service from the bottom and to start remove the bottom plate, that should expose the belt – if this is the case, some Hoover’s might be self propelled, if not the self-propelled vacs have 2 belts and the non self propelled models have one belt – so remove the belt(s) and then lift up on the brushroll and slide the belt onto the belt pulley then take a screwdriver tool with a hook on the end and stretch the belt onto the motor shaft – once this has been done the track the belt(s) and it should straighten out and run straight, re-install the bottom plate, plug in and test. If you cannot get @ the belt from the bottom the look for 2 or 3 screws – remove the screws and the top cover will lift off and then follow the procedure mentioned above… Questions? Please feel free to contact your local vacuum dealer in your area or in the yellow pages or contact the Hoover factory for more details.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Apr 22, 2008 | Vacuums
Vacuums Logo
32 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
