Question about Irons
My steam iron is full of cal
My steam irons metal base is full of cal deposit, have tried removing with conventional cleaner- but would really like to remove the base and completely clen out
can anyone tell me how to remove base?
  • 154 Answers
Use vinegar to clean
Posted on Aug 02, 2009
My stream iron generator tefal and problem some parts outstanding on base of iron , and stream can not get out , how to remove PARTS.
follow this steps and fix it. God bless you
Clean an iron:
  1. Unplug the iron and make sure it is cool before cleaning.
  2. Use a toothpick or pipe cleaner to remove buildup in the steam vents, making sure the debris doesn't fall into the vents.
  3. Use a fine sewing needle to carefully clean the spray nozzle of mineral deposits.
  4. To flush sediment from a steam iron, pour 1/2 cup water and 1/2 cup vinegar into the water tank. Place the iron on a rack over a broiling pan and set the iron to steam until the tank runs dry. Repeat if necessary. Or follow the instructions for using a commercial iron cleaner.
Service the steam and spray mechanism:
  1. Unplug the iron.
  2. Use a fine sewing needle to unclog the steam valve assembly. Also, check the valve spring and replace it if it is broken or has lost tension.
  3. If the spray pump is accessible, remove it and check for leaks by placing the spray tube in water and squirting the pump. Clean or replace as needed.
Clean a metal soleplate:
  1. Unplug the iron.
  2. Use a sponge and commercial soleplate cleaner or baking soda and water to remove dirt buildup on the soleplate. Rinse well with water and dry. Don't use harsh abrasives or immerse an electric iron in water.
  3. Use very fine steel wool (0000) or an emery cloth to remove scratches and burns on the soleplate, then clean the soleplate.
Oct 02, 2013 | Tefal Irons
WATER HOSE PERISH
Clean an iron:
  1. Unplug the iron.
  1. Unplug the iron.
Oct 01, 2013 | Irons
My steam cleaner was working, then when i refilled it, it didnt heat up. its a multipurpose with different attachments. could it be element gone?
Clean an iron:
  1. Unplug the iron.
  1. Unplug the iron.
Sep 30, 2013 | Conair Compact Garment Steamer Iron
How to open a steam iron severin
follow this principle.God bless you
Clean an iron:
  1. Unplug the iron.
  1. Unplug the iron.
Jul 20, 2013 | Severin Steam Iron, 2500 Watt, White...
The steam button is stuck on (pushed in) but there's no steam.
follow this steps. God bless you
Clean an iron:
  1. Unplug the iron.
  1. Unplug the iron.
Nov 15, 2012 | Black & Decker Irons
As the steam builds up it constantly comes out of the the blow off pressure valve under the iron. steam will come out of the sole plate when the button is pressed
see this causes and fix it. God bless you
Clean an iron:
  1. Unplug the iron.
  1. Unplug the iron.
Oct 02, 2012 | Irons
When I iron my white sheets dirty water comes out and my sheets are dirty
follow the steps and fix it. God bless you
Clean an iron:
  1. Unplug the iron.
  1. Unplug the iron.
Oct 01, 2012 | Tefal Pro Express GV 8120 Iron
What happens if I use CLR in my steam iron? I have an expensive European style iron which is no longer producing steam. I have bought an iron descaler/cleaner and have repeated its use. I tried the...
The steam tank may not be heating because of mineral deposits in the tank. But also do this check first. Open up the tank reservoir cold, and drain all water out, (is it clean inside there when you shine flashlight in there? Rinse with clear filtered water only (low minerals).
Do not use CLR or anything agressive in there. You should have the main unit in full steam mode and the iron control also in full steam mode. Leave one tablespoon of water in the tank, put back together and let the pressure build. Put a clean towel on your ironing board and when iron is at full pressure and heat, hit the burst of steam and look at what comes out of the sole plate. If you see lots of white deposits look at the sole plate and see if the white chunks are coming out steam holes.
When using iron, run it till steam/water tanks are dry, the burst of steam is used in this case to clean the iron of all standing water. Pull the reservoir and allow to cool...once tank is cool drain it as well. Doing this several times should help purge unit of the heavy mineral deposits.
If you need parts, here is the Rowenta repair facility....
California Electric Service in Concord CA (it is the only Rowenta repair station in California) go to either of the following addresses:
their website is: http://www.californiaelectricservice.com/
or tech service: service@californiaelectricservice.com
Mar 12, 2010 | Rowenta DG-980 Iron
Irons Logo
83 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
