Question about KitchenAid KSRD22FKBT / KSRD22FKWH / KSRD22FKBL Side by Side Refrigerator
Kitchen Aid Fridge
I have a Kitchen Aid Fridge but I am not sure how to tell which model I have. The freezer is freezing well and the fridge has ice on the Roof of it but it is not cooling properly. I have recently plugged it in so I do not think there can be ice built up on the coils. Do you have any suggestions. Thanks
How long does it take for fridge to cool if its not been used in months?
Posted on Mar 07, 2008
Why the heat exchanger between the freezer section and the fridge section freezes up around the second element closer to the door and makes ice on the roof of the fridge section.
If your freezer is icing up it is the defrost mechanism consisting of the timer, heating element, and defrost thermostat.
When you unplug unit everything melts and it runs fine for a few days till it freezes up again.
Usually it is the heating element that just burns out and has to be replaced.
Sep 14, 2015 | GE Refrigerators
Buzzing sound Kitchen Aid fridge Model KBLA20EMSS
It may be the arm in the ice maker is down. Even though the ice maker does not have the water hooked up if the arm above the ice bin is down it will still cycle the ice maker try lifting up the arm it should stay up this signals the ice maker that the bin is full and should shut off the ice maker. Hope this helps.
Dec 31, 2013 | KitchenAid KSCS25FKSS Side by Side...
How to defrost freezer in kitchen Aid bottom drawer freezer
My kitchen aid bottom drawer freezer kept melting and freezing to block the drain and then water would leak out all over the floor. I did the WHOLE fridge/freezer defrosting process once, when i really just needed to do the bottom.
I have had issues with other Kitchen Aid (NEW BTW) appliances so I've talked to many repair people. One guy who came out to fix something else, told me that the freezer is really a pain to get to close completely. SO, when you don't close it all the way (Extra push) it will melt and then re freeze when it is closed properly. He suggested I take everything out, leave it open and use a hair dryer on the ice until it melts. Then use a wire hanger to unplug the drain to make sure its draining properly.
It works! You really have to make sure the drawer is shut ALL the way. I have a 2 yr old who is constantly opening it up...this is my issue! The seal is not that great and you have to really push it closed to prevent the ice build up issue.
Hope that helps!
Sep 10, 2013 | KitchenAid Refrigerators
Fridge freezing items in veg draw
Usually the thermostat stuck closed but can sometimes be drain water freezing after defrost due to blocked drain. Fully defrost and check water drains away.
May 09, 2012 | KitchenAid Whirlpool Kitchen Aid...
Kitchen aid KSRG25FKSS04 freezer is not freezing
Hello, few things to check:
1) Remove dirt / dust that has accumulated on the condenser coil located on the back of the fridge, or underneath. Use a vacuum to clean off with.
2) Remove dirt / dust in / around compressor area. Make sure you turn power off first as there are several areas in this area that can "bite."
3) Look for heavy frost / ice buildup in the freezer compartment. Defrost if necessary.
4) Make sure the fan is blowing in the freezer compartment.
5) Make sure there is air flow from the vent at the top of the refrigerator compartment. This air is driven by the fan in the freezer (most models).
6) Loading a lot of unfrozen food into the freezer compartment will have the appearance of the fridge going out, but is actually functioning normally as it removes heat from the food so it will freeze.
7) Your thermostat is not working correctly. Move it to the coldest setting if not already done so. Listen for the compressor to kick on. If it doesn't, bad t-stat.
Jul 12, 2010 | Frigidaire FRS26KF6E Side by Side...
if neither one works that usually is the water valve located on the back of the fridge. Try this manually fill the ice make with a glase of water and check the temp. in the freezer. you can reach in and touch to see if water is freezing in ice maker. see if it dumps the ice then surly the valve is bad
Apr 21, 2010 | KitchenAid KSCS25FKSS Side by Side...
Freezer and icemaker freezes, jams.
I have run into this before and found it very helpful to re-level the refrigerator. By leaning the fridge back toward the wall about an inch helped keep the water and ice in the tray. Remember to remove items that block air flow in the freezer. Remove the ice bin and clean it then start over with the fridge leaning back a little. Hope this helps.
May 01, 2009 | KitchenAid Superba KSRG25FK Side by Side...
Kitchen Aid Fridge problem
ok first the freezer does all the cooling for the whole unit and in order for it to cool properly the freezer needs to be a certain temp it should be around -10 -6 if its not reaching that temp it will still freeze and apper to be working right also check to hear if the freezer fan is running as it pulls air from the fridge and cools it then blowes it back look in the freezer on the back wall toward the bottom see if frost is building also in the refridgerator section on the left hand side of the cabnit is a return vent make sure its not blocked and see what the thermostat in the freezer is and let me know we need to know things like this to help narrow the promblems and people dont reply to the questions so we cant answer appliance repair is a skill
Jul 13, 2008 | Refrigerators
Stinky Ice
You could try using ice aid, However there is nothing on a fridge that causes an odor only things that are put into the fridge i.e. food, water quality.
Nov 07, 2007 | Refrigerators
KitchenAid KSRD22FKBT / KSRD22FKWH / KSRD22FKBL Side by Side Refrigerator Logo
157 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
