Question about Dyson Vacuums
How do I remove the power switch assembly for my Dyson 365 to check the starter switch? When I push the red button, it won't stay on.
  • 43 Answers
SOURCE: Dyson DC07 main power switch
you will need to replace this switch remove the bucket from the front of the machine and the handle and pipe from the back on the front of the switch housing you will see a screw remove this screw on the back you will find two little catches one on either side push these with a screwdriver then the sides of the switch housing will pop out from the chassis now on the front theres another on the bottom of the housing push this down and pull the housing off from the front when replacing this part be carefull not to trap any wiring
Posted on Nov 11, 2008
SOURCE: dyson animal, have to hold ON switch for it to work
Pull the wand out of the Vac. Need to use a small Torx bit to take out 2 screws hidden behind the wand storage. Once screws are out, there are 4 push-clips which need to be un-latched. Pry the power panel off and you will expose the two switches (one for power, one for the brushes). Push the power switch down and it should "release" and go back to clicking when pushed. Re-assemble. Took about 5 minutes to fix.
Posted on Nov 15, 2008
defrankond
  • 65 Answers
SOURCE: Dyson DC01 - can't get starter button switch off.
this issue is known well with dysons to be honest you will continue to have this problem for as long as you have the vacuum. they use substandard plastic parts which break easy. You will have to replace the button and make sure there are no other broken pieces of plastic in the housing before putting it back together.
Posted on Nov 30, 2008
SOURCE: dyson dc17 animal
on the bottom plate are 3 spots, one in the center and one at each corner, that need a flat head screw driver to loosen. turn left to unlock, this will remove the plate so you can clear the debris from the brush.
Posted on Feb 01, 2009
  • 83 Answers
SOURCE: Dyson will not stay powered on unless power button
Yes, you probably need to replace the switch - call the Dyson helpline, they'll give you the info for your closest authorized repair dealer who will open it up and replace the switch for you.
Posted on Jul 30, 2009
Dyson dc25 power switch will not stay on
I called Dyson because I had a similar problem. When I pushed the red button down on my dc25, but it would not stay down. The vacuum would turn on when the button was pushed down, but of course when I let go of it the vacuum would shut off. The helpful telephone tech. Recognized the symptom right away and told me to push down on the button fully and let It flick up like a lighter. I about fell off my chair when that worked right away! Anyways for what it's worth, she said sometimes the mechanism in the buttons gets consnarlitated (my tern, not hers!) and this resets the spring.
Feb 19, 2012 | Dyson DC25 Animal Bagless Upright Vacuum
Dyson DC 25 power switch replacement
It a fairly straightforward procedure. Remove the accessory hose to expose 4 torx screws from behind that hold the front switch cover in place. After removing the screws, gently pull the front switch cover and carefully pry two plastic tabs apart using a small screwdriver that "snap" cover in place. The switches will be exposed. The electrical connectors each have a tiny lock button at the base of the terminal that you need to push to remove. Otherwise they won't pull off easily. Assembly is reverse with one note: You'll have to hold the plastic cover and push buttons together so they don't fall out as you place the the cover back on. Once you get it on, the plastic tabs will hold until you install the torx screws. Be sure to retest the push buttons to make sure there was no binding in reassembly.
If I may add one more thing- I believe all DC25's carry a 5 year warranty and switch failure is covered. I replace these routinely. If you call Dyson, they will likely refer you to an authorized repair center for replacement at no charge.
Regards
Feb 16, 2012 | Vacuums
The power button on my Dyson DC19T2 won't stay on
The switch is broken. If you are handy, remove the old switch and match it up at a hardware store or a Vacuum repair shop. It shouldn't cost much to have it replaced by a proffessional either.
Nov 18, 2011 | Dyson Vacuums
When i push the power button and let go it turns off and won't stay on. what might be the problem.
Sorry to hear you're having difficulties with your DC27. In case you haven't already tried this, make sure you press down firmly on the power switch when turning the cleaner on. If the switch still won't stay down, it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you, and recommend the best course of action. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
Aug 20, 2011 | Dyson DC27 Bagless Upright Vacuum
Brush will not spin
- Look for the reset button on the side of the brushbar housing - there should be a red sticker and a red button. Push it once. It's not gonna stay depressed, it's gonna pop right out - that's normal.
- Step on the red pedal on the back
- Turn the machine on with the red power button
- Press the gray button next to the red power button - this is the ON/OFF switch for the brushbar
- If it still isn't spinning, open it up and make sure nothing is blocking it and withholding it from spinning
- For further troubleshooting assistance call the Dyson helpline, they know what they're doing
Jun 28, 2009 | Dyson Ball DC24 Bagless Upright Vacuum
Dyson DC 24 pick up head wont spin
- Press the gray button next to the red power button - this is the ON/OFF switch for the brushbar - if it doesn't spin, press and hold the gray button down for 10 seconds
- If it still isn't spinning, remove the brushbar and make sure nothing is blocking it and withholding it from spinning
Jun 20, 2009 | Dyson Ball DC24 Bagless Upright Vacuum
Dyson animal, have to hold ON switch for it to work
Aug 06, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
On button won't stay on
easy fix, unplug the machine sit in front of it. put your thumb on the on/off button and push down and slip your thumb off of it as fast as you can so it pops real loud. Do this ten times and then plug back in and see if it works. ( this came from talking with Dyson people) Hope it works for you. They said this will reset the machine. also acts as a warning that your filters most likely need cleaned.
May 21, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
Vacuums Logo
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
