Question about Apple iPhone Smartphone
My iphone cannot switch on what do i do?
I was using my phone normally. i left it charging and in the morning it was off and could not turn on. i have tried to put it on but it havent worked
    Novelist:
  • 112 Answers
Usually, with my HTC Touch Pro when this happens, I just remove the battery for a minute then put it back in and turn it on and it works.
In your case, if I recall correctly, iphones have the battery virtually sealed into the phone and Apple would need to pull it out and replace it for you. That is, if you don't want to void your warranty/insurance.
Honestly, I would contact Apple for support with this issue.
I hope this helps :)
Best Regards,
James
Posted on Jul 29, 2009
After connecting the charger cord and plugging it into the wall socket, is the iPhone to be turned off or turned on?
If you turn it off, it will charge faster. I've done both. This morning my charge was very low. Then I noticed the plug became out of the socket. Try it both ways,see what happens. If you are charging with it on, have you closed all your apps? Double press the on/off button on the bottom front. Any open apps will appear half size. Place your finger on the app, and slide it UP and "OFF" the unit. Turn it off, try charging. Be sure your plugs are all the way in. If you try it turned off, the unit will briefly show your current charge, then turn itself off.
Sep 22, 2014 | Apple iPhone 5c
My iphone won't charge up at all i put it on
hi there.
Follow these steps:
  1. Remove any debris from the charging port on the bottom of your device.
  2. Restart your iOS device.
  3. Try a different USB cable or charger.
  4. Make sure that you have the latest version of iOS.
  5. Contact Apple Support to set up service.
If your iPhone, iPad, or iPod touch won't charge - Apple Support
Why my iPhone is not charging?
2: Change the Wall Outlet or USB Port Plugged Into. The next most common reason aniPhone won't charge is because of where it's actually plugged into. Sometimes the wall outlet itself isn't working or the light switch is turned off, so if you're using a wall charger then change the outlet.20 Feb 2016
iPhone Won't Charge? Here's Why iPhone Isn't Charging & How to Fix It
How do you clean the charging port on iPhone?
To be safe, back up your iPhone or iPad to your computer or the cloud. Power it off, and with a normal toothpick, gently remove the lint. You will be amazed how much can get stuck in the port. Connect the charger and see if it works.16 Dec 2014
Use a toothpick to clean out your iPhone - CNET
https://www.cnet.com/how-to/use-a-toothpick-to-clean-out-your-iphone/
How do I charge my phone if my charger port is broken?All you need to do is shut down your device, remove the battery if possible and use something small, such as a toothpick, to 'lever up' the little tab inside the USB port on your smartphone or tablet. Do so very carefully and gently, then reinsert your battery and plug it in again.16 Jul 2016How to fix a phone that won't charge properly - AndroidPIThttps://www.androidpit.com/how-to-fix-a-phone-that-won-t-chargeSearch for: How do I charge my phone if my charger port is broken?
or try this link.
iphone won charge up Google Search
Nov 19, 2017 | Cell Phones
Iphone wont charge
The battery might be damaged, but in most cases you can just let it be plugged in like you normally do. It doesn't show "recharging" because it has been too drained.
Turn on your phone after 15 min. in the charger.
If it still doesn't work, then you have to ask a store that supports Iphones.
Aug 06, 2014 | Apple iPhone 4S
My iphone 3gs will not charge or conect to itunes
REplace your data cable.If not working that also.... check you port of iphone.And try different USB port.
Thanks.
Feb 18, 2013 | Apple iPhone 3G
I walk up this morning and i found my iphone not working , not even showing any sign that a battery is down if i charge like its dead, yet before i slept at night, i left it charging but its battery w
Have you try to do a hard reset by simultaneously press on both Home and Turn off button. It can be a system crash. other way, you can try to plug your iphone to a PC and use "tiny umbrella" or others to exit recovery mode.
Jun 18, 2012 | Apple iPhone Smartphone
I tend to take my iphone in the shower with me, after a couple times i would see this thing come up saying interefence with the phone or i would have problem hearing, then it would go away.. i kept taking...
Water and steam is the worst enemy of all phones and mobile devices. You've most likely got severe water damage to the phone caused by the steam.
Never take a phone in the bathroom with you, for any reason. Water kills phones
Sep 06, 2011 | Apple iPhone Smartphone
After working just fine for months, yesterday the battery went down faster than normal.I plugged it in to charge it overnight and by morning there was progress on the charge bar
there was or was not progress on the charge bar.
if there was then you probably just used it a whole lot that day or had wifi turned on, bluetooth turned on, and brightness up. those are battery drianers.
if there was not progress then you need a new battery, search craigslist for it and there will be people willing to fix that for you for around $40
Apr 17, 2010 | Apple iPhone Smartphone
My iphoneran out of battery and wont charge (i think)
try leaving it on charge for a few hours, otherwise that ipod radio could have damaged it
Nov 02, 2009 | Apple iPhone Smartphone
Iphone won't charge and now won't work
I left my phone charging for a few hours and it appeared not to be charging as the battery icon was staying at 10% of charge. I was confused because it had the charging icon in the upper right hand corner. If your phone is doing something similar i simply powered the phone down and turned it back on. The charge went from 10% to 100% on the display. This is what worked for me hope this helps.
Jan 22, 2008 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
1,064 people viewed this question
Top Apple Cell Phones Experts
David
Martin Murray
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
