Question about Hobart 24 in. LXIH-3 Built-in Dishwasher
E3 is showing up on the screen. We were told in the past this means that the probe is clogged we cleaned it out the way the guy showed us but this has not solved the problem.
    Scholar:
  • 109 Answers
E3 is -- water did not reach the middle probe in time. It's the longer of the two probes in the right rear corner. they should be white plastic insulators with stainless pins . Scale may be built up on the pins. Check for corrosion on the probe assembly connector on the rear outside. The connector is directly under the vacuum breaker which will leak if dirty of if pressure is low.. Watch the control board leds to monitor water level as it's filling. make sure you have 20 PSI fill flow pressure. Your system may be choked with scale restricting flow rate.
Posted on Aug 14, 2009
I use this dishwasher in a florist to clean wax out of candle glass and recently it is not working. E4 codes appear, and it over flows sometimes.
this all I can find Machine will not fill or will not fill high enough. (Display shows E0, E2, E3 or E4. Machine will not run). 1. Low water pressure - check for clogged hose strainer; ensure the site water pressure meets minimum flow pressures. 2. Make sure probes are clean. (See Cleaning.) 3. No water pressure - main water supply valves may not be working. 4. Anti-siphon valve - located in the lower left area of the chamber just above the water line. Drain the machine and insert toothpick or similar object into hole to verify ball (3?16" OD) is free to float. 5. Delime machine perhaps the wax is plugging up the floating ball area
Apr 20, 2015 | Hobart 24 in. LXIH-3 Built-in Dishwasher
LX30H THROWS A CODE EO after running awhile. I hit the high reset button under the flaps on the front for both the boost and reg elements . It will work for a couple cycles and then does the same thing....
Machine won't fill or won't fill high enough. site water pressure meets minimum flow pressures. (LX18, LX30 display shows working.
"E0," "E2," "E3," or "E4". LX40 display shows "DR1 PRBLM," "FILL1 PRBLM," FILL2 PRBLM," or "FILL3 PRBLM". Machine will not run.)
1. Low water pressure - check for clogged hose strainer; check that
4. Drain valve open - turn machine OFF to drain machine, then
ON. Repeat twice (this assists in clearing any drain valve
obstructions). Wait for machine to reach READY mode and
press WASH. Slowly open door several seconds later and note
water level. Close door; 30 seconds later, open door slowly and
check that water level is the same as it was. If not, repeat the
OFF-ON procedure. If problem persists, call your local Hobart
Service Office.
5. Delime machine.
https://my.hobartcorp.com/resourcecenter/ProductDocumentation/F18615%20Rev%20I.PDF
Dec 10, 2013 | Hobart Lx30h Commercial Dishwasher
Dishwasher showing e3 error
E3 error arises due to the malfunction of temp sensor or the heating element. Check for the thermostat.
Jul 02, 2012 | Baumatic 23 in. BDW13 Built-in Dishwasher
Code E3
e3 cde show no fill,,,is the water turned on you might have to clean inlet screens,,,check fill vavle ..good luck
Sep 10, 2011 | Maytag Neptune MAH5500B Front Load Washer
I have kitchenaid Kerc700 electric range that had the code F2:E3 show up on the display. What does this mean?
Hello, Thank You for using FixYa. I will be helping you today.Kitchenaid F2-E3 means a button was held down too long if you push cancel and it comes back you would have to replace the glass console. Thats assuming its F2-E3 and not E3-F2
Thank You and please rate my answer if it was helpful..
Jun 12, 2011 | KitchenAid KERC700 Electric Kitchen Range
I have a PD code on a Hobart LXI dishwasher. What does that mean
PD is not an error code. It shows that when it draining water out shortly after power-up and when shutting down. If it seems to be showing "PD" longer than usual, it means the dishwasher's control circuitry believes there is still water in the tank, due to a faulty water level probe, most like the one under the lift-out screen. It has a plastic body with a metal probe coming out the center.
There is also a dual probe at the rear of the machine, but I believe the dishwasher uses the front probe to determine when to stop draining the machine during "PD" - most likely meaning "Power Drain" or "Power Draining".
If you are not seeing any E- codes (E1, E2, E3, etc.) then these water level probes are likely just fine and the "PD" is appearing normally, as it should during draining conditions.
Feb 08, 2011 | Hobart 24 in. LXIH-3 Built-in Dishwasher
What is an E3 error message
E3 FROST PROBE OPEN: Normal operation is allowed. Replace probe.
E3 FROST PRObE OPEN: Normal operation is allowed. Ohm frost probe. Replace probe if ohm value not read. If ohm value is present replace board.
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 10, 2010 | Fedders A6D24E7D Wall/Window Air...
The machine does not make copies showing an error E3 which i can not see where i can find it
yep!
e3 means a machine error and it need a service technician to fix it.
furthermore may i ask what e3 code displays on the screen (you might see something like this e3 10 , e3 40 , e3 01 etc)
i can still help you if it is e3 10
Jan 04, 2010 | Panasonic FP-7735 Black and White Copier
E3 showing on Kenwood model KDW243A
E3 means longer heating time. Usually this indicates the heater element has failed.
Aug 01, 2009 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
Kenwood washing machine display showing E3
e3 means there was a longer heating time but not reaching required temperature could be a malfunction of temperature sensor or of heating element.
Please do rate my solution also do post further comments if any help needed.Good luck with the machine.
Apr 08, 2009 | Washing Machines
Hobart 24 in. LXIH-3 Built-in Dishwasher Logo
207 people viewed this question
Top Hobart Dishwashers Experts
Jason
Garth Jackson
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
