Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
WD440 HOTPOINT AQUARIUS LEAKING FROM FRONT/NOT DRYING
Hello
My HP WD440 hasn't been able to dry for a while - technician couldn't fatham it either...now it leaks from front of machine (know its front as dust behind machine is dry - lol!) Any ideas on what i can try to resolve issue? Have tried looking for a filter and can't find one, i pulled down kick front and can see a red disc seal to the right but this has a diagram on it which says don't touch! I've not pulled it out yet as its in quite a small gap and not sure i can do that on my own. Also cleans soap drawer out and that didn't help.
Thanks
    President:
  • Hotpoint Master
  • 662 Answers
Power off the mains. The filter is located behind the silver plate at the back of the machine at the bottom. Four screws hold it on. Drain out all the water. The filter is inside the big black rubber hose attached between the pump and the main drum. Remove the plastic clip holding it to the pump unit and then the metal cir clip holding it to the main drum. Inside is a white molded cone and a big white ball which floats. You will find a lot of junk here, clean out thoroughly. To refit put white cone back inside just as you found it, at the bottom, fit ball back into the cone. Attach to the bottom to the drum and re-fasten the cir clip. Finally reconnect the gator to the pump unit and tighten the plastic clip. Check out the pump too before reconnecting.
The leak in the front could be from one of the tubes bringing water to the detergent box; you should open up top to locate.
And rate me nice pl for the free help!
Posted on Jun 08, 2010
My Hotpoint Aquarius WD440 smells of hot rubber when it is on the M (drying) programme and the clothes come out smelling of rubber. Can you tell me why this is happening. Everything is working fine...
Hotp[oint Aquarius WD440 washer /dryer - Has a distinct smell from clothes when washed like stagnant water is lying somewhere in the machine, It has all benn stripped down but cannot find anything wrong. Whats the solution????
Aug 11, 2011 | Hotpoint Aquarius WD63 Front Load...
Hotpoint aquarius wd440. Flashing lights
press and hold on off button till the display panel lights up.Then press and hold the on/off button and the start /cancel button together.You will now reset the washing machine settings.And just pick your cycle again
Oct 04, 2009 | Hotpoint Aquarius WD63 Front Load...
Not drying
the steam gets condensed back to water and pumped away so sometimes draining problems cause poor drying. is the machine plumbed in according to handbook?
also your dryer filter may be blocked but this is not accesable without the dryer box being stripped down.
Nov 05, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint wd440 heating but not drying
yes, the dryer is pants im afraid. weve had ours going on 4 years & it has broke down every 6-10months - seriously! the dryer will leave clothes hot & steamy but when hung up for 1/4hr they r dry! _ Hotpoint advised us that he machine is esigned his way - but dont believe a word from their corporate b***hit mouths!
Aug 11, 2008 | Hotpoint Aquarius WD640 Front Load...
u might have a blockage in the drainpipe. hope it helps. good luck!
Jun 16, 2008 | Hotpoint Aquarius WD640 Front Load...
WD440 drying high heat and 0n/off light flashing
Just had the exact same problem and think I may have solved it. even turning power off didn't solve it. I think what happened was that the programme had been interupted while drying. I tried everything to get machine to work afterwards but only the following worked - while lights are flashing put back to the same time I had set to dry (60) in my case and turned the dial to M for dry high heat light goes off after a short while - leave for 5 mins then press off. machine will make a noise for a short while then stop.
If this happens then machine should be back to normal.
this is same for both posts I guess.
Feb 03, 2008 | Hotpoint Aquarius WD640 Front Load...
Not drying
Is it still under warranty? I've read that these machines are better left at the retailer...
Dec 08, 2007 | Hotpoint Aquarius WD640 Front Load...
WD440 programme m
This sounds like a faulty pcb and/or inlet valve. see links for prices.
meatballs77 - If you have warranty (the machine is less than 1 year old which yours is) or paid for extended cover then call hotpoint to replace... Hotpoint should be able to fix this - this should be free. call 0870 4422 510
Rememer parts are free up to five years - but there is a £90 callout fee after the first year.(unless you extend the full warranty)
Nov 07, 2007 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius wd440
Find the pipe that comes out of the bottom of the drum, this may contain coin, muck, etc. Clean. This pipe leads to the small pump that draws the water out. If your clean of the pipe does not work the machine.......there could be a fault with your pump..........which you can/cannot clean.
Dec 29, 2006 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
792 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
