Question about Symbol Motorola MC9090 Mobile Computer
Symbol MC9090 unable to connect to wireless network...
I have a Motorola Symbol MC9090. I am trying to get it to connect to our wireless network. It picks up the signal, but cannot connect. I have checked and rechecked the settings (WEP key, IP Address, WIFI is turned on, etc.) and everything seems ok. I brought it home, and was able to connect it to my home network without any problems. Any suggestions?
  • 3 more comments
  • TheFishGuy
    TheFishGuy Jul 29, 2009
    DHCP is not enabled in the router. We are using static ip addresses, so the MAC address of the RF Gun shouldn't need to be coded into the router.
  • TheFishGuy
    I've double checked the IP Address to make sure that 1) It is correct, and 2) It is an available address, and it is both. When I attempt to ping the RF Gun, I get a "Request Timed Out".
  • TheFishGuy
  • TheFishGuy
  • TheFishGuy
    I've gone through all of these already. That's why I'm at a complete loss. I've even done both a cold and hard reset of the RF Gun.
    President:
  • 1,383 Answers
Check in your router MAC security
if in your router MAC security is enabled then only those can connect whose MAC addresses are in allow list in router.
you can access your router with following link
http://192.168.1.1
or
http://192.168.1.0
for belkin router
http://192.168.2.1
type user name as "admin" and password as "admin" or blank or "password
then go to wireless advanced security then check MAC security if enabled then add your moto MAC in allow list.
Let me know .
Posted on Jul 29, 2009
  • kishor
    kishor Jul 29, 2009
    so check your RF gun ip addrsses and check in router test ping tool that you can get reply from rf gun ?
    Please rate my solution if you think that i give you technical info.
    Thanks sir.
  • kishor
    kishor Jul 29, 2009
    ok
    check your ip addreses of rf gun
    check that subnet mask is same as your router subnet mask.
    And set gateway ip in your rf gun is your router ip adrese.
    Also then try to reset your rf gun to defaults then set again ip net mask and gateway.
    Thanks.
How to change host on mc9090
Wireless Local Area Networks (WLANs) allow mobile computers to communicate wirelessly and send captured data to a host device in real time. Before using the mobile computer on a WLAN, the facility must be set up with the required hardware to run the wireless LAN and the mobile computer must be configured. Refer to the documentation provided with the access points (APs) for instructions on setting up the hardware. To configure the mobile computer, a set of wireless applications provide the tools to configure and test the wireless radio in the mobile computer. The Wireless Application menu on the task tray provides the following wireless applications: • Wireless Status • Wireless Diagnostics • Find WLANs • Manage Profiles • Options • Enable/Disable Radio • Log On/Off Tap the Signal Strength icon to display the Wireless Applications menu
pg 1-13,
Download manual
Apr 07, 2015 | Symbol Motorola MC9090 Mobile Computer
How do I get Symbol / Motorola MC9090 wireless settings to be
This is an old post but I'll give my solution anyway!
I anticipate that you're not exporting the connections:
Open the Wireless Menu icon on the task bar (Close "Manage Profiles" if it is open, select "options".
Select from the drop down "Regulatory" and select your country of operation (e.g USA), de-select "Enable 802.11 d", click Save.
Select from the drop down "Export", click "Export Options", click OK top right, click "Export All Profiles", click OK top right.
Now if a cold boot is performed the device will retain the added network profiles.
Cheers!
Apr 27, 2012 | Zebra Symbol Technologies Mc9090 Moble...
Hi, I just bought a set of 5 used symbol ppt8800,
It seems that the Wireless features, like Wlan and Bluetooth are optional features.
To find out what kind of connectivity is availble, hit start, settings, and then from the bottom, connections.
Take a look under network cards tell me what you got listed there and also see if you got Wireless manager or similar available there?
Oct 22, 2011 | Symbol Motorola PPT8800 Wireless Portable...
I cannot set the static IP for my MC9090. I went into Network Connections and have tried to Specify a valid IP address, Subnet and Gateway. I press ok. Then when I run cmd, I then type ipconfig and it...
Hi Jim,
I remember having the exact same problem when I first used the MC9090. It works on such other devices like the Datalogic Viper, but not the MC9090.
The IP is set within the wireless profile.
On the radio icon in the task bar select Wireless Profiles. This box then holds all your wireless profiles, including the default Motorola "out of box". Hold down the stylus on the screen and select "Add New" follow the prompts. When you get to IP Address from the pull down menu select static and then next this will take you to another screen where you can add your details.
Now you want to make them persist through either a cold boot or when the terminal has been left without a battery for a substantial amount of time.
This can be done 2 ways. When the profile has been set up highlight it by holding down the stylus on it and from the menu select export. This saves the registry key to the Application folder; a folder which persist through a cold boot. When it does cold boot it takes all the registry keys from the Application folder and builds 1 complete key.
The other way is to close the WLAN profile and selection options, from the pull down menu select export and save all profiles.
Hope this helps.
If you need any more help then please do not hesitate to contact us:-
http://www.biastechnology.com/
or TEL 01202 620955
Jan 14, 2010 | Symbol MC9090 Barcode Scanner
MC7090 showing WIFI unavailable
Check that the radio is switch on. This can be either done Using the wireless manager or by clicking teh radio symbol with red cross and and then [Enable Radio].
Failing that try a warm boot.
Failing that try a cold boot.
Failing that try reinstalling the operating system.
If that doesn't work contact us and we'll see what we can do.
helpdesk@biastechnology.com
Aug 27, 2009 | Symbol MC9090 Barcode Scanner
Windows Mobile Symbol Find WLAN error
Warm boot the MC55 if that doesn't help then cold boot it, if that doesn't help then reload the Operating system, if that doesn't fix it then send it back to Motorola for a warranty repair.
Jun 02, 2009 | Symbol MC9090 Barcode Scanner
Connecting to the internet
Hi there, this one might help since the OS is Windows mobile 5. the settings on your handheld might be quite different but still this may work. Please turn on wi-fi. There is a small icon below for wireless simply tick that and it will turn on wi-fi. Once you turn it on it will detect available wireless networks or you may simply go to Start menu and select settings. Go to connections and select network. It will give you available wireless networks. If prompted for the pass key or encryption, use the encryption set to the wireless network you're trying to connect with. Once you input the correct key you should be good to go.
Hope this helps
May 15, 2009 | Symbol MC9090 Barcode Scanner
Blue light flashes on the ws2000
You can try to connect to it through the DB-9 serial port on the front (you need a null modem serial cable). The CLI interface isn't very intuitive but if you can connect this way you might be able to reset it to factory defaults or reload the latest firmware. If not then get a new one.
Jan 16, 2009 | Symbol WS 2000 Wireless Switch (WS2000)
Connect MC9090-G to an Intermec 2100 Access Point
Make sure that the ESS ID and security features match the ones on the AP.
Also, from the MC9090, you will need to click on the radio icon, select options and in the top drop down menu, choose regulatory. select the country where you are and uncheck the box named enable 802.11d.
This should have the terminal connected on to the network.
Jul 11, 2008 | Symbol MC9090 Barcode Scanner
Symbol Motorola MC9090 Mobile Computer Logo
11,046 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
pkwc
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
