Question about IBM Lenovo ThinkCentre M55e PC Desktop
When start button is pushed, power on light flashes on/off.
After pushing power button, power light flashes on/off at 5 second intervals but unit will not start. Prior to this it did run for several days, but then stopped sudeenly. Managed to get it restarted and PC Doctor gave it a clean bill of health on reboot. Subsequently it will not start at all.
  • 23 Answers
Try swapping out the power supply, ibm usually has them **** out every now and then, other than that make shure your heatsink is clean and that all your vents are clean and unblocked
Posted on Jul 29, 2009
How to reset a service interval indicator on a 2003 mini one
Resetting Oil Service Light on your 2002 - 2006 Cooper and Cooper S Hatchbacks, and 2005 - 2008 Cooper and Cooper S Convertibles:
1) Press and hold the trip button
2) Insert key and turn to position 1
3) Watch for RESET to appear
4) Release the button, then press & hold it again
5) Wait for the RESET to flash
6) Release the button, and then press & release (once only)
7) Service interval should then be reset to next interval
If that didn't work, try this:
1. Push the Trip Button
2. Turn ignition key to position 1 and 51A will appear to left of mileage
3. Release trip button
4. Wait 3 seconds
5. Push trip button
6. Wait (5-8 seconds) for RST to appear in left corner
7. Release trip button
8. Push trip button
9. 15000 will appear as new service interval
10. Release trip button
Or this:
1. Press and hold the trip odometer button.
2. Insert car key and turn it to the fi rst position (not the second position).
3. You will see 51A come up in the trip odometer area.
4. Release, then press and hold again.
5. Watch for the word "RST" to appear on the Odometer indicator.
6. Release, then press and hold again.
7. Wait for the "RST" message to fl ash.
8. Release, and then press & release (once only).
Jul 01, 2014 | 2004 Mini One
I dont know how to pull the codes on a 1993 volvo
Volvo Code Retrieval Accessing Trouble Codes 89-93 models (and later non-turbo/non-OBDII models)
Fuel Codes Locate the diagnostic unit behind left strut tower and remove its cover.(see image) Connect selector cable to socket #2,which tests the fuel codes. Turn the ignition switch to the ON position(engine not running). Enter the diagnostic mode by pressing the push button on the diagnostic unit for at least 1 second, but not more than 3 seconds. The red LED light will start to flash,count the number of flashes in 3 flash intervals. The flashes will be seperated by 3 second intervals.Make note of all codes. If no codes are stored,the LED will flash 1-1-1,which means the fuel system is operating correctly.
Ignition Codes To access the ignition codes,follow the above procedure,but with the selector cable connected to the #6 socket on the diagnostic unit.
NOTE:Turbocharged models may have seperate codes for the turbo system and are accessse by hooking the selector cable to the #5 socket.
Rate this.
Dec 28, 2009 | 1994 Volvo 940
Kenmore Ultrawash dishwasher Model 665 15810000. Originally "water heating" light was flashing and no water in dishwasher. Replaced water inlet valve. Turned power back on, normal wash light goes on...
lock light is locking the panel push this child lock button for 3 sec and see if it un locks . then try it again .. may have a pannel out. mm
Dec 06, 2009 | Washing Machines
Blue flashing light on lumipure air purifier
I read on another site to hold the power button down for 5 seconds. Dont know what the blue light is but this stopped it from flashing!
Jun 13, 2009 | Sharper Image Ionic Breeze GP SI730 Air...
Dell XPS400 No Start!!
If you fan isn't turning like it should, it is definitely a power supply issue. Go out and purchase a power supply with 250-300 watts...thats a good standard wattage!!
May 12, 2009 | Dell XPS 200 PC Desktop
How do i reset my kilometer gauge after changing oil or does it reset to 0 automaticly
Resetting Oil Service Light on your 2002 - 2006 MINI Cooper and Cooper S, and 2007 - 2008 MINI Convertibles:
4. Wait 3 seconds
5. Push trip button
8. Push trip button
Or this:
5. Watch for the word “RST” to appear on the Odometer indicator.
7. Wait for the “RST” message to fl ash.
Apr 12, 2009 | 2003 Mini Cooper
Mini dash
4. Wait 3 seconds
5. Push trip button
8. Push trip button
Or this:
backbutton0001.gif Article Date: Jan 02, 2007
Car Accociations: NEW_MINI
Hits: 16731
Jan 13, 2009 | 2002 Mini Cooper
Kenmore Oasis Elite---110-27086601
This error only shows in diagnostic mode, with power off choose any buttons except stop and power, press in intervals 5 seconds on and 5 seconds off until 88 appears and all light light up. If the user panel is faulted F 2 will flash in the display, press the same button you used to start diagnostics to jump to the next error code and once through 88 will flash and diagnostics will start. Sometimes once F2 flashes and the machine has not been repaired it will stick at that mode.
Aug 07, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Magnavox codes
Try holding down the the code search button until the LED lights.. Then push the TV button.. with the tv on Start pushing the power button at one second intervals until the tv turns off.. Then push the enter button. that should find the correct code.
Jul 18, 2008 | Philips Magnavox 27MS343S 27" TV
Flm-3201
my polaroid model #3200  does'nt come on!  the light goes from red to blue and nothing,the picture stays black with no flashing or flickering
Apr 01, 2008 | Polaroid FLM-3201 Television
IBM Lenovo ThinkCentre M55e  PC Desktop Logo
464 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
