Question about Brother HL 5250DN Laser Printer
When printing envelopes, they feed in about 1/3 of the way and then stop. They worked before but are now having issues.
  • joshua_mulli Aug 04, 2009
    It feeds about a forth of the envelope past the roller, the ones used to pull the paper in. We have ordered replacement parts for the roller hoping it will fix it.
  • 30 Answers
Hi, try it again and look where the envelope stops, do not remove it. Look at the farthest the envelope went in for an obstruction ei. paper, lever, rollers or guide ramps that could snag the end of the envelope.
Posted on Aug 04, 2009
Why brother mfc 7360n printing envelopes wrinkle paper
Do U mean wrinkle the envelopes?,,,,I can solve some MFC-9840-CDW issues, but the 7369N is a guess. Read your manual or do a google search.....There maybe a setting in the 7360N that adjusts printing for card stock and envelopes....
Jul 01, 2014 | Brother MFC-9840CDW Laser Printer
My HP CE399A does not automatically feed the envelopes on my HP Laserjet 600 M603 printer...why?
Sounds like it needs to be set in your software program. For example, in Word, Tools> Envelopes and labels> Envelopes> Options> Feed From: (and select the envelope feeder in there). Sounds like its set for manual select or Default.
Dec 20, 2017 | HP Hewlett Packard CE399A 75-sheet...
I can't get anything to print from tray 1, the manual feed. I'm trying to print envelopes and they keep printing on 8.5x11 paper from tray 2. If I put envelopes in tray 2 it won't print
Have you already tried this? After you click print and select your printer, click properites and select your paper from 8.5x11 to Envelope.
Jun 25, 2012 | Xerox Phaser 8560MFP Laser Printer
I would like to feed and print an 6" x 9" envelope
Print 4" x 6" photo images in normal mode in about 60 seconds; up to 17 ppm ... 3/4 Envelope. 9 Envelope. A4. A5. B5 Envelope. C5 Envelope. DL Envelope. 6 3/4 ...lexmark.com/lexmark/product/home/15/...?tabId=1
Dec 04, 2009 | Canon PIXMA iP5000 InkJet Photo Printer
My Imagistics Model im2520f won't print envelopes
Printable envelope
[ Manual-related ] Field Remedy There are 7 kinds of envelopes printable:
Yougata 2 (114mmx162mm), Yougata 4 (105mmx235mm), COM10 (4 1/8x9 1/2inch), Monarch (3 7/8x7 1/2inch), DL (110mmx220mm), ISO-C5 (162mmx229mm) and ISO-B5 (176mmx250mm)
For important points when loading envelopes on the tray, refer to Reference Guide, Making Prints Using the Stack Bypass in Chapter 1 Before You Start Using This Machine.good luck mate,pls rate me!!!!!
Sep 18, 2009 | Office Equipment & Supplies
We're trying to print envelopes using the Samsung CLP300.
Got the 300N and encoutered similar issues. Try making lifting the ends of the envelopes up so they're slightly out of the tray at the feed end, this seemed to work for me. (Only tried it with about 10 envelopes, dunno about more).
--Rob
Mar 17, 2009 | Samsung CLP 300 Laser Printer
How to print envelopes
Open the manual feed tray door (that is the door on the front that has the "Brother" logo on it. Narrow the feed tray guides to filt your envelope. Envelopes feed it with flap side up and to the left.
Dec 30, 2008 | Brother MFC-8660DN 5-in-1 Laser...
Print job will not print from the manually feed tray unless I select the Go button for it to process
Table 3-7. Paper Handling Menu
Item Values Explanation
ENVELOPE FEEDER
SIZE=COM10
For supported paper sizes
see page 1-12.
This item appears only when the
optional envelope feeder is installed.
Set the value to correspond with the
envelope size currently loaded in the
envelope feeder.
ENVELOPE FEEDER
TYPE=PLAIN
For supported paper types
see page 1-12.
envelope type currently loaded in the
envelope feeder.
TRAY 1 MODE=
FIRST
FIRST
CASSETTE
Determine how the printer will use
Tray 1.
FIRST: If paper is loaded in Tray 1,
the printer will pull paper from that
tray first.
CASSETTE: A paper size must be
assigned to Tray 1 using the
TRAY 1 SIZE option (the next item
in this menu when TRAY 1
MODE=CASSETTE). This allows Tray 1
to be used as a reserved tray.
TRAY 1 SIZE=
LETTER
see page 1-12.
This item appears only when TRAY 1
MODE= CASSETTE. Set the value to
correspond with the paper size
currently
Mar 12, 2008 | HP LaserJet 4350 Printer
Can't print envelopes
Solution Title: How to print on COM10 envelops from the Bypass tray (PCL6) using a Windows 2000 O/S Resolution/
Solution
thumbsup.gif Fixed! thumbsdn.gif Did not fix. Resolution Role: Fix
Critical Message: The Envelope must be placed in the Bypass Tray face down (flap side up) and Long Edge IN. In Microsoft Word (Word 2000)
    1. Under the Tools tab, select Envelopes and Labels.
    2. Enter your Delivery and Return addresses.
    3. Click on Options
    4. Under Envelope Options; [Envelope size], select Size 10 (41/8 x 91/2 in)
    5. Under Printing Options, select Portrait (LEF) - Long Edge Feed
        • As Feed from, select Tray 5 (Bypass)
    6. Click <OK>
Within the WorkCentre Pro 123/128 print driver
After opening up the print driver [<Start>, <Settings>, <Printers>, double-click on the WCP 128 PCL6 driver], click on Printing Preferences under the General tab.
  • Under the Paper/Output tab
Set the following features as follow:
    • Job Type: Normal Print
    • Paper Size: COM10
    • Output Size: Same as Paper Size
    • Image orientation: Portrait
    • Image Rotation: OFF
    • 2 sided Print: 1 sided Print
    • Stapling: None
    • Output destination: Center Output Tray
    • Offset Stacking: None
  • Under Tray/Layout
  • Set Paper Source to Tray 5 (Bypass)
  • Click on Bypass Tray Settings
    • Paper Type: Heavyweight (1 or 2)
    • Feed orientation: Portrait
  • Click <OK>
  • " on Specify Paper Type and select Heavyweight (1 or 2)
  • " (Apply> and <OK>
  • " <OK> again
In Microsoft Word under Envelopes and Labels, Click <Print> to send the information to the printer.
Note: This setup represents one way of printing envelopes. Other ways setting up some features in a different manner will work as well.
Solution v1.3.20.0 312637.How to Print on COM10 Envelops From the Bypass Tray (PCL6) 2006-04-05 21:57:29
Nov 02, 2007 | Xerox WorkCentre PRO 128 Copier
Envelope printing
did you go to the menu in the printer and set it in yhe paper options to envelope? You MUST also set it in the PC.
Go to
1- file
2-Print
3-right click on your printer
4-Properties
5-Device settings
6- set tray 1  to envelope
Oct 12, 2007 | HP Color LaserJet 2600n Printer
Brother HL 5250DN Laser Printer Logo
229 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
