Question about Garden
Drive belt problem
I have a 42 in. 21hp troy bilt that keeps kicking off the long drive belt. The small belt seems fine but the big one keeps slipping down on the var. speed pully and I have no speed and it tears up the long belt...;
  • 61 Answers
Ck var speed pulley for movement on middle part
of pulley
Posted on Sep 06, 2009
I have a troy bilt 42 inch 17 hp lawn tractor. The problem is when I cut grass and i get in some thicker grass the blades turn off then I back out the blades restart. The engine never bogs down
One or more of your drive belts is in need of adjustment or replacement, maybe. Possibly, your electric (or manual) PTO clutch could also be adjusted. You do have the spring tensioner on the deck engaged, right? You say the engine doesn't bog when this happens so I am inclined to think "clutch" and/or "PTO belt" to the deck and/or the "deck tensioner" are the things to check.
The tensioner will be the easiest, it is a handle on the left side ON the deck. Has a BIG spring on it. Make sure it is engaged.
Is yours a Troy Bilt manufactured in Troy New York or is it another manufacturer (MTD?). Troy Bilt is actually out of business, having sold the Troy name to a variety of makers depending on the model line. I don't have the run down on who makes what any more (tillers, chippers, mowers, blowers, trimmers, etc.), but Troy Bilt of Troy, NY is no more. :-(
I have a 16 HP Troy with 42 inch deck driven through a electric clutch. I also have a "grass pump" on my deck. Important maintenance tips: Keep the bearings greased, keep the deck clean underneath. The belt on the deck should have the tensioner released when you are NOT mowing. Keep the blades sharp and in good repair. Mow with engine at full speed. When you get to areas of heavy growth, slow the tractor down (hydro drive) or reduce to a lower gear (gear drive). NEVER adjust speed using the "clutch" (hydro drive or gear drive). When you engage the blades (electric or manual) always have the engine just above idle, bring the engine speed up slowly to preserve the belts and reduce stress on all components.
I am sure this is the fix for your trouble. If there is anything else or if I missed the ball, please let me know and we will go further.
Thanks for your question @ FixYa.com
May 30, 2011 | Troy Garden
Drive belt is slipping when under load. How do you tighten the belt. thanks, Ted Troybilt Horse rear tine tiller
hi there, ive been doing a bit of head scratching over this one as i needed to check my facts. i think the belt has a automatic spring loaded adjuster so it sounds as if you need a new belt for it.
good luck
iain
Apr 30, 2011 | Troy-Bilt 21AE682L766 Big Red 10 HP...
Drive belt slipping, how to adjust
Where the lever mechanism for forward and reverse works down close to the engine mine has a bolt that you loosen and adjust the slide up and down to allow for more movement of the housing.
May 15, 2010 | Garden
My troy-bilt 8.5 horse 26 inch wide snowblower wont move anymore.
Take the belt cover off that covers the drive pulley on the engine. You should only have to loosen two bolts. Inspect the belt to see what it looks like. I am not sure if it drives a gear box or if it turns a friction wheel that drives the wheels. If the belt looks good check for shear bolts that might have sheared off and replace them.
Dec 19, 2009 | Garden
I have a troy bilt front wheel drive mower, model
ya the trans is trying to go out and thay look up thay do that all the time
Nov 02, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Had to change the small drive belt that drives the transmission on a Troy-Bilt 42'' 17.5 HP Pony mower. Now it only has one speed forward, slow!! Didn't touch anything-got the OEM belt replacement. Any...
You need to adjust the gas pedal. Info should be in the owners manual. I have it in my Troy Bilt Bronco manual. It say to adjust it in my book after replacing the trans drive belt. Maybe that will help.
Aug 17, 2009 | Garden
Troy Mower Belt Slippage
If you have an tension adjuster on the handle loosen up until you can slip it back on. If thats not enough remove the spring at the tranmission.
Jun 10, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Changing Drive belt On Troy Built Tiller
You have to remove the engine (4 bolts, no big problem), then remove the bolt in the center of the pulleys, then remove the pulleys. Slip the belt(s) (2 if you have the Super Bronco model) onto the pulleys, re-attach the pulleys with the bolt, re-mount the engine, and you're home free.
May 20, 2009 | Mtd Troy-Bilt Bronco OHV Tiller
Replace drive belt 2004 troy bilt garden tractor 54'' Big Red
Not an easy fix. There are likely 2 belts which should be replaced as a pair. Engine pulley must be lowered to remove long belt. Pay special attention to belt routing. Most times small belt requires removal of transmission pulley. Good Luck.
May 15, 2009 | Mtd Garden
Garden Logo
264 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
