Question about Whirlpool Kitchen Ranges
Model GERC 4110 PS. Issue is that when using the oven the oven vent causes moisture to enter the electronic controls which results in the complete shutdown of the Range, all functions. Range cannot be restarted until moisture dries up, usually about 1 to 1.5 hours. Paricularly annoying when baking as it results in the loss items being baked. Range is less than 5 years old. Problem has been in existence for about 3 years and reported to selling dealer without response from them. Can you suggest how to repair? Thank you.
  • 126 Answers
SOURCE: Oven stopped 5 to 10 minutes after pressing START
sounds like a wiring problem check your power source
Posted on Dec 10, 2007
  • 262 Answers
SOURCE: BAKE MODE NOT WORKING ON MAYTAG STOVE
the gas valve has gone bad change the gas valve and the glow bar (igniter) at the same time.or you WILL have problems in the future
Posted on Dec 18, 2007
  • 1314 Answers
SOURCE: GE Profile XL44 Spectra gas oven
try to hold down the light switch on the door set it up for another cleaning hit start when oven clean door lock showes hit cancel if that doesnt work try unplugging it for three min fyi the doors can take up to an hour to un lock after cleaning its so it dont burn your face off from the intense heat after cleaning some take 2
Posted on Feb 14, 2008
docjohn174
  • 943 Answers
SOURCE: Oven or broil does not work
hi thanks for the question . the control board seems to be defective the clicking noise is the relay .but not letting power to the elements thanks the appliance doc
Posted on Sep 28, 2008
MNTECH
  • 1543 Answers
SOURCE: JGBP33 BAKE IGNITOR
You did not post a complete model number, but this should help:
Take racks out of oven. Remove two screws at the very back of the oven bottom. Lift back side of bottom up and back a bit to remove oven floor. Remove flame spreader (one nut at center). ignitor is at the back left of burner, most likely a WB2X9154 (round style) ignitor. The entire burner can be removed rather easily at this point if you remove the two screws at the front and disconnect the ignitor wire (if you wish to have easier access to ignitor mounting screws.)
Posted on Nov 23, 2008
JTP85 microwave shuts completely off with a blank readout.
Your magnetron is overheating, and its attached thermostat is doing its job to protect the magnetron by shutting off the power to the oven until it cools back down to a safe temperature.
An overheating magnetron can be due to:
  • operating oven without cover(s) in place
  • wrong magnetron installed in oven
  • an old or otherwise failing magnetron
  • cracked magnetron magnet
  • improper power line voltage (should be 110-125VAC)
  • foods low in moisture (popcorn & bacon, e.g. - add 1/2 cup of water in rear oven when cooking such foods)
  • failed or inoperable cooling fan or hood vent exhaust fan
  • deteriorating foam weatherstripping seals in air ducts or on outside cover
  • blocked air vents (dust, animal nest debris, insufficient free air space behind & around oven, etc.)
  • clogged or greasy charcoal filter or grease filter
  • blocked duct in hood vent exhaust
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, and it is very helpful when troubleshooting, testing, and locating components.
dee77f7.jpgAt our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Accessing some parts may require you to pull the oven from the wall and remove the cover.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Aug 21, 2012 | GE JTP85 Electric Double Oven
Tip
One For All URC-4110 Reassign Key Model: One For All URC-4110 Would you like...
Would you like to re-assign one of the function buttons on your One for All URC-4110 Universal Remote to control a different device?
If you would like to program the CBL/SAT button to control a DVD player, here are the steps:
  1. On the remote, press and hold SET until the LED blinks twice, then release SET.
  2. Enter 9 9 2. The LED will blink twice.
  3. Press DVD/VCR once.
  4. Press CBL/SAT once. The LED will blink twice. The CBL/SAT key is now ready to be set up to control your DVD player.
I hope that helps.
_______________________________________
One For All URC-4110 Manual
One For All URC-4110 Code List
One For All URC-4110 Code Entry
One For All URC-4110 Code Search
on May 30, 2010 | Televison & Video
Tip
One For All URC-4110 Code Search Model: One For All URC-4110 To program your...
To program your One For All URC-4110 universal remote control to operate your TV, the remote has a code search function.
To search for a code for your TV:
  1. On the remote control, press TV once.
  2. Press and hold SET until the LED blinks twice, then release SET.
  3. Enter 9 - 9 - 1.The LED will blink twice.
  4. Aim the remote control at the the TV and slowly alternate between pressing POWER and TV. Stop when the TV turns off.
  5. To lock in the code, press and hold SET until the LED blinks twice, then release SET.
I hope that helps.
My kenmore model 970(frigidaire) electric range displays F10 fault when i use the oven shutting down the oven and beeping. Help me please
Hi
Thanks for using FixYa. F10 error indicates that the Electronic Range control (ERC) has gone bad and should be replaced. However, before replacing it you can take the screws out and then blow some air with the help of hair dryer so that if there is any moisture it blows it off. If still the issue is not resolved then replaced the ERC. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 22, 2010 | Frigidaire Ovens
My microwave does not vent out moisture well and leaves a lot of moisture accumulating into water at the bottom of the oven and on the door and sides. The vent is not blocked. It just doesn't clear...
The fan that cools the magnetron also helps exhaust water vapor. Does the fan sound as strong as it used to? Is the vent at the back of the microwave clean? Sometimes lubing fan motor bearings with light machine oil will speed up the fan. You would have t remove the cover to gain access.
Jun 20, 2010 | Panasonic NN-H504WF Microwave Oven
Tip
One For All URC-4110 Code Entry Model: One For All URC-4110 To program your...
To program your One For All URC-4110 remote control to operate your TV you can use the direct code entry function.
To enter for a code for your TV follow these steps:
  1. Turn on your TV.
  2. On the remote, press the TV key once.
  3. Press and hold SET until the LED blinks twice, then release SET.
  4. Enter the first four-digit code from the code list. The LED will blink twice. If it does not blink twice, go back to step 2 and try the same code again.
  5. Aim the remote at the TV and press POWER. The device should turn off. If it does not turn off, repeat steps 2 through 5 with the next code in the list.
I hope that helps.
Tip
I hope that helps.
on May 30, 2010 | One For All URC4110 Remote Control
My dryer does not completely dry the clothes when we use the dryness sensing option. It does fine when we use the timer. Is there a moisture sensor that I might be able to replace ?
Dryers with electronic control and auto dry cycle indeed use moisture sensors for the auto drying to work. The problem is absolutely associated with the failure of the moisture sensors, especially when the timed dry cycle works fine. Either the connection of the sensors to the electronic control is loose or the sensors are covered with thin film that prevents it to sense the proper moisture content of the clothes.
Clean the moisture sensor bars thoroughly and make sure its connections are snug fit. Reseat the connections several times to clean off dirt and corrosion build up in the connectors and terminals. The last thing to look into is the electronic control if all resort fail to address the issue, that is, clean sensor bars and good terminal connections.
Indicate the exact model number of the dryer should you need further or more specific troubleshooting and repair advice.
Jun 12, 2010 | Estate TEDX640JQ Electric Dryer
Tip
I hope that helps.
Tip
  1. Turn on your TV.
I hope that helps.
Kitchen Ranges Logo
124 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Ismael Rodriguez...
Sal De
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
