Question about NEC Lands Phones
How do i lighten the display on my NEC phone - NEC Lands Phones
  • 1 more comment
  • kathy470 Jul 29, 2009
    The display on my 22b hf-DISP ASPIREPIONE-BK phone is black. I know there is a way to lighten and darken the display screen. The screen is currently dark. What is the correct sequence of buttons to lighten the screen so I can see the numbers
  • James Trageser
    James Trageser May 11, 2010
    What is the Model of your phone? I know it's an NEC, but what is the Model Number?
Display name not mine, how do i change it?
Here's a link to the individual steps:
http://www.telephonesystemsdirect.com/necdsx/nec-dsx-knowledge-base/changing-the-name-on-a-nec-dsx-22b-display-tel/
Dec 16, 2013 | NEC DSX 22 Corded Phone
Our phone is a NEC DTerm 80, but looks a lot like ...
The Display can be swapped.... if you can find one.
Otherwise no programming is retained in the telephone. Swapping phones will not loose any data programed to that jack/Extension number
May 21, 2010 | NEC DTH-8D-1 Corded Phone
Need Replacement LCD/Displays for NEC DSX 22B phones
You can buy replacement NEC DSX telephone system LCD screens here: http://www.nec-dsx.com
You don't have to buy whole new telephones
Jun 16, 2009 | NEC Dterm DTP 16D-1 Corded Phone
The contrast of my LCD display has gone very dark. How do I lighten it back up.
With the phone turned off, use the volume up/down key to increase/decrease the display contrast.
Apr 09, 2009 | NEC Dterm DTP 16D-1 Corded Phone
How to change time on NEC Electra Elite IPK? I
You have to be on the root phone or "first phone".
To check various phones -Hit {feature} 4.
Should display 100= TEL 01. Once on the first phone then use {feature} 9 #.
Time will flash at top of display and can be adjusted.
If you are not on the first phone you will get error at the top of the display. Leave the hand set on the hook.
Mar 11, 2009 | NEC Electra Elite DTU 16D-2 Corded Phone
Trying to change the name on the display on the phone
Dial 700>dial your ext #>enter name>press Hold & press Speaker
Feb 13, 2009 | NEC Dterm DTP 16D-1 Corded Phone
NEC Dterm 80 LCD display is defective, where do I get parts? How difficult is it to change?
The common thing on this style of phone is the silver ribbon cable that connects the display to the main circuit board comes loose after being dropped or knocked around and needs to be reinserted. You will need to open up the phone to do this. If this is not the solution then you will either need to purchase a used phone, send it in for repair or use another phone to take parts from.
Dec 08, 2008 | NEC Dterm DTP 16D-1 Corded Phone
Can't find caller id function on NEC ETW-16DC-1 BUSINESS PHONES SYSTEM
You have to make sure the phone system you have has CID cards in it. What kind of card is in the Electra phone system.
Sep 08, 2008 | NEC ETW 16DC-1 Corded Phone
Display Problems
The only way to darken or lighten the display is to use the arrow keys when the phone is idle. try unplugging the phone and plug it back in. If that does not work you need to replace the phone.
Aug 04, 2008 | NEC Electra Elite 32D-1 Corded Phone
Lands Phones Logo
262 people viewed this question
Top NEC Lands Phones Experts
Craig Butler
Craig Butler
Oloyede Monsuru
ray gallant
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
