Question about Cisco 7920 IP Wireless Phone
IP 7920 & Asterisk
I have firmware problem. I'm trying to connect my phone with Asterisk. The connection is ok, but appears on the display strange symbols (euro) and if I make a call, after 10 sec it reboots. Now, where can I find a way to update my phone? I searched everywhere but I didn't find anything...only link with no file to download.My version of firmware is:7920.3.3-01-03 Please help me!Thank you
I believe I saw somewhere that the 7920 works best with the 4.02 version of firmware... only hitch is you can't get it unless you have a valid Cisco login with access to their voice stuff. You could see if your local partner could get it for you otherwise. Also, I think you need the cradle to upgrade the phone manually - otherwise you need a TFTP server set up and the proper keywords in the cnf.xml file. There is better info on voip-info.org about these sccp phones - god I wish they (Cisco) would release a SIP firmware for these things!
Posted on Jan 19, 2008
3COM 3100 entry phone, how to configure SIP
From Digium Mailing List:
3Com 3100 series phones do not support SIP with non-3Com systems. They have a basic boot loader which must download code from a 3Com NBX or a 3Com VCX system. If you don't have either of these, then you won't get runtime code on the phone, thereby making it impossible to use the thing with Asterisk.
Asterisk Users 3Com Phones
Mar 14, 2014 | 3Com Computers & Internet
How to connect a linksys 941 phone
SPA 941 is a pixel display phone. You can configure it to work with any IP Telephony server like asterisk easily.
1. Press "Paper" Button and press "9". You ll find yourself in network settings.
2. Configure IP address, Subnet mask, Default gateway.
3. Now enter http://ipaddress in your browser
4. Choose EXT1 menu on top
5. Configure the following
Proxy: Your server here
User ID: Enter the phone number (Mostly they are phone nos.)
Password: Enter the password / Secret
Note : depends on your server config you may need to configure some extra informations. Say SIP Port, Preferred Codec, Auth ID etc.
6. Save settings
7. Happy calling.
HTH
-Karthik.
Oct 19, 2012 | Linksys SPA941 IP Phone
Nbx 2101
You can't. The 1100 and 2100 series 3Com phones aren't SIP phones. Only the 3100 series phones can be used.
May 28, 2012 | 3Com NBX 2102PE IP Phone
Unable to wireless connect TP-Link TL-WR841ND to Motorola SBG900
DO any of these error conditions show up on the front panel display?
Front-Panel Lights and Error Conditions
Light Turns Off During Startup If:
RECEIVE The downstream receive channel cannot be acquired
SEND The upstream send channel cannot be acquired
ONLINE IP registration is unsuccessful
POWER The SBG900 is not properly plugged into the
power outlet
OR
Light Turns Off During Normal Operation If:
RECEIVE The downstream channel is lost
SEND The upstream channel is lost
ONLINE IP registration is lost
POWER The SBG900 is unplugged
If you rent or lease your SBG900 Contact your cable service provider.
If you own your SBG900 Call 1-877-466-8646 for technical and warranty support. Support is available
24 hours a day, seven days a week.
Feb 28, 2017 | Arris SURFboard SBG900 (49402201900) Modem
Can I use a CISCO IP 7941 phone, that has been on a company network, in my home? Should it just work by plugging in a telephone connection and using the appropriate power supply? Is there programming that...
Yes, there is programming which would need to be removed. However, you would need a cisco call manager($800) at home. Unless of course you have voip in your home. then you could just set it to DHCP I'm assuming and then it should just work!
Jan 14, 2010 | Cisco 7940 IP Phone
Visual C++ runtime error message
Hi.
It would be best to download a new installer and reinstall the program.
Jul 24, 2009 | Linksys CIT310 IP Wireless Phone
Want to unlock Siemens Dual Phone DP450
How To Unlock Tesco Internet Phone Siemans DP450
Unlock your Tesco DP450 IP Phone to use this with other VoIP providers.
Gigaset Communications have created a process that enables Tesco Internet Phone subscribers with Siemens Dual-Phone DP450 to unlock the phone from the Tesco Internet Phone service. This will enable the phone to be used with other Internet Telephone services. This follows the recent news that the Tesco Internet Phone service is to be ceased from April 26th, 2010.
This is an approved method for unlocking the Siemens Dual-Phone DP450 defined and released by Gigaset Communications, the original supplier of the phone to Tesco. If this procedure is not followed exactly your phone might not work anymore. In this case Gigaset Communications cannot accept any warranty claims.
Unlock procedure
Your Phone should have the latest released Tesco software version, else this unlock procedure will not work.
On your handset:
BASE > SETTINGS > SOFTWARE UPDATE
Select and press OK Enter the system PIN (0000) and press OK
The base station establishes a connection to the internet or a local PC.
YES Press the display key to start the firmware update. If no update is needed, this will be displayed.
To unlock the WEB interface of the DP450, you need to enter the following service code. Please use the exact code as is described below, else your phone will not work anymore.
SETTINGS > BASE 94762001 (Now "Eeprom" must be displayed)
Insert the following number sequence: 01778 06183 06191 Press OK to finish the programming. "Saved" must be displayed on the Handset.
Then release the phone to be able to upgrade it with the latest Retail firmware version.
SETTING > BASE 94762001 (Now "Eeprom" must be displayed)
Now insert this number sequence: 04850 04351 04864 Press OK to finish the programming. "Saved" must be displayed on the Handset.
After this procedure you can upgrade your phone to use the latest retail firmware version.
SETTINGS > BASE > SOFTWARE UPGRADE
Please Note: The firmware update can last up to 3 minutes.
Your Phone is by default configured to use the Internet Telephone service, if you want to change this to set the default to the land line you need to change this in the web interface from your phone. How to do this, download the Gigaset S450 IP manual from the Gigaset web-site URL: http://gigaset.com/uk/en/cms/PageCustom ... nuals.html
Regards,
Smith Online
Apr 11, 2009 | Lands Phones
I have nortel phone ip 2002 i want use for my own carrier i need to reset
1. Reset the phone by disconnecting and re-connecting power.
2. When the Nortel logo appears, press each of the four soft keys in sequence.
3. If no other configuration changes are required, press OK repeatedly until the “PC
Port? 1-ON 0-0FF
” option appears.
4. Press 1 to enable the PC Port or 0 to disable the PC Port.
5. Select OK to confirm the change.
6. Restart the IP Phone.
When the IP Phone is restarted, the firmware sets the PC Port status accordingly
Apr 20, 2008 | Nortel 1140E
Reseting to default Firmware!!!
If you are saying that there is a mistake with the firmware, you are in serious trouble. Firmware in most cases cannot be restored if there is a problem with upgrades or installs.
Apr 14, 2017 | D-Link DPH-80S
Cisco 7960G IP Phone Problem
Try to manually reset the phone - **#"Settings" (this will unlock the configuration) + Network + menu under number "33" - erase the configuration. Then the phone configuration will be erased. Also you can manually set IP address and TFTP server
Sep 11, 2007 | Cisco 7940G IP Phone
Cisco 7920 IP Wireless Phone Logo
595 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
