Question about Relisys RLT1720 17" LCD Monitor
Blank TV screen after switch on
When my TV is switched on the screen blanks out but the sound is ok
  • 372 Answers
The most common problem for this fault is the invertor failed.
The invertor is a HT circuit with 2,4,6,8, transformers on one or more of the tranformers will be open circuit.
Its relatively easy to replace but could be dificult & expensive to buy.
Posted on Nov 24, 2007
I have a 50inch LG TV that when switching between programmes the TV goes blank for a moment
Are you using cable and if so which company and box?
Dec 07, 2016 | LG Televison & Video
LG TV Doesn't Turn Normally
Contact the authorized service centre for LG. The fault sounds like strange.
Gopakumar Gopalan Google
Mar 27, 2014 | LG 42LE5500 42 in. TV
Bauhn 80cm tv model no. ATV-32HDC1N
Could be internal power supply failure.
Dec 25, 2013 | Televison & Video
Samsung le40d503f7w only displays samsung logo on screen for a few seconds after switching on and then goes blank
have the same problem, one or more of the flourecent light bulbs in the back panel got broken, looking for a supplier who may keep these bulbs in stock, or other wise will see if i can get a used one off ebay for spares.
Jan 24, 2012 | Computers & Internet
Have 21,6umc switch on after 3-6mins picture & sound go off with a click, just left with blank screen with
Power supply problem, intermittent voltage regulator ic after it heats up it shorts out internally and tv shuts off.
Nov 18, 2011 | Televison & Video
When i plug my xbox 360 hard drive in it makes the screen go blank?
If the A/V cable is not inserted far enough into the console, the console might not transmit images or sounds to the screen.
If the screen is still blank, try the next solution.
Make sure that the TV or monitor is set to the correct input for the console. Check the TV or monitor user manual to see how to configure the video inputs, or try to use the console on a different TV or monitor.
Make sure that the TV/HDTV switch on the cable is set correctly.
  • For standard-definition TVs with only the yellow connector plugged in, set the switch to TV.
  • For high-definition TVs or monitors with the red, blue, and green connectors plugged in, set the switch toHDTV.
Dec 29, 2010 | Microsoft Xbox 360 Hard Drive (120GB)
My Phillips 32pw8759 TV screen is Permanently blank
There might have been a power surge that had damaged the two units. For the reset, having the tv unplugged overnight should do it. If it does not work you may want to check the power supply of the tv for leaking capacitors or burned resistors or loose solders.
Aug 15, 2009 | Philips Televison & Video
Screen is blank but sound is there.
For the same solution. Your backlight and inverter should be replaced. %0.00 if you do it yourself.
Take care
Apr 20, 2008 | Philips 32PF5320A 32 in. LCD Television
Thomson 27" LCD TV 27LCDB03B
cannot be presise but at worse the lcd back light is failing or the supply to it . this is a job for a service engineer
Dec 02, 2007 | Thomson LCDB 03B 27 in. Television
Relisys RLT1720 17" LCD Monitor Logo
106 people viewed this question
Top Relisys Computers & Internet Experts
Samuel Konger
Samuel Konger
Level 1 Expert
Are you a Relisys Computer and Internet Expert? Answer questions, earn points and help others
