Even though my iPhone app will unlock the door using Siri I cannot access the Lock information to add a new code or look at existing codes or access the history. Also in the app it says that it is connected to the lock and I have not t reached the maximum number of codes.
Where did you buy the fone. Most reps will assist you, or point you in the correct direction for the answer. Never spoke to SIRI in my life, so sorry. Manual, MANUAL!!! Study it in a quiet room, & master it. Is the company for the locking device a local company? Or all in the I Phone? Seek them out.
SOURCE: nokia N80 "phone lock code"
Hi have you tried 0000 thats usually the code that is stored when phone is new failing that you will need to get a flash lead and nokia softtware that scans the phone and gives you all the codes allowing you to change them but this is expensive to buy.
I have alot of nokia software but not sure if it works through usb lead as i use from computer then into black box then into phone as i have this as it works on all makes an model of phone if it can be done through the usb lead i can tell you where you can get this software from ok just give us a shout back
SOURCE: Ipod Nano can't unlock volume lock
I assume your music is stored safely in iTunes on your computer? If so, just do a Restore on the iPod through iTunes to reset your iPod to the factory defaults. You will have to copy your music back, but the lock will be removed.
If your music is not saved on a computer, use software such as ephPod to get the music off - then do a Restore. (see: http://www.engadget.com/2004/11/02/how-to-get-music-off-your-ipod/)
Good luck.
SOURCE: iphone
goto this link click here this guy has been unlocking iphones since they were first relesed he has great guides and all the software needed this is how i unlocked mine.
SOURCE: forgot security lock/unlock code and now i cant use my phone at all.
call the phone comp they will eset i for you
SOURCE: unlock screen lock code number
Unlocking iPod
You can unlock iPod in one of two ways:
If you can't unlock iPod using either of these methods, you can restore your iPod to
factory settings. Please note that this will erase all data on your
iPod. Afterwards, you can add your music and data back to iPod.
If you want to change the primary computer that your iPod is
associated with, do this:
