Question about Nokia 6300 Cellular Phone
Hii i get some sound in key pad while pressing keys. did it effect anything if i press key long time and hard .wat the reason .and to take care of my mobile wat i should o.plz help me
    President:
  • 1,884 Answers
If it a click sound then it is the key being pressed in the wrong direction. It will effect the key in the long run if you press the keys hard. remember that it is electrnic and not mechanical. If you make the contact slightly the work should be done. Pressing it hard does not mean that you can force it to do something that it cant or does not want to do. To take care of your phone, keep it clean, use it gently, dont throw it around even on a soft surface, avoid humidit, if it gets wet remove the battery immediately and dry its insides with a hair dryer and use it only when you are sure that it is dry. Paste a scratch guard on its glass. Keep its battery fully charged, dont run it on low battery. If it gives you the signal for low battery, put it on charge.
Posted on Jul 29, 2009
Sound stuttering
Hi, This and a lot of similar keyboards have gold flashed pads on the PCB and the keys press one or two rubber caps, with conductive pads in them, down.
Clean the pads with isopropanol, (and nothing else) and it will be cured 99% of the time. If a few notes do not work, especially after heavy use, then the rubber caps can be replaced.
Taking the keyboard apart is long winded because of the number of screws involved.
The job its self is simple enough, but take note of the order things go in and where the screws go.
Hope this helps, Chris.
Jan 09, 2014 | Casio Music
Canon MP830 message re: waste tank full. How do I get to it to empty it or replace it.
The waste ink tank refers to may be a small well, surrounded by a
rubber ring, that sits under the cartridge when it is parked.
Place a cotton tip swab ("Q-Tip") over the hole to wick out the ink inside.
Oct 07, 2008 | Office Equipment & Supplies
Hii i hav lenovo s10 - 3 n its typing number when i am typing alphabets wat i do ? pls help
Welcome to Fixya
The number keys are locked. Press and hold Fn key then tap numlock key once. Test the issue again after doing the procedure.
Thank you for using Fixya!
Aug 07, 2011 | Lenovo S103 Netbook
How do I change the time on my Panasonic KXDT343?
1. From extension 101, press the PROGRAM key.
2. Then, using the number pad, dial *#1234 (Display shows SYS-PRG #).
3. Using the number pad 000.(Display: 000 DATE / TIME)
4. Press the SP-PHONE key (Display example:'93 Jan. 1 FRI).
5. Press the SP-PHONE key again (Display example: 12:00 PM 24).
6. Enter the new hour using the number pad.
7. If you need to adjust the minutes press the FWD/DND key.
8. Enter the new minutes using the number pad.
9. If you need to adjust the AM/PM press the FWD/DND key.
10. Press the AUTO ANSWER/MUTE key to select AM or PM.
11. When finished entering the new time press the AUTO DIAL/STORE key.
12. Press the HOLD key.
13. Press the PROGRAM key to exit programming.
Jan 11, 2011 | Panasonic KXDT343 Phone
Clean unable???
To reset purge counter
1) Enter machine maintenance mode (on MFC240C all four photo/copy/fax/scan lights flash in maintenance mode). Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
FAX models with numerical keypads: Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail to complete the correct key sequence within two seconds, press the Stop key to try again).
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the “up arrow” key four times to enter the maintenance mode).
2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine’s log information list (function code 80).
3) Press the Black Start key several times to scroll through the log information list to reach the purge counter. The purge counter is the 25th item in the list.
4) Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
5) Press the Stop/Exit key to return to the initial stage of the maintenance mode.
6) Press the 9 key twice to return to the standby state.
Mar 27, 2010 | Brother MFC 240C All-In-One InkJet Printer
Model 9109; above numeric pad there is three lights, right most light is a down pointing arrow with a line under it. It is lit and I can't turn it off, and I believe it is effecting my movement in excel.
On the 10 key pad you will see a Num Lock key. Pressing this will take the light off and restore the functionality you are talking about.
Take Care,
-WN
Dec 17, 2009 | HP 386209-001 Keyboard
Key pad 1
The key is dirty or stuck. Clean your keyboard with compressed air, and tap it firmly many times repeatedly. If no good you may need a new keyboard.
Aug 11, 2009 | Dell Latitude D600 Notebook
Can't answer calls key pad wont work to answer incoming calls
i think its ur key pad problem. it may be disconnected from ur circuit for many reason. 1st is under the button there r too much dust. so i cann't connect with ur pda circuit. 2nd is may be key pad has broken for pressing hardly or use many days. so u need to go tecnication . thanks
Jul 29, 2009 | Computers & Internet
NEED TO PRESS REALLY HARD TO INCREASE VOLUME. EVERYTHING ELSE WORKS FINE
as time goes buy more of the keys will fail to work, pressing hard on the keys may do some damage to the circuit board inside. you need to remove the batteries any and small screws you can see then pry the two haves apart remove any screws that hold the circuit board to the top half and remove the circuit board to expose the bottom of the key pad you will see a black conductor painted on the bottom of each key button, use a Q-tip dipped in alcohol to clean the black conductor on all the keys then do the same thing to the contact points on the circuit board then rub a pencil eraser over the same contact points on the cicuit board and reclean with alcohol again.
This should fix the problem but it will happen again, and at some point even this won't fix the problem and logitech won't let you buy a new key pad, and that is the point I am at now and for that reason I won't buy another remote from them, I expect more than four years out of this product good luck.
Nov 12, 2007 | Logitech Harmony 890 LCD Remote Control
Nokia 6300 Cellular Phone Logo
61 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
