Question about Garmin Forerunner 305 GPS Receiver
My garmin 305 only operates when connected to charger. It says that the charge is complete but does not operate when not connected to charger.
  • simon_fra375 May 11, 2010
    Not a solution but I have the same problem. It also will run on the base even when the power is NOT connected to the base. I am in touch with Garmin tech support but so far no solution. I have tried to reset the device but even the reset sequence doesn't seem to work.
Go to the garmin website and install the firmware update.
http://www8.garmin.com/support/download_details.jsp?id=1421
Took about 5 minutes to do the whole thing. Seems to work fine now. Didn't even loose data.
Posted on Jul 30, 2009
  • simon_fra375 Jul 31, 2009
    Short lived solution. It is back to the way it was. Seems to work OK for a while after holding Mode and Reset while hitting the power button. It then starts but as soon as the Up or Down or Enter keys are pushed it dies again.
    Works perfectly when sitting on the charging base with or without the power connected.
Garmin Forerunner 210W screen is blank. No charging symbol appears when it is on the charger.
Not sure if this is useful but double check that your charger connection to the Garmin is actually clean. I've had to clean the contacts for both my 405 and my 610 in order to make sure there was a solid electrical connection. Have you tried resetting it?
Feb 20, 2014 | GPS
Garmin 305 will not power on. When connected to charger screen says "battery charging complete" but will not power on. Advice?
two things... go to www.garmin.com and see if your gps qualifies for the battery recall. and second try powering it on when the power cord is hooked up rather then just on battery. then try it without the power cord
May 14, 2011 | Garmin Forerunner 305 GPS Receiver
Garmin watch
If you haven't already done so, try replacing the battery.
You can remove the battery cover with a small coin, check the type (all batteries are marked) and buy a replacement.
Jan 16, 2010 | Watches
Won't turn on or charge
Press Mode (bottom left side button) and Reset (left front button) simultaneously, let go, then press On (top left side button).
Jul 28, 2009 | Garmin Forerunner 305 GPS Receiver
Unit only powers on when attached to base charger
sounds like internal battery is dead, if underwarrenty contact company, if not these batteries are not user changeable u will have to use as is or replace
Jul 07, 2009 | Garmin Forerunner 305 GPS Receiver
Can not charge only works plugged in
Your Garmin nuvi 5000 will never charge because it has NO internal battery. The only time it will operate is when it is plugged into a 12 volt power source. I have one and it really doesn't bother me at all. I bought a second cradle and a 12 volt adapter for use in the home.
May 19, 2009 | Garmin Nuvi 5000 GPS Receiver
Garmin 305 wont power on, wont charge on cradle
Same thing happened to mine. Put the unit in the cradle (just like you are going to recharge it) and press the reset and mode button at the same time for 3 seconds. This will "wake" the unit up.
Mar 30, 2009 | Garmin Forerunner 305 GPS Receiver
I am charging the Garmin Edge 305 for 24 hrs or for at least over night, yet the Edge 305 will show 2 to 3 bars of charges and will last maximum 1 hour of riding time. What to do?
Discharge completely device then charge again for 8 hours.
If not working, then attempt Soft reset :
Hold mode and lap/reset for 10 seconds then release.
Start the device then by long press on start. DEvice should start and charge then
Mar 16, 2009 | Garmin Edge 305 GPS Receiver
Garmin Forerunner 305 GPS Receiver Logo
338 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
