Question about Canon PIXMA MP150 All-In-One InkJet Printer
Hi my printer is flashing E and then 3 in red and I have changed the cartridges and no change there is also a light on which looks like a triangle icon with a bolt of lightning inside it. I do not have the manual and am here in Panama....could you please help? Thank you for your time! Katie
  • katiebrame Jul 29, 2009
    It is now saying E and then 2...we checked for paper or paperclips but nothing. So now it's a different problem...any clues?
    Thanks a lot!
    President:
  • 2,306 Answers
E3 is saying there is still a paper scrap inside, it's a jam error. Usually either a scrap or paper clip or something inside, otherwise a broken or bent sensor flag giving a jam error.
Posted on Jul 29, 2009
  • Craig Gillette
    Craig Gillette Jul 29, 2009
    E2 says there is no paper, install paper ond press OK. Still could be a sensor problem, can't tell without having on the bench.
Flashing red light under ! triangle.
If the red light is on and you just put a new cartridge in it some times shorts the fuse so try:
The fuse is 250mAh and 3/4" inch long (20 mm) round glass with metal ends, the electrical contacts are notin the cartridge but inside the printer: There is a plastic fuse holder on the cartridge, even the starter cartridge. You just simply pop it into the holder. This will stop the flashing red LED and the system tray will say the cartridge is full.
Apr 25, 2011 | Samsung ML-2571N Laser Printer
My Dell 1130 Laser Printer has a red light flashing (triangle and <--> symbol). What does this mean?
Your toner chip page counter has to be reached on last point (run out). Normally one OEM toner cartridge chip can print 2.5k pages, after that cartridge has been locked (although it's remain toner) and red light will be blinking. So, you can't able to take print furthermore in this state. You need to change cartridge chip or you can contact me by my mobile: +91 9330033560 or write a mail to my email id: <e_postmaster@rediffmail.com> I have a solution for changing printer firmware which will make you printer permanent solution for taking print out without changing chip.
Feb 01, 2011 | Dell 1130 Laser Printer
Red light is flashing next to the triangle on my HP2600n laserjet. Do I have to replace all print cartridges that printer says are low
You only need to replace the light indicated toner cartridge but if the others are reading low be prepared to change them. You can do a supplies page printout from the printer menu, click on information and scroll down, this will tell you how much toner you have left in each cartridge
Jun 17, 2010 | HP Color LaserJet 2600n Printer
Photo 1290 Changing ink cartridge
You may have to reset your printer, for when the green an red are flashing. Please do the following in order to reset the printer;
1-switch off printer itself
2-switch off at socket for 20 seconds
3-hold down both black buttons on front
switch on at mains
4-switch on printer itself
green and red flash together
5-now switch off at mains and leave for 3 seconds
6-while holding down both front buttons again, switch on at mains
both green and red flash together so release
7-quickly hold down the left botton, the one with the scroll icon above it.
Hold this until it resets itself, - the print head will re
charge and it will be obvious.
Restting by unpluggin rather than turning off at mains tends not to work.
This must help you as it worked for me.
Regards,
Anirban Mazumdar
Jun 05, 2010 | Epson Stylus Photo 1290 InkJet Printer
Flashing Red & Green lights - Samsung ML 2510
Hi
It maybe one of the fuse gone.
You have to change the fuse:
The fuse is 250mAh and 3/4" inch long (20 mm) round glass with metal ends. The electrical contacts are not in the cartridge but inside the printer: There is a plastic fuse holder on the cartridge, even the starter cartridge. You just simply pop it into the holder. This will stop the flashing red LED and the system tray will say the cartridge is full.
All The Best: Pineworks
Oct 09, 2009 | Samsung ML 2010 Laser Printer
The red light on my epson printer wont turn off and it wont print,ive changed both ink cartridges and still no change.
Hi
Which button has the red light or which LED light? Is it flashing or steady red light? turn it off and check for any obstruction and double check if you installed ink cartridges properly.
Hope this helps
May 13, 2009 | Epson Stylus C40UX InkJet Printer
RED LIGHT
If the signs that is blinking red which is shape like triangle , it is the toner cartridge indicator. The toner cartridge is empty.Try to pullout and check the toner cartridge, if it is light in weight it is already empty.
Feb 23, 2009 | Sharp AR-153E Copier
Cartridge holder won't move when i press button to change ink
Hi, it's not ready for a replacement cartridge yet, the printer is only LOW on ink not OUT of ink. continue to use the printer until the flashing red light remains on solidly, then the head will move to the replace cartridge poswition when you press the button.
Feb 12, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Flashing light
Here is what HP has on the subject of the triangle light flashing:
c00028322.gif 1 - Attention Light 2 - Ready Light 3 - Go Light Figure 2: Printer light key c00028323.gif 1 - Symbol for light off 2 - Symbol for light on 3 - Symbol for light blinking
c00028328.gif Door open, media out, no print cartridge, or media jam
The printer is in an error state that requires operator intervention or help. Check the following:
  • The print cartridge door is completely closed.
  • Media is loaded.
  • The print cartridge is correctly installed in the printer.
  • There is no media jam.
Figure 8: Paper jam c00028328.gif 13.JJ.NT JAM IN TRAY 1
13.JJ.NT JAM IN TRAY X
The Attention LED is blinking. Check paper loading then open and close top cover.
When there is a jam in tray 1, verify the paper is loaded correctly, open and close the top cover. Pressing GO is ignored.
When there is a jam in tray X, verify the paper is loaded correctly, open and close the top cover. Pressing GO is ignored. These are the error explanations for just the flashing triangle light, there are many more, but none for just the flashing triangle.
If the light pattern is different let me know (other lights on as well)
-Hope this helps.
May 28, 2008 | HP LaserJet 1012 Printer
Canon PIXMA MP150 All-In-One InkJet Printer Logo
252 people viewed this question
old marine
old marine
