HOW TO FIT SURROUND SYSTEM TO A YAMAHA RX-V640and also dvd and tv to the amplifier
  • 30 Answers
You should have a orenge moniter or audio out tha goes from you yamh to the amp
Posted on Jul 29, 2009
Will a panasonic tv work with a yamaha surround sound system
Yes, any TV will work with any surround system. It all depends on how you wish to connect them together. That all depends on what kind of inputs/outputs you have on both the TV and the amplifier. Too difficult to advise without being there and having the operating manuals for both the TV and 5.1 system.
Aug 21, 2014 | Yamaha 5.1-Ch. Surround Sound Home Theater...
Subwoofer
go to audio set up and configure the system for 5.1 or higher sound output.then only all the speakers ll work
Jan 03, 2008 | Yamaha RX-V640 6.1 Channels Receiver
How do you connect a Nakamichi surround sound system to my Phillips tv model 42PF7220A/37
I'm confused. The message header shows a problem with a Yamaha RX-V995 receiver.
As for connecting a Nakamichi (or any surround system) to a TV - the only connection would be the Monitor output (video connection) to an appropriate video input of your TV.
If it is a Nakamichi, it is a little older and probly predates the invention of HDMI cables. My guess is you will either use the S video output or Composite video output to the TV's input with similar connections.
This allows you to route whatever video sources you have connected to the Nakamichi to the TV.
May 07, 2014 | Yamaha RX-V995 Receiver
Yamaha RX-V471 3D video for blu ray will not display on TV
Your Yamaha is the problem here. It cannot handle the signal and process the 3D as it states. What I would do is hook your player direct to your TV in the manner that it works and feed your audio from a different path to maintain surround system. Your tv/dvd player may have an audio out that you can feed back to the Yamaha .
Jan 11, 2014 | Yamaha Rx-v471 3D A/v Receiver
Yamaha rx-v1600 hdmi output not working
Have you inspected the HDMI socket? I had the same problem and the socket had been damaged by a tight fit cabinet with insuficcient space behind the amplifier. A sideways cable tug on the inserted HDMI cable had snapped a small piece of plastic seperating the two rows of HDMI connectors, and three were splayed out, so no connection when plugged in. Solution was to carefully re-align the connector fingers and glue a tiny piece of insulating material between the two rows. The output now works perfectly. A bit fiddley, but worth the trouble when you look at how much Yamaha would charge to fit a new socket, or even a new board!
Don.
Aug 11, 2012 | Yamaha RX-V1600 Receiver
No volume from surround sound system on dtvcbl cable, dvd or cd modes with yamah rx-v861 powered on.?
Have you looked at the manual? How did it fare using the set up test tones? Did you assign the digital inputs?
http://www.retrevo.com/support/Yamaha-RX-V861-Receivers-manual/id/2526ci757/t/2/
The unnamed sources probably have manuals, too.
Apr 26, 2011 | Yamaha RX-V861 Receiver
I have a Yamaha RX-V640 AV receiver. When I turn on the system, one of the rear speakers makes a hissing noise and system goes in standby mode automatically. I have tried changing the speaker and speaker...
Hi
the noise that you hear is a static, on the main circuit some components needed to be replaced. dont connect the speakers while you have this problem it can burn the speakers
if you want to fix the Amp let me know
ecrdn@yahoo.com
Jack
Oct 12, 2010 | Yamaha Audio Players & Recorders
My RX V640 is 5 years old..no problems...no changes to the configuration. when I use to the DTV/Cable setting HDTV..video feed...stereo sound etc is fine. Lately when I try the DVD setting to record TV to...
theb best way to do this is to connect the DVR to the vhs unit and the vhs unit to the tv using red white and yellow for both connections. usually composite video 1,2,3 or 4. DO NOT involve the AVR at all, as it will cause your video and audio to be out of sync.The video will not be as sharp, until you play it threw an up-converting dvd or AVR.
Aug 19, 2009 | Yamaha RX-V640 6.1 Channels Receiver
My center and surrond sound speakers don't work with just one output from my dvd do I need to purchase an amplifier also?
You need to first check whether your dvd player supports dolby 5.1. If it supports that then you could connect the digital output of your dvd player to a surround receiver such as Yamaha RX-661. You can then connect all the speakers to the output of RX-661 which has 7 inbuilt amplifiers for all the channels. Its a 7 channel receiver and would be useful with DVD-Audio and such that comes in 7 channels. For your requirement any 5 channel receiver will do. Please let me know if you need any more clarifications.
Jul 28, 2009 | Audio Players & Recorders
Home cinema
Yes, these speakers need an amplifier. So unless your DVD player features an amplifier, then you will need separate 5.1 receiver, for example Yamaha RX-V365 or RX-V465 (which supports audio via HDMI input).
Apr 06, 2009 | Jamo A102HCS5 BLK Compact Designed 5.1...
26 people viewed this question
 Grubhead
Grubhead
