Question about Ricoh Aficio 450 Copier
Cannot find confirmation page "on off switch" Ricoh Afico 2035esp
I selected the fax option as advised but within the four tabs of settings nothing appears to be clearly labeled a "conformation page". Could you directl me to which tab to look under, and if there is an "alias" for the confirmation page.
We'd prefer to only print a confirmation if the transmission fails.
    Problem Solver:
  • 13 Answers
The transmission confirmation report is enabled under the user parameters bit switches. The printing of the report is located at switch 3 bit .
You will find the instructions in your Facsimile Reference
<Advanced Features> users manual. Try looking up page 159.
Posted on Sep 13, 2009
  • 31 Answers
User Tools/Fax/Parameter Settings. Personally I wouldn't mess with those, it's to easy to totally mess up the fax system if you flip the wrong bit switch setting. I threw my 450 programing guides away some time ago being that there's just a hand full of these things left in the hole country. I believe if you go to Ricoh's web site and go to the download page, you can download the fax user manual which if memory serves me (and it often doesn't), you'll find how to change the fax parameter settings.
Posted on Jul 29, 2009
SOURCE:
I have a Ricoh Aficio MP 161 SPF. Faxes unable to send. Message on screen: "Cannot connect to DHCP"
one has nothing to do with the other.but to get rid of the cannot connect to dhcp gotouser toolson the top u will see a few tabs.. select the network tab.one of the options will be ip . select it and select specify.then press ok and exit user tools. that will get rid of the cannot connect error.but again it has nothing to do with the faxing
Jul 17, 2011 | Ricoh Aficio MP 161 Black and White Copier
How do I turn off the fax notification on a Ricoh Afico MP 3500
Most Ricoh multifunction printers have a set of parameter lists that control reports and journals. The parameters are set by using bit switches in the User Tools, and each machine has different switches to control different settings.
What kind of fax machine or printer do you have? The user manual has a list of all parameters and bit switches.
Jan 21, 2010 | Ricoh Aficio CL2000N Laser Printer
Fax confirmation with copy of 1st page
what is the error code 05 for ricoh fax 1140L?
Jul 21, 2009 | Ricoh FAX1180L Laser Fax
Ricoh 2050l confirmation reports
It's more complicated than it needs to be. You'll have to refer to the user manual under 'user parameters'. It's to difficult to explain here. But I can tell you that it is switch '3'......Bit '0' that needs to be changed. manual is here if you need it:
http://www.ricoh-usa.com/downloads/manuals.asp?tsn=Ricoh-USA
* select "Fax 2000L" from the drop down menu (it's the same as yours"
*please rate me :)
Mar 13, 2009 | Ricoh FAX2210L Plain Paper Laser
Wasting paper
Press the User tools/counter button. Select the fax option. Locate confirmation page and turn it off.
Jan 19, 2009 | Ricoh Aficio 450 Copier
Need to change fax number programmed in Ricoh, afico 3025
Press the User tools/counter button;
Touch the Facsimile features icon on the touch panel;
select Gen. settings/Adjust tab;
touch Program fax information;
touch Own fax number;
touch For G3-1, then enter your fax number from the blue numeric
keypad then touch OK.
Touch Exit, then press User tools/counter button to go to Standby mode.
Jan 13, 2009 | Ricoh Aficio 180 Laser Printer
Confirmation page
You can configure your HP all-in-one so that it automatically prints error and confirmation reports. If you need printed confirmation each time a fax is sent, follow these instructions before sending any faxes and select Send Only. To set automated report options from the control panel Press Setup. Press 2, and then press 1. This selects Print Report and then selects Fax Report Setup. clip_image001.gif Press to scroll through the following report types: Every Error: prints whenever there is any kind of fax error (default). Send Error: prints whenever there is a transmission error. Receive Error: prints whenever there is a receiving error. Every Fax: confirms every time a fax is sent or received. Send Only: prints every time a fax is sent indicating whether the fax was successfully sent or not. Off: does not print any error or confirmation reports. Press OK to select the report.
Jul 29, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Fax confirmations
i have read the manual end to end and I don't think you can.
Only thing I see is this.
Customizing your settings using the Lexmark Fax Solutions You can adjust the fax settings in the Lexmark Fax Solutions. These settings apply to the faxes you send or receive.
  1. Click Start onestep.gif Programs onestep.gif Lexmark 7100 Series onestep.gif Lexmark Fax Solutions.
  3. Click each tab and change the settings as desired.
  4. Press Save Settings after you finish your updates. Nothing is saved until you press this button.
  5. Click Close.
The following table contains the Setup and Settings tabs for the Lexmark Fax Solutions.
On this tab
You can
Personalize
  • Enter your company name and fax number.
  • Enter your name, company name, phone number and address as you want them to appear your cover page.
  • Select a cover page for your fax.
Send
  • Choose to use error correction.
  • Choose to use fax header.
  • Select a maximum send speed and a print quality for outgoing faxes.
  • Choose whether to scan the entire document before dialing the number.
  • Select when to print a fax usage report.
  • Select when to print a fax activity report
Select when to print an activity report is the only close item I can find. Nothing whatsoever about a confirmation report.
Feb 25, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Fax confirmation
Hi TUlsi The majority of fax machines will do this, I know as the ones i use in DHL are the same when i contacted the company Cannon they advised that it could not be disabled. Which give the solution, All faxes are different and you will only know how to disable it by contacting the manufactures support. I agree full it is anti enviromently friendly and a waste of ink
Mar 02, 2007 | Ricoh Aficio 2018D All-In-One Laser...
Ricoh Aficio 450 Copier Logo
1,266 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
gggg
Adorjani Laszlo
quennie732
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
