Question about Brother MFC-8860DN Printer
Brother MFC-8840D print quality very faint and also overprinting same page three times along the page - please help!
  • 23 Answers
Refil teh ink, and open it up.. make sure you print 1 paper and see that it feeds properly. if it has a problem somewhere take actions to fix it... duct tape usually helps :P
Posted on Jul 29, 2009
Brother mfc-j4410dw overprint
Go To Below official brother Printer Page For Your problem, http://solutions.brother.com/Library/ug/mfc440cn/us-en/html/nug/chapter7.html
Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For Brother Printer Support
Apr 20, 2014 | Brother Office Equipment & Supplies
I have a Brother MFC 8840D. The print quality is excellent and appears to be stable (it does not rub off), but once I fold a document and place it into an envelope, the recipient will receive a smeared...
It sounds likea problem with your paper stock. Check the following to make sure you are using a paper type that is compatible with your printer.
Recommended paper
Plain Paper: Xerox Premier 80 gsm
Xerox Business 80 gsm
Mode DATACOPY 80 gsm
IGEPA X-Press 80 gsm
Recycled paper: Xerox Recycled Supreme
Transparency: 3M CG 3300
Labels: Avery laser label L7163
??  Before you buy a large amount of paper, please test some to make sure that the paper is suitable.
??  Use paper that is made for plain-paper copying.
??  Use paper that is 75 to 90 gsm.
??  Use neutral paper. Do not use acidic or alkaline paper.
??  Use long-grain paper.
??  Use paper with a moisture content of approximately 5%.
Caution
Do not use ink jet paper. It may cause a paper jam and damage your MFC.
Choosing acceptable paper
It is recommended that you test paper (especially special sizes and types of paper) on the MFC before purchasing large quantities.
??  Avoid feeding label sheets that are partly used or your MFC will be damaged.
??  Avoid using coated paper, such as vinyl coated paper.
??  Avoid using preprinted or highly textured paper, or paper with an embossed letterhead. For optimum printing, use a recommended type of paper, especially for plain paper and transparencies. For more information on paper specifications, call your nearest authorized sales representative or the place where you purchased your MFC.
??  Use labels or transparencies that are designed for use in laser printers.
??  For the best print quality, we recommend using long-grained paper.
??  If you are using special paper and the paper has problems feeding from the paper tray, try again using the manual feed tray or Multi-purpose tray.
??  You can use recycled paper in this MFC.
The output quality depends on the paper type and paper brand. Visit http://solutions.brother.com and check the latest recommendations for paper that can be used with the MFC-8840D.
Dec 23, 2010 | Brother MFC 8840D All-In-One Laser Printer
GETTING MACHINE ERROR ERROR 78 , PRINTER NAME BROTHER MFC 8840D
Machine Error 78 indicates a mechanical malfunction of the Brother MFC-8840D. 78 represents the error number. You have to contact Brother Customer Service 1-877-BROTHER.
Dec 22, 2010 | Brother MFC-8840D All-In-One Laser Printer
Brother MFC-8840D printer w/false paper jam indication.
With my Brother 8840D I have had paper jams that when cleared would not delete from the display nor would the machine operate until I unplugged the machine for around eight hours. I guess it is a sort of reset or reboot.
Jun 06, 2010 | Brother MFC 8840D All-In-One Laser Printer
Toubleshooting and routine maintainance is what comes oout on myscreen
Found this on the web. Click on link below to print the entire manual out to keep. Below are steps to do cleaning. If you find this helpful pls rate me. Thanks and Good Luck.
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_210C_420CN_EN_286.PDF
How to improve print quality Cleaning the print head
To ensure good print quality, the MFC will regularly clean the print head. You can start the cleaning process manually if needed. Clean the print head and ink cartridges if you get a horizontal line in the text or graphics on your printed pages. You can clean Black only or three colors at a time (Cyan/Yellow/Magenta), or all four colors at once.
Cleaning the print head consumes ink. Cleaning too often uses ink unnecessarily.
Caution
Do NOT touch the print head. Touching the print head may cause permanent damage and may void the print head’s warranty.
1 Press Ink.
2 Press or to select Cleaning.
Press Menu/Set.
3 Press or to select Black, Color or All.
Press Menu/Set.
The MFC will clean the print head. When cleaning is finished, the MFC will go back to standby mode automatically. If you clean the print head at least five times and the print has not improved, call Brother Customer Service (see Brother numbers on page i).
Checking the print quality
If faded or streaked colors and text appears on your output, some of the nozzles may be clogged. You can check this by printing the Print Quality Check Sheet and looking at the nozzle check pattern.
1 Press Ink.
2 Press or to select Test Print.
Press Menu/Set.
3 Press or to select Print Quality.
Press Menu/Set.
4 Press Color Start.
The MFC begins printing the Print Quality Check Sheet.
5 Check the sheet to see if the quality is OK by following these steps:
Color block quality check
The LCD shows:
6 Check the quality of the four color blocks on the sheet.
7 If all lines are clear and visible, press 1 (Yes), and go to Step 10.
OR
If you can see missing short lines as shown below, press 2 (No).
The LCD will ask you if the print quality is OK for black and three colors.
OK Poor
Is Quality OK?
1.Yes 2.No
Black OK?
1.Yes 2.N
8 Press 2 (No) for Black or three colors
with a problem.
The LCD shows:
Press 1 (Yes). The MFC will start cleaning the print head.
9 After cleaning is finished, press Color Start. The MFC will start
printing the Print Quality Check Sheet again and then return to
step 5.
10 Press Stop/Exit.
Jan 14, 2010 | Brother MFC 210C All-In-One InkJet Printer
Cannot print keeps saying clean printer cannot find info to do it
Caution
1 Press Ink.
Press Menu/Set.
Press Menu/Set.
1 Press Ink.
Press Menu/Set.
Press Menu/Set.
The LCD shows:
OR
OK Poor
Is Quality OK?
1.Yes 2.No
Black OK?
1.Yes 2.N
with a problem.
The LCD shows:
step 5.
10 Press Stop/Exit.
There is more, but too long to put here.
Jan 13, 2010 | Brother MFC 210C All-In-One InkJet Printer
Print is faded. I just replaced the ink jets.
You said you just replaced the ink jets. Did you clean the print heads? Here is Link on Web. If you find this helpful pls rate me. Thanks
once.
unnecessarily.
Caution
1 Press Ink.
Press Menu/Set.
Press Menu/Set.
numbers on page i).
Jan 11, 2010 | Brother MFC 210C All-In-One InkJet Printer
EVERY TIME I PRINT OR GET A FAX ON MY BROTHER MFC-8840D FAX IT SHUTS MY COMPUTER DOWN
Fax is an operating system setup utility...perharps you have backup file that are corrupt in your operating system so, Repair your operating system and try it again.
Sep 30, 2009 | Brother MFC-8840D All-In-One Laser Printer
MFC-7420 GHOST IMAGES
sounds like a bad drumbur also can be caused by a defective fuser.
Jan 16, 2009 | HP LaserJet 1020 Printer
Brother MFC-8860DN Printer Logo
201 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
