Question about Logitech Labtec Wireless Laser Mouse
I took the mouse apart and I can't put it back
Logitch wireless mouse: I took the mouse apart and I can't put it back together. I cant get the top cover to go back in place.
    Novelist:
  • 112 Answers
Make sure the circuit board and wires are all in place correctly so they aren't preventing the case from snapping/connecting back together.
Most of the time, it's just a small piece of wire or something that is getting in the way and preventing you from closing it back up.
Devices are made so small these days that they don't leave much room in them for loose wires and all.
I hope this helps :)
Best Regards,
James Trageser
Posted on Jul 29, 2009
Where is the receiver or usb device in a GE wireless optical mouse 98763
There isn't one on a wireless mouse.You get the sender with the mouse that goes into your USB port on computer.Put it back together and find the little USB sender in the blister pack,put a battery in the mouse,and your good to go.All i use is wireless mice.
Nov 08, 2013 | GE Optical Mini Wireless Mouse 98793
How to put a rotozip rz10 back together
Hardest part is getting the trigger mechanism back in the right position while putting the screws in place. Everything has a slot/groove it fits into before both outside covers can be put together. One side will be easier to hold the pieces while the other simply covers them. A spot of glue (elmers) may help to hold trigger in place and the wires.
Apr 22, 2013 | Bosch RotoZip Spiral Saw RZ10 - 2100
Need logitch M317 Wireless Mouse Driver
Hi...
logitch M317 Wireless Mouse drivers (xp/vista/win7/win8) can be found at driverupdate us
It will take 2 mins from you to install...
I hope I have helped you...
enjoy
Aug 30, 2012 | Logitech Computers & Internet
How to set up a tomtop mini wireless mouse
Just had the same problem, the battery compartment is in the top, back part of the mouse, it was a pain to get it open, but once I did everything seemed to work just fine
Feb 02, 2012 | Computers & Internet
I took my Dell wireless mouse apart to clean the wheel. The spring fell out. I don't know where it goes back ( I didn't see where it fell from). I put it back together without the spring and now...
i beliece it is very fiddly to put that certain spring back in cus it is hard to see where they go back, my advice is to go to a local PC store and get them to use the right tools to place it back in for you.
Jul 15, 2011 | Computers & Internet
I cant get my logitch wireless keyboard to work
Do as I did. Get a 5 dollar wired keyboard and put the Logitech wireles keyboard in the garbage can where it belongs. I can't start describing the many problems I had with it. The mouse went the same way weeks earlier.
Jul 25, 2010 | Logitech Wireless Access Duo Optical...
Battery replacement
There is a button for the battery cover release on the bottom of the mouse. Slide the wireless usb adapter out and the button should be there.
Nov 05, 2008 | Logitech 3-Button Cordless Optical Scroll...
Dell mouse
Buy a new wireless .. a lot cheaper than worrying about putting it together.
Oct 23, 2008 | Dell USB Scroll Mouse (x04-91624)
Cant get it back together
I put together what I knew where it went, the put the whole thing together and looked at it before putting in the screws. I saw a hole and remembered a "button" there that moved sideways with a spring pushing it back into the original place. I reopened and after examining the part put it in that slot. I then put it together and it worked. I put the screws back in then and all is well
Thank you for the reply.
Glad I found your site. I will keep it if I ever need any help.
Kathryn
Oct 11, 2008 | HP Wireless Optical Mouse
Microsoft Wireless Optical mouse 2.0 Sticky central wheel
I just took mine apart to fix same problem, works much better but not sure for how long.
Quite simple to dismantle the unit.
Take the battery cover off, remove batteries.
There is a small screw in the middle of the battery cavity, you will need a very small Phillips head screwdriver.
Gently ease the base (holding circuit board) from the top shell
The wheel unit can be gently eased out of its cradle, use the small screwdriver to pop it out, watch out for the small spring between base and wheel unit, don't lose it
You can disconnect the wheel unit from the circuit board by unhooking the small plug connector
Now defluff, then clean the wheel - I used a tiny amount of turps on a cloth, anything similar should work. If you look closely the reason the wheel won't roll smoothly is that the gel ring on the wheel is too close and rubs at the front and back of the cradle. Once grime builds up, this problem makes the wheel unusable. Roll the wheel back and forth along a clean surface once cleaned, should start rolling freely again.
I also unscrewed the top shell from the mouse buttons (all one piece, pinch the plastic pegs in the centre of the shell together to release) and cleaned the whole unit up before putting it back together
Don't forget the spring when putting the wheel unit back. When screwing the base to the top shell make sure there is no play between the two parts before you put the batteries back in, mine was a bit tricky to get tight again but worked fine second attempt
Sep 07, 2008 | Microsoft Standard Wireless Optical Mouse
Logitech Labtec Wireless Laser Mouse Logo
444 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
