Question about Samsung CLX 3160fn All-In-One Printer
Samsung CLX-3160FN "DEVE HOME SENSOR ERROR"
Following the instruction manual, I unplugged the printer, and turned it back on. It worked for a few hours. Now the same error is back and turning on an off does not help. I also removed the imaging unit and transfer unit and re-seated both, thinking that would help. I have read many on-line posts with different solutions. No one seems to have the definitive answer! Will I need a new imaging unit or transfer belt? I replaced these within the last 6 months. The folks at Samsung are useless and I am beginning to hate this printer more every day! Any suggestions that REALLY WORK?
  • gailrayner Jul 29, 2009
    Thanks for the advice. We will attempt to clean the inside, but do you know exactly WHERE the DEVE HOME SENSOR is so we can make sure that it is cleaned as well?
    The advice was helpful, but it did not fix the problem. Looks like I may need to purchase some new parts -- AGAIN.
  • Samsung Master
  • 19,396 Answers
To start the printer must be cleaned internally, as dirt may cause the Deve Home sensor malfunction.
If that does not work, in that case a Deve Home sensor may be faulty. In this case Samsung suggest that there is a problem with the fuser unit and they say to call support.
As far as I know Deve Home sensor is often caused by toner contamination and dirt inside the printer.
Posted on Jul 29, 2009
HOME SENSOR EROR
Deve Home Sensor Error
There is a problem in the fuser unit.
Unplug the power cord and plug it back in. If the problem persists, Replace to the Main board.
Aug 30, 2011 | Samsung CLX 3160fn All-In-One Printer
Deve home sensor error on samsung clx 3175
Dear
There is a problem in the fusser unit.Turn the power switch off and on. If the problem persists, call for service engineer.
Thanks.
Sep 24, 2010 | Samsung CLX 3160fn All-In-One Printer
Non-working printer; no paper pickup
The solution shown for the Samsung CLX-3160FN All-In-One works also for the Samsung CLX-2160N.
The associated picture and methodology of "pre-stretching" the solenoid spring is virtually identical for both printers.
Worked for me on the CLX-2160N
See here
http://www.fixya.com/support/t4742967-deve_home_sensor_error
Jul 07, 2010 | Samsung CLX-2160N All-In-One Printer
Problem for Samsung CLX-3160FN All-In-One Printer Deve home sensor erro
Please check the sensor of front door or back door, one of these are not working, chec softly by rolling your finger on it, and let me know if this works or not i3game@cooltoad.com
Mar 24, 2010 | Samsung CLX 3160fn All-In-One Printer
Samsung clx-3160 fn not printing flases DEVE HOME SENSOR ERROR
if the printer is flashing developer home then the developer unit is not situated correctly or the contacts are dirty causing the printer to not recognize the dev unit clean the contacts with denatured alcohol on the dev unit and where it makes contact within the printer and power back up.
failing that the dev unit may have expired requiring a new one to be installed.
if this answers your query and fixed the issue please rate me accordingly.
thanks
Sep 14, 2009 | Samsung CLX 3160fn All-In-One Printer
DEVE Home Sensor Error
Dev. Home error can be fixed by stretching out a solenoid spring on the power cord side of the printer. The solenoid acts as a clutch to stop the spinning developer actuator at the right spot.
The problem is that the spring gets weak over time / the cogs round out over time and the solenoid finger is overcome by the spinning cogs, and resulting in selecting the wrong developer.
Open up the right side (power cord side) of the printer (take off top cover, then take off side cover). Then, find a solenoid (little metal square) that touches the white plastic vertical spur gear. Take the spring off the solenoid. Now, put the spring back on - only this time you will attach one anchor point to the middle of the spring as to pre-stretch the spring for more tension.
More pictures of the solenoid on Facebook:
http://www.facebook.com/#!/photo.php?pid=55779771&id=2257206&fbid=10100154259704133
Sep 13, 2009 | Samsung CLX 3160fn All-In-One Printer
hi if u check the samsung manual herehttp://www.wisconsinimaging.com/downloads/clx3160manual.pdfthen u will find it in page 79 and it saysThere is a problemin the fuser unit.suggestion:Unplug the powercord and plug it backin. If the problempersists, please callfor service.
Jun 09, 2009 | Samsung CLX 3160fn All-In-One Printer
Deve Home sensor Error as occur cannot get printer to work
The web does not offer alot on this error. However the users manual indicates it is a fuser issue. Try a new maintenance kit. That should include the fuser and all rollers.
Dec 16, 2008 | Samsung CLX 3160fn All-In-One Printer
Samsung CLX 3160fn All-In-One Printer Logo
574 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
