Question about Dell Inkjet 720 Printer
My daughter just pulled off a small grey strap from inside the printer where teh cartridges are and there is a spring too - where shoudl this go? Now the cartridge block just snaps from side to side really quickly. I took it to a repair shop and they said a clip has snapped???
    Novelist:
  • 112 Answers
If you took it to get serviced and they told you that the clip has "snapped", they probably mean that it's broken and a replacement part is needed which you can most likely order from Dell.
If not, you may have to get a new printer, but you can pick them up fairly cheap at Wal-Mart, Staples, etc...
I hope this helps :)
Best Regards,
James Trageser
Posted on Jul 29, 2009
How do I remove the cartridge on the hp laserjet p3005dn printer
Normally you open the front of the printer, there is a grey indent on the front top which then tilts forward, then remove the cartridge. If the cartridge does not want to come out because it is jammed then check the inside right of the door, there should be a white nylon curved bar that is attached to the front door and disappears inside the printer. This is the lever that disengages the cartridge drive so that you can pull the cartridge out. If it is not attached to the front door, try to pull it out manually so that you can remove the cartridge. Beyond that, if the cartridge is jammed for some unknown reason, you may just have to pull and wiggle it to get it out.
Sep 05, 2014 | HP LaserJet P3005dn Printer
How to reset ink cartridge for lexmark x5650 #36 black
Take a small pice of clear tape. Try covering one of the outside vertical row of contacts at thr front of the cartridge. Re-insert it and it shoudl "fool" the printer into thinking it is a new cartridge. It works for my Lexmark 2600 series all in one
Mar 25, 2010 | Lexmark X2500 All-In-One Printer
I have a hp psc 1517 and there is a thin strip of plastic behind the ink cartridges, my daughter pulled it out can it be put back in and if so how
Sounds like you are refering to the encoder strip. It is a thin clear piece of plastic with little black lines all the way accross the length of it. The printer has a sensor on it that reads these lines so that the carriage assembly knows where it is inside the machine. It is usually spring loaded on one end of it. Both ends of the encoder strip have a notch on it. One side of the encoder strip hooks onto a fixed mount through one of the notches, the other side hooks onto a spring loaded mount. If your daughter didn't pull it all the way out of the machine it is a bit easier to reinstall because all you need is something skiny and long like a pair of needle nose pliers to reattatch it to both of the mounts. If it is all the way out the strip needs to be threaded back through the sensor on the back of the carriage assembly(the thing you intall the ink cartridges into). Hope that helps a bit. It is a simple problem for a tech to fix but could be more difficult if you are trying to do this without removing any of the covers.
Oct 03, 2009 | HP PSC 1315 All-In-One InkJet Printer
Replacing an ink cartridge
You need to completely remove the plastic strip in order to use the cartridge. That releases the toner to allow printing. It's there to keep the toner from escaping during shipping.
Jan 12, 2009 | HP LaserJet 1100 Printer
We have a hp deskjet f4140 printer that had a paper jam. My wife pulled the paper out of it, and it is acting crazy now. It told me that it was low on black ink, so I replaced the cartridge with a new hp...
Does the carriage move and home out when you power up the printer? If not, look inside the cavity where the carriage assembly is and look for a skinny little piece of plastic, it should be anchored on either side of the printer frame with a small spring on one side. it should go thru the carridge assy. This is the encoder strip. The carriage uses it for reference when it moves. If this strip has been knocked out of position the machine almost immediately signals an error, (attention light flashes). If this is the case, then the challenge is to A-find the spring and B-reattach the encoder strip. Good luck.
Larry
Dec 01, 2008 | HP Office Equipment & Supplies
Hp 6110 remove and check cartridge
this kind of hp printer, have often a specific problem with a cartridge carriage. If you can observe (with a flashlight) inside of cartridge carriage, on the right side of carriage, you can see a small piece of spring made from steel, which is moved from his place, because an broken little piece of plastic.
if you see the spring which is moved, you also may see the hole created by the spring on the electrical contacts of the cartridge carriage.
if you can see the hole... you have a very bad news.
i dont know how much cost the repair of printer, but I tell you, this printer is discontinued.
Sep 22, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Hp office jet 7310 all in one printer problem
When you install your printer, did you install the driver first ??? If not, unplugged the USB cable from the printer and uninstall the printer of your computer and restart your PC.
Re-install the driver first and connect your USB cable when the software prompt you to do so....
Let me know !
Mar 31, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Lexmark z53
You will need to do the following diagnostic tests to determine the exact cause of the error: · Remove the ink cartridges · Perform the self test (test B below) · Test the ink cartridges A. To remove the ink cartridges: Switch the printer on by pressing the green button. Open the front cover of the printer. The cartridge carrier should move to the center of the opening. Remove both cartridges. If the carrier does not move to the center of the opening, you will need to remove the cartridges by hand. Turn the printer off and remove the power supply cable (the small circular one) from the back of the printer. Open the front cover of the printer. Inside the printer, locate the silver metal carrier bar on which the print carriage slides. Locate the black rubber carrier belt above the carrier bar. This belt has tracks on its inner portion. Grab the top portion of the belt and move it toward the right. As you move this, the ink cartridge carrier will move to the left. Continue to move the belt until the carrier is in the center of the opening. Now pull both cartridges out. B. To perform the self-test: Disconnect both the power cable and the USB or parallel cable. After one minute has passed, plug the power supply cable (the small black circular one) back in. (This step is necessary to reset the printer.) Turn the printer off by pressing the green power button. Hold down the grey paper feed button. Turn the printer on by pressing the green button. After the printer begins to feed paper, release the grey button. Once the paper exits the printer, press the green button to turn the printer off. If the power light blinks twelve times while no cartridges are installed, there is a problem with the printer. If this is a new purchase, you can also exchange the printer at the point of purchase. If the paper went through the printer as if printing was occurring, you will need to do some more testing. Continue as instructed below. C. To test the ink cartridges: Open the front cover and insert only the black ink cartridge. Make sure that you push it back until it snaps into place. Close the front cover. If the light flashes twelve times, there may be a defect in the black cartridge. If not, proceed to the next step. Turn the printer off using the green power button. Hold down the grey paper-feed button. Turn the printer on using the green button. After the printer begins to feed paper, release the grey button. Once the paper exits the printer, press the green button to turn the printer off. If the light flashes twelve times, there may be a defect in the black cartridge. If a page came through with a black line, your black cartridge is working properly. Now you need to take the black cartridge out and perform the same steps with the color cartridge. If the light flashes twelve times, there may be a defect in the color cartridge. If a page came through with colored lines, your color cartridge is working properly. If one of the cartridges is causing the problem, you will need to replace that cartridge. If it is a new cartridge, please exchange it at the point of purchase. Good luck
Aug 30, 2007 | Lexmark Z53 Color InkJet Printer
Error 1200
Lexmark X4270 Error 1200 Fix - Click here for document link
1. Unplug printer from wall and remove power supply.
2. Unplug any phone lines or USB cords connected.
3. Remove printer attachments, paper trays and phone.
Figure 1 - Printer paper holder and completed print tray
4. Lift the front cover of the printer and remove the white rubber bar by pulling the blue lever on right towards you.
Figure 2 – Top view of printer showing the white rubber feed bar with purple attachment
5. Remove the screws underneath the front cover (6 screws), back of printer (2 screws), and bottom of printer (1). View the images below to find where to remove the screws.
Figure 3 - Top view of printer showing which screws to remove.
5. Cont…
Figure 5 - Bottom view of printer. Image on left is cover to screw. Gently remove ribbon cable to reveal the gold screw beneath
6. Flip the front cover open and gently lift the top of the printer cover. Keep front cover open.
7. Remove the ink cartridges out of their carriage.
Figure 6 - Displays ink cartridge carriage with ink cartridges removed.
Caution: Electrical hazard. Keep hand and metal pieces clear of board or any other electrical wires or parts.
NOTICE: The ink cartridges are all the way to one end. If the X4270 is plugged in, the cartridge carrier is stuck and doesn’t move. After further investigation a noticeable small black plastic lever is preventing the ink cartridges from moving. Photo below shows lever up and down (cartridges already moved in image below).
Figure 7 - Shows inside of X4270 and the lever that causes error #1200. Image on left displays lever up. Image on right displays lever down.
8. Push lever down clockwise so it is flush with plastic wall. Refer to image on right in Figure 6.
9. Lift the front cover open (if not already open) and plug in the X4270. Cartridges should move to center as if preparing for replacement.
10. Unplug the X4270 and remove power supply.
11. Remove bottom assembly carefully.
Figure 8 - Displays bottom assembly with lever and spring
Note: The cause of this problem is the spring slides out of place over time, probably because of ink shed on one end of its loop and loop attachment.
Figure 9 - Displays loop attachment
12. Place spring in loop attachment and use hot tip of heated tool to melt top of loop attachment to prevent further errors. Melt top of loop attachment similar of that to a mushroom top.
Figure 10 - Displays fix for jammed carriage.
13. Reattach the lever to the bottom assembly and slide back into place inside the X4270.
14. Plug in and check if operational.
15. Reassemble X4270 using steps 3-7.
Oct 03, 2006 | Lexmark X4270 All-In-One InkJet Printer
Dell Inkjet 720 Printer Logo
49 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
