Question about Kodak Carousel 4600 Slide Projector
Carousel 4600. Dropping resistor is crumbling.
Carousel 4600. Dropping resistor is crumbling. Cannot read number of ohms to determine replacement. Please advise. Thanks
    President:
  • Kodak Master
  • 412 Answers
The dropping resistor is a 3 ohm, 30 watt resistor. It is available from: www.micro-tools.com
Posted on Jan 03, 2011
Tip
Load Resistor Testing for 4400CL and 4600CL Steppers
This video covers troubleshooting of the load resistor on the Stairmaster 4400CL and 4600CL Steppers.Tools Needed: Multi Meter
The load resistor is cylindrical in shape and has metal fins encased in the ceramic coating around the outside. The job of the load resistor is to take the extra electricity from the alternator and dissipate it as heat. Symptoms that one may experience when the load resistor fails are alternating resistance in the pedals or no resistance in the pedals. Alternating resistance can occur as the load resistor heats or cools causing the resistance to come and go. If the load resistor is really bad, there can be no resistance in the pedals.
You can test the load resistor by first following the wires from the load resistor to the lower control board.
Next, carefully disconnect the load resistor wires from the lower control board. Be careful not to damage the connector on the lower control board or the load resistor wires.
Set your volt meter to the setting larger than and closest to 2.5 ohms. Insert each lead from your volt meter into the pins of in the wire connector of the load resistor.
Look for a reading of 2.5 ohms (+/- 10%). If your reading is outside the range, the load resistor should be replaced.
Load Resistor Testing for Stairmaster Steppers 4400CL 4600CL
on Feb 11, 2015 | Stairmaster 4600 Cl Cordless Freeclimber
How do I properly install the carousel? It's not advancing I think it's not on properly.
It is a while since I have handled one, but as I remember, you have to line up the number 1 slide position with the slot in the projector and then it clips into place with a little pressure.
May 17, 2011 | Kodak Carousel 4600 Slide Projector
My tv is 3D.....I purchased the repair kit, but it did not come w/the right resister. I went to radio shack and they can't read the # on the olld resister, so I need to know what number should it say on...
What is the location number of resistor on the board? I assume you are replacing the STK ICs
is one resistor in that circuit? It has to be a low ohm resistor What are the Band Colors on resistor?
Example brown,red,black 1.2 ohms
Nov 12, 2010 | JVC AV-48WP30 48" Rear Projection...
Sometimes stop advancing. sometimes keep advancing 5 to 8 slides.
the mechanism needs cleaning. it is an almost purely mechanical device and needs greasing. the old grease gets hot and dusty and starts to get sticky. when this happens, the moving parts tend not to move. the mechanism needs to come out for a cleaning and regreasing.
Jul 11, 2009 | Kodak Carousel 4600 Slide Projector
Need to make it advance automatically
Sure! Not only did Kodak sell an external automatic timer that plugs into the remote socket, a number of other companies had them as well. If you can't find one searching online for "Kodak slide projector plug-in timer", try: www.micro-tools.com Good Luck !
May 12, 2009 | Kodak Carousel 4600 Slide Projector
I have a resistor problem in sanyo ST-21G1
it's very difficult to give the exact value of that resistor.,but i can give some tips to find the value of the said resistor .( find how the resistor works, it is a dropping or fusable? if fusable used .47 or 1 ohm resistor if it is a dropping resistor you should make a trial and error .from 100k,10k or 1k.
Oct 29, 2008 | Televison & Video
Resistors
Okay R939 resistors are 3.3 OHM 2 watt metal film. and R950 are 270 OHM 2 watt metal film. The 3.3 ohm are the most likely. One end has to be unsolderd fro circuit and lifted out to check them if they dont read 3.3 ohm they need to be replaced as they are 5% tolerant resistors. I Cant find the rating for R392 can you tell me the color bands on them and are they the same size as the other two type resistors? The 3.3 are the ones I would check if they read 3.3 they are good but if they dont measure or measure high replace them, and let me know the details on R392 color bands and size.
Jun 16, 2008 | Apex Digital GB55HD09W 55" Rear Projection...
Hitachi 43UUWX10B
The resistors often burn out on that set when the convergence ic's go. The 3.3ohm 1/2watt metal film resistors those are usually the ones that burn out when the ic's go. you have to unsolder one side and lift the leg up out of circuit to check with a ohms meter. You can not check them in circuit make sure you lift a leg up to check or you will not get a correct reading
May 28, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Blown 1501d
R435 is 39.2 ohms. If R436 is the other gate resistor, it's also 39.2 ohms.
Oct 18, 2007 | MTX Thunder 1501D Car Audio Amplifier
Kodak Carousel 4600 Slide Projector Logo
154 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
