Question about RELIANCE ELECTRIC WATER HEATER
My electric reliance water heater is making a constant noise
My electric reliance water heater is making a constant noise I have had it for 10 years I have not noticed a loss in hot water. Could this be the pressure valve? I can not find my manuel.
  • 117 Answers
It might be hard water in the heater. the hard water flakes and when your water heater turns on it creates some movement in those hard water flakes and makes a popping and hissing noise then when it comes to temperature it should stop. the temperature and pressure relief valve shouldn't make this noise. but if you stick your finger in the pipe and it is wet then you might have problems some where else. let me know if it is
Posted on Jul 29, 2009
Reliance 606 electric water heater is making a pulsing noise. What could be the cause?
Your heating element is bad get tha specs for your hot water heater and get one at lowes or menards
Aug 31, 2016 | Reliance Water Heaters
Hot water tank wont heat water, how do you relight or resat, its a reliance self cleaning 808
Reliance Water Heater Literature ' Owner's Manuals ...
www.reliancewaterheaters.com/resources/instruction-manuals
Welcome to the Reliance Water Heaters Owner's Manual and Installation ... 9 40 EKRT - 40 Gallon Tall Self-Cleaning Electric Water Heater - 9 Year Warranty . ..... 10 50 DHPST - 50 Gallon Electric Heat Pump Water Heater - 10 Year Warranty .
How to light the pilot on a Reliance 606 water heater ...
? 3:27
https://www.youtube.com/watch?v=VU2PsFVd2ug
Jul 12, 2011 - Uploaded by kilroywashere123
How to light the pilot on a Reliance 606 water heater ... How to fixwater heater, will not stay lit - sealed combustion no hot water - Duration: ...
Reliance Water Heaters - Consumer Affairs
www.consumeraffairs.com > Homeowners > Bath & Plumbing
Rating: 1.6 - ‎84 votes
I purchased a Reliance 606 water heater in 2010. ... That they don't TELL you there's areset button or that I'm having conspiracy thoughts ... After several attempts, I was able to relight it. ... It's heading to the junk pile and I will purchase a new reliable (NotReliance) ... Checked breaker and changed breaker still no hot water!
Dec 28, 2015 | Reliance Water Heaters
My water heater is running out the overflow valve and making noise, also noticed my hot water is coming out extremely hot out the faucet.. Whats wrong and how do I fix it?
there is a thermostat control at the heater element that is adjustable
The temperature range is from around 55c to around 90c and if the water is almost boiling then I would suspect that that thermostat is not operating correctly
have an accredited electrician or plumber with electrical qualifications check it out.
Jun 20, 2015 | Reliance & 50gal Electric Water Heater
Sediment build up on element
Copy following link for element resources:
http://waterheatertimer.org/How-to-replace-water-heater-element.html
You can soak element in white vinegar to remove scale, and that will reduce some of the whistling noise.
Cleaning sediment out of tank can restore full efficinecy to electric water heater:
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html#electric
Another cause of water heater noise are factory-installed heat traps.
http://waterheatertimer.org/New-water-heater-making-noise.html
Add a comment for followup
May 26, 2013 | RELIANCE ELECTRIC WATER HEATER
My reliance 501 is leaking at both entry hoses ports and also is very hot to the touch near the electrical connection port on the top of the water heater.
Emergency steps:
Turn electric power off.
Release tank pressure by opening bathtub faucet on hot side.
Turn off water supply to heater.
You can turn water heater ON for short periods (1/2 hour) to make some hot water until repairs are made.
It sounds like runaway heating caused by shorted element, possibly caused by leaking water. But I cannot tell for certain what the problem is. Read following links and/or call plumber.
http://waterheatertimer.org/Leaking-water-heater.html
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Over-amping:
Look at watt rating label on side of tank.
For example 4500 watt water heater requires 30 amp breaker and 10 gauge wire.
If you have 20 amp breaker and 12 gauge wire, then change elements to max 3800 watts. Tank will heat more slowly.
You have to fix leaks, and I cannot see that problem. Call plumber or repost question with clear description of leak.
Jul 31, 2012 | RELIANCE ELECTRIC WATER HEATER
The water heater leaks
Once it starts leaking, that is it, replace it. I strongly recommend that you put a PAN under the new unit, as it will also leak in 8 to 10 years...pan needs to be plumbed into a drain....not expensive, but water damage is...
Sep 10, 2011 | RELIANCE ELECTRIC WATER HEATER
I don't have a problem, just a question.....we are in the process of buying ahome and the hot water heater is a Reliance 501, 50 gallon tank....with serial number G94278175...I would like to know the...
State, Kenmore, Reliance, Ace , Ambassador, Barnett, Century, Crosley, Energy Stretcher, Freedom, Freedom/Nipsco, Hardware House, Master Plumber/True 5, Mission, Nationaline, Patriot, Penfield, President, Regency, Century, The Plumbery, Thermo-king, TopLine
1-letter month followed by 2-digit year
So it was manufactued in 1994. Most water heaters will last 5-10 years for gas and 10-15 for electric unless they receive yearly maintenance (flushing tank, cleaning) so it is already past its expected life span.
That being said, an electric water heater is more costly than a gas one. If I was in your place I would start saving to replace the unit with a tankless gas water heater, as soon as the house closed.
Jun 09, 2011 | RELIANCE ELECTRIC WATER HEATER
Hot water heater is constantly runnin and sds like water is running. the noise seems to be coming from the emergency valve area. there is water pooling around the bottom of the heater
Open following link to identify specific leak and remedy:
http://waterheatertimer.org/Water-heater-is-leaking.html
If TP valve is leaking: replace TP valve:
http://waterheatertimer.org/How-to-replace-TP-valve.html
If tank is rusted and ready to rupture, then turn water heater off:
Over next days, turn water heater on for short periods to make hot water when needed, then replace water heater.
http://waterheatertimer.org/Emergency-steps-for-leaking-water-heater.html
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 19, 2011 | RELIANCE ELECTRIC WATER HEATER
RELIANCE ELECTRIC WATER HEATER Logo
579 people viewed this question
Top Reliance Water Heaters Experts
Mack Baxter
Gil Shultz
Paul Nielson
Paul Nielson
Are you a Reliance Water Heater Expert? Answer questions, earn points and help others
