Question about HP PAVILION DV4000 AND V4000 SERIES (FF)MOTHERBOARD - 403895-001 CD-ROM Drive
NIC Connection question, Manual in XP, Automatic in Linux
My computer is setup wherein I can dual boot either Windows XP or Linux. Initially I have been using Linux only when I had my broadband internet set up and it works like a charm. Problem is, On the same computer, when I boot into windows xp, my internet connection goes limited or no connectivity, so i have to get the IP address, subnet mask etc from my connection in linux (because it connects automatically in linux) and configure my connection MANUALLY in windows so I can connect. Why doesn't it connect automatically like in Linux?
  • D Anax Jul 29, 2009
    Please ignore this question for i have found the answer by myself. As for your solution yboyandrei, I don't think it is dependent on LAN Card configuration, and furthermore, your GRAMMAR is horrendous, you must have worked as a tech support for DELL in india! For I did not understand your solution at all!
    For those who may also wish to know the answer to my initial query, the answer is:
    It is dependent on the ISP itself, whether the system they are using for their routers is BSD based. BSD (Berkeley Software Distribution) meaning Unix or Linux based distros. I found out that most windows systems use zeros-broadcast addresses, and with linux, most of them are configured with ones-broadcast addresses. Therefore causing me to manually configure my dsl connection when it comes to windows. in layman's terms, i found out that my ISP is actually Linux based! and if i want to connect with windows, I'd either have to manually configure it or edit my windows registry for it to connect automatically. Go figure! Cheerio!
    President:
  • 828 Answers
Its depend on your LAN Card Configuration, something it obtain or directly detect your internet connection but sometimes its not. That is why to make sure that you can connect you manually put IP Address on it. Uncheck the limited or no connectivity on the Lan Setting to make that when you are using Obtain IP Address then it shows and detect your Router or Hub with internet provider.
Posted on Jul 29, 2009
  • Francis Mark Arango
    Francis Mark Arango Jul 29, 2009
    Then why you ask some solution then you know already the answer, and what about if it is not that solution is true. Then how you supposed to do. To figure it out is to have any idea with somebody, i'm not an expert to say that i am correct, to see and actual to believe is very important. Got that, yoho!
Is this computer able to dual boot win 7 and xp
Which version of xp are you trying to install 32 or 64 bit ?
Your ability to install a second operating system on your Windows 7 system hinges on one thing: partitions. If your computer has only one partition, you can't dual-boot your system without erasing all information on your computer. Two hard drives, or two partitions, enables you to dual boot. Check this information first, before proceeding.
Click "Start" and type "disk management" into the search bar. Click on "Create and format hard disk partitions" in the list of programs to open "Disk Management." Look at the list of partitions and available drives. The information here will be different on every computer. "C" is your primary hard drive and active operating system partition, and this drive contains your Windows 7 installation. You can't install Windows XP here without formatting the system. Check for secondary drives and partitions in Disk Management. Your system may have a "D" or "E" drive. Some computer manufacturers create a hidden partition with recovery software: don't remove this partition. If you have a secondary partition called "D" with more than 2GB of free space, you can install Windows XP here. b> Installing XP b> Insert the Windows XP Setup disc into your CD or DVD drive and close any windows that appear. Shut down your computer with the disc in the drive. Turn the computer on and look for a message saying "press any key to book from CD." Press any key on your keyboard when this message appears. Most computers are configured to look to the CD or DVD drive first, before booting to the operating system. If your system doesn't recognize the disc, you will have to enter your BIOS and change the boot order. Look to your manual for information on changing the boot order. Press "Enter" on the "Welcome to Setup" screen to load the Windows XP setup program. Read the license agreement and press "F8" to accept. Windows will detect that an operating system is already installed on your primary partition and present a list of other partitions to install XP. Use the arrow keys to select your secondary partition ("D") and press "Enter" to confirm that you want to install XP here. Then choose what to do with the partition: leave the file system intact or format the partition using FAT32 or NTFS. Windows XP supports both file systems, but requires NTFS on partitions larger than 32GB. You don't need to format the drive to install XP. Follow the prompts on screen to enter your personal information, serial number, and date and time. The setup program copies files to your PC and reboots -- don't press a key to boot to the CD. When you have to operating systems installed, a DOS screen appears asking you to choose an OS; press the down arrow key to highlight Windows XP and press enter to complete the setup. You will have to choose this every time to boot into XP, otherwise your computer will boot to Windows 7 by default. Hope this helps.
b>
Jan 06, 2013 | HEWLETT-PACKARD Pavilion Desktop with AMD...
Tip
Unable to start Windows
Before we start, always check there are no USB devices/drives attached, or any discs in the cd/dvd drive.
If there are, remove them and try to boot....
Still no windows?......Read on
Depending whether you have a recovery disc, or a full version of windows, you still may be able to repair your installation.
If you have a recovery disc, and you can use it, you will restore your computer to factory fresh state, you will loose all your files/programs. (If you wish to do this you may want to save your files, to do this follow the "LIVE" linux install option (bottom of page)
If you have a windows disc (the same copy as you have installed on your computer), try this....BASED ON WINDOWS XP, JUST GOOGLE WINDOWS REAPAIR INSTALLATION + VISTA OR WINDOWS 7 FOR INSTRUCTIONS ON THOSE OS'S
  1. Boot the computer using the XP CD. You may need to change the boot order in the system BIOS so the CD boots before the hard drive. Check your system documentation for steps to access the BIOS and change the boot order.
  2. When you see the "Welcome To Setup" screen, you will see the options below This portion of the Setup program prepares Microsoft
    Windows XP to run on your computer:
    To setup Windows XP now, press ENTER.
    To repair a Windows XP installation using Recovery Console, press R.
    To quit Setup without installing Windows XP, press F3.
  3. Press Enter to start the Windows Setup. do not choose "To repair a Windows XP installation using the Recovery Console, press R", (you Do Not want to load Recovery Console). I repeat, do not choose "To repair a Windows XP installation using the Recovery Console, press R".
  4. Accept the License Agreement and Windows will search for existing Windows installations.
  5. Select the XP installation you want to repair from the list and press R to start the repair. If Repair is not one of the options, END setup. If repair is available.....
  6. Setup will copy the necessary files to the hard drive and reboot. Do not press any key to boot from CD when the message appears. Setup will continue as if it were doing a clean install, but your applications and settings will remain intact
IF the repair option is not available, and you continue to load windows, you will loose everything.
LIVE LINUX INSTALL (google "live linux distro")
IF you want to save files/documents before a recovery or clean windows install, you can download various " LIVE" Linux distrabutions.
You Burn these to a cd as a bootable ISO file ( imgburn is a free burning program that will enable you to make bootable ISO discs).
Some linux distrabutions have built in recovery tools/virus scanners.
Once you have recovered your important files, you can either carry on with the windows recovery, clean install.... OR...you may find that you like LInux, if so you can fully install the linux OS and if its not what you want, Install Windows back in.
After installation dont forget .......
1.Download and install your security programs (Anti-virus/Anti-malware)
2. download drivers from your manufacturers support page
3. turn automatic updates on
NOTE............When you are up and running, and want to transfer any saved files you may have recovered..SCAN THEM with your Anti-virus BEFORE you put them onto your nice clean PC.
All of this information is available freely on the internet, just google your relavent question.
on Jul 18, 2010 | Computers & Internet
I have want to setup Windows xp and windows 7 together .Meaning when start up computer have : Windows xp Windows 7 I try to setup two windows ,but i setup windows xp lost windows 7 and setup windows 7...
Not sure what you have done so far. You need to divide your hard drive into two sections. Install XP first on to one section. Then use a program to manage your computer start up, the one I use is called Easy BCD this is a free program and works great. Once you cut your hard drive and install XP make a copy of your start up partition. Install the Easy BCD program and make a back up again. Then Install Win 7. Then on the Win7 side install the Easy BDC program and set up the menu choices. I run a 3 way boot with XP and Ubuntu. Hope this helps Fix Ya up.
Jul 09, 2011 | Computers & Internet
I need to setup a dual boot computer. I have 2 hard drives each has an os I need the option to select at startup
Try Install KDE on your desktop, I think its much better than gnome for booting setup. There's another way which one you'd like to booth by striking the F8 key repeatedly on the restart or starting your PC and select the drive which drive you like to boot.Or you can configure it on your bios setup by hitting the del key and configure your boot priority.
Sep 11, 2009 | Microsoft Windows XP Home Edition
Computers
Yes you can dual boot linux and windows. Install windows and then install linux. The linux screen will show first and you can change the booting sequences.
Jul 07, 2009 | IBM OS/2 WARP 3.0 Full Version for PC,...
Boot loader problem
I beleive that you are installed windows first and linux second,then dual booting will be configured automatically ,means linux will install the grub (boot loader)and configure it with what all Os u have.If your system is not booting and showing grub menu do one thing ,boot it from a linux cd and reinstall grub.
Oct 31, 2008 | Microsoft Windows XP Home Edition
Dual Boot Ubuntu
1st, install windows or if you have already its good .
Then, download Linux distribution that suits You better
Download It and burn into a CD or DVD with ISO file you can use Magic ISO or other manufacturer
then Go to BIOS setup and set 1st priority is the CD or DVD drive and save and exit
and install follow the instruction of linux.
also if you chose capacity of windows or linux is to little dont worry you can make install a partition magic and resize what you like....
PS:
pls rate me if my solution solve the issue and you need more further information. but if is invaluable solution rate me fixya.
Sep 07, 2008 | Canonical Ltd. Ubuntu
USB mouse won't work under XP in a dual boot Ubuntu GRUB 1.5
It has the latest mouse driver (logitech setpoint 4.0). Before installing Ubuntu the setup worked w/ SUSE/XP using GRUB dual boot. After installing Ubuntu XP does not see the usb mouse. Even Logitech setpoint does not have the mouse setup/configuration option. It appears that at boot it does not recognize the mouse or disables it. The BIOS has the usb keyboard and mouse enabled. Currently, I have two mices one for xp and either mouse will work under Ubuntu.
Sep 03, 2008 | Canonical Ltd. Ubuntu
Linux Connection to WGA54G
first, check your cable. loose cable connection often lead the cause of that error. second. check the lan card of your linux pc. If your pc is a desktop type pc, try to replace the lan card and . Make sure that the lan card is detected by your system. try to connect on the internet again.
A Simple Thanks is Good Enough
Feb 13, 2008 | Linksys Wireless-G Game Adapter [ WGA54G ]...
Where is Linux mbr file
There's nothing like the Linux MBR File. The option to boot to multiple operating systems is controlled by a software called as the "Boot-Loader".
Windows XP and Linux both have their versions of boot-loaders. The Bootloader that Windows XP uses is called the NTLDR, whereas Linux provides many bootloaders (prominent among them being "Grub" and "LILO").
>but Linux is shown in the manage option from the My Computer in Win XP 2.....
That is the control section of NTLDR. So from what I understand you shouldn't have a problem selecting the operating systems.
If you want the Linux bootloader taking control of the boot process, you can always install it.
All you need is a Linux CD and then run the setup for "Grub" or "LILO".
Information about installing Grub or LILO can be found easily on the internet.
Oct 19, 2007 | HP Data Protector Express Software...
Computers & Internet Logo
78 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
