Question about Canon FAXPHONE L80 Laser
Canon faxphone L80 parts available? paper feed shaft broke in half
  • 19 Answers
The L80 printer guts are very similar to the HP 5L and HP 6L printer (Not well known, but the printing engines on many HP printers are made by Canon). In fact it is almost possible to use a 5L/6L toner cartridge in the L80, but as I recall there was a plastic nub that prevented it from fitting properly. This is probably meant to force the user to buy more expensive Canon toner carts instead of using cheaper generics for the 5L/6L. Try HP PartSurfer and you may be able to locate the part that you need.
http://www.partsurfer.hp.com/cgi-bin/spi/main
Posted on Sep 07, 2009
My fax machine only feeds paper to one side when I'm sending a fax. I cleaned the roller with WD-40 but it still only rolls to the right.
Most of the times there is a dockument stop arm thac6cfff.jpgat broke that cause the paper just to feed one side.What you can do is to remove this arm.I have pointed with a sckrew driver this part.After removing this document stop you will be able to use the fax while ordering a new part.
Aug 27, 2009 | Canon FAXPHONE L80 Laser
I have Paper Jam Display on my Canon Super G3 Fax phone L80 FaxScreen.
There is most likely a piece of trapped paper where you cannot see it and it is covering a jam sensor. Try to cheat the machine by turning it off and remove all the printing paper. When you turn it on look down where you see the paper normally feeds and see if you can see any rollers turning. Then, try to take a sheet of paper and feed it through were the printing paper usually goes. Open up the cover where the cartridg goes as well and you may see the trapped paper move when you feed through your piece of paper. Remove the cartridge if necessary to get a good look and see if paper is trapped near.
Jul 08, 2009 | Canon FAXPHONE L80 Laser
Retrieval of faxes in memory
Press the stop key and it will resume printing
Apr 07, 2009 | Canon FAXPHONE L80 Laser
When sending a fax on the faxphone L80 it pulls in duplicate page
There is a little rubber pad where original feed in. Look at it on edge and you'll see it has concave wear. Carefully remove black plastic hold down and flip rubber pad over. You'll have to make a new hole so it will lay flat.
Apr 06, 2009 | Canon FAXPHONE L80 Laser
Canon faxphone L170 won't copy
if you look at the top piece of paper in the cassette is there a smug mark or wrinkle in the paper. you my just need to clean the feed roller. ( black or gray roller ) . I'm not sher on this model if it is a rear paper feed or a cassette from under if it is a back feed one look in side the paper shoot of any fourn object is in there. Hope for the best.
Feb 02, 2009 | Canon FAXPHONE L80 Laser
My canon faxphone l80 can not be loaded paper, once I load paper in the tray, the monitor still shown load paper
Please shut down the unit and remove all paper. Wait ten seconds turn the fax backon without paper. mAKE SURE THE FAX IS ONLINE. hAVE SOMEONE SEND YOU A FAX SO THE MACHINE DEMANDS THE PAPER. SEE IF THIS WORKS
Jan 19, 2009 | Canon FAXPHONE L80 Laser
Fax says Paper Jam but there isn't one!
After what operation does the machine report the jam. If it is trying to print something and the paper doesn't pull, then it will report a paper jam, even though the paper didn't move. If this is the case then the paper feed tire behind the toner is dirty. Cleaned with rag and rubbing alcohol.
Apr 08, 2008 | Canon FAXPHONE L80 Laser
PAPER FEED
the drum of toner crtridge has expired chande the drum if available,otherwise change complete toner cartridge
Sep 17, 2007 | Canon FAXPHONE L80 Laser
Canon FAXPHONE L80 Laser Logo
476 people viewed this question
old marine
old marine
