It worked last night, I turned it off prior to bed. When I tried to turn it on this morning it would not start. I plugged it into my laptop and wall plug and it still would not turn on or charge.
SOURCE: Gateway Laptop
Battery poles are giving problem. Its the port connecting the battery to the laptop either has a short or just stop working. Check that & get bac @ me! Thats the problem.
KJ
SOURCE: archos 404 not charging
Dont use the USB to charge the 404. Use a wall charger that accepts USB. Wally world (Walmart) has one for 15 dollars that has 2 USB ports. It works for me. Also the docking station will charge the 404 in no time at all. It's 80 dollars. Make sure you get the generation 4 unit
SOURCE: wont turn on
Laptops are far more prone to be taken out by even minor power surges then anything else in your home, including desktop computers.
If you have any method (multimeter etc) to check the voltage from the power supply you may have been lucky and it took the bullet to save the laptop.
If the power is registering in the correct range, around 18volts, then chances are your laptop has taken the hit and the motherboard is gone.
If this is the case, then before you throw it against the nearest wall, take it to a laptop repair centre. It "may" have been saved by a fuse on the motherboard and therefore protected itself as best it could.
Prices to have it looked at will vary alot, so call around.
SOURCE: My Creative Zen Mozaic 4GB won't turn on
Use the reset button located on the left side. Worked for me!
SOURCE: Garmin 200 won't turn on, flashes "Garmin" screen when plugged in
I connected the unit to the car charger instead of the USB charger and then held down the reset for 10-15 seconds, after which the system would show the computer connection on the charger and then boot up when not on the charger.
