Question about Averatec 2260-EH1 (AV2260EH1R) PC Notebook
Fan is always on - Averatec 2260-EH1 (AV2260EH1R) PC Notebook
    Master:
  • 404 Answers
Use the manual. find out how to get to the bios menu. in the bios menu there is an option to chose how you want your fan to run.
advice: fan always on is a better and safer for your laptop.
Posted on Jul 29, 2009
Why does my fan on my Gateway ZX4931 always run loud?
does it has variable speed feature?, clean the heat dissipator, is clogged with lint and hairs! and always runs @ full speed, also if you're already there, might as well reapply thermal grease to the thermal dissipator.
ALSO, because you will have the fan dismounted, is so cheap you can put a NEW QUALITY fan (or fan dissipator combo) sometimes bearings gets loose and the axle wobbles (because of costs all OEM fans runs on cheap bushings) new aftermarket PRO-fans runs on ball bearings.
did you checked if a loose wire is not touching the fan blades?
Aug 06, 2014 | Gateway Computers & Internet
Mb vito cooling fan always on
relay or switch goosed relay not getting signal to disengage fan
Aug 26, 2012 | Cars & Trucks
The fan is constantly running, is this normal?
the fan on the trailblazer is attached to the water pump which is always spinning so yes the radiator fan always is running,,its mechanical,not electrical fan
Oct 19, 2009 | 2002 Chevrolet TrailBlazer
1993 Maxima fan always on
the fan resistor is causeing this!! the resistor has different size coils for each fan speed. so if the coils burn out. no fan speed on that setting.
Oct 07, 2009 | 2006 Nissan Maxima
Fan always running
vacuum out air ports/power supply fan or use compressed air in a can to clean out dust.
yes this is bad, life is greatly reduced.
clean dust out once every other month or as needed.
Oct 02, 2009 | Computers & Internet
Old 1972 Fedders centeral air fan will not always come
Since its a 1972 its probably called a fan center---------combination fan relay and transformer and they are still available.
Jun 14, 2009 | Fedders A6X05F2D Air Conditioner
Replacing old fan with Hunter 20763.
People find all kinds of creative ways to wire things. White wires are always supposed to be neutrals and therefore should always go with other white wires, and colored wires should always be hot and should always go with other colored wires. If you have a voltage tester you could test to see if in fact the blue wire is actually the hot and the white is actually the neutral. (test each wire to a ground). If the previous fan was wired backwards, it would not affect the operation of the fan or lights at all. But you'd probably want to make sure the new fan was wired properly. In that case connect the white from the fan to the neutral and the black and black/white to the hot.
Jan 30, 2009 | Hunter 52" Ceiling Fan With Light And...
Cooling fan always runs with ignition on
try putting the electrical connector on the other way
Jul 29, 2008 | 1992 Saturn SL2
Averatec 2260-EH1 (AV2260EH1R) PC Notebook Logo
41 people viewed this question
Top Averatec Computers & Internet Experts
k24674
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
