Describe your gateway 7508gx notebook
Flickering screen I send my laptop to gateway when it was on guarantee I they said that they replace a part that was causing the flickering on the screen but after some month it started again so I will like to get some manual on how to open up the laptop and replace the ribbon.
    Master:
  • 404 Answers
I beleive the part they have replaced is called the inverter. I found a link here with pictures how to do that.
http://www.instructables.com/id/How-to-Take-Apart-a-Laptop/
hope this helps. you need screw drivers and patience
Posted on Jul 29, 2009
Taking my laptop apart
On which part of your laptop, you get stuck in openiing it..?
May 30, 2008 | Gateway 7508GX Notebook
My laptop screen flickers when I connect the power adapter to it.
Hi
And it still flickers? Have you tried attaching a secondary monitor? If the external monitor is not flickering then the problem is the inverter for the laptops screen. If you see the flickering there then the problem is on the laptops mother board, maybe power regulation or video processing. If this is the case it will mean a mother board chip replacement.
Mar 29, 2010 | Gateway M305CRV Notebook
I have a Gateway M-6843 Notebook PC that won't power up.
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
Sep 06, 2009 | Gateway 7405GX Notebook
Describe your Toshiba Satellite® L10 PC
You most likely have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :- To determine if you have a LCD screen or video card problem, read this and follow the instructions. Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case. The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills. Check out www.lcdparts.net for parts, repair service and DIY info.
Jun 04, 2009 | Toshiba Satellite L10 Notebook
Backlight flickering
Matrix. Backlight lamp is flicking, you shoud change the matrix. If it is in guarantee, that is not you priblem, but if it is not..... the cheapest way is to find someone to chenge just the lamp. if you can
Apr 28, 2009 | Acer TravelMate 5720-6635 Notebook
The power button is stuck in OFF position. How do you disassemble the laptop to fix it?
i suggest you do that. this takes time, patience, the right tools, and a perfect memory for where parts come from
Oct 20, 2008 | Gateway 7508GX Notebook
About my laptop
http://www.fixya.com/ThreadView.aspx?thid=634141&prdid=485713
Gateway 7510 DVD PLAYER
Look for an external swicth, to pull the drive out. If your laptop dont have it remove the bottom screws, the remove the
keyboard, finally you can push the cd drive out of the computer
Let me know if this post help you.
Dec 20, 2007 | Gateway 7508GX Notebook
Computers & Internet Logo
David Payne
David Payne
