Question about GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator-freezer GE TBX 181ABQRWW does not stop working. Is this a thermostat failure? EP
  • epp8 Jul 29, 2009
    Yes, compressor runs constantly for at at least 6h, then breaks for 10-15min and starts again.
  • ddieringer May 11, 2010
    Do you mean that the compressor runs constantly?
2 Suggested Answers
  • 103 Answers
SOURCE: freezer works refrigerator doesn't ge tbx-25zle
Hi: Your defrost heater or defrost timer is bad. There is an off chance your freezer or fresh food compartment are so full they block the airflow. If not full, Remove the food from the freezer, unplug the ref. and hit the back wall of the freezer with a hair dryer. Avoid plastic components as they will melt. When your defrost mechanism fails frost will form where it shouldnt and block the airway to the fresh food compartment. That's why the freezer still works. That will get you a week or two of fresh food getting cold. If your'e handy remove the back panel of the freezer at the bottom will be a glass tube with a metal coil in it. If the coil is broken buy the new defrost heater and install it. If not look for a defrost timer. Use the model number of the refrigerator to find the part. www.searspartsdirect.com will have a parts schematic to help you find out where the timer is located. There shipping is high so try to buy it locally. I hopes this helps, Jeff
Posted on Jun 25, 2009
I have a GE TBX 22Z - just recently, the refrigerator half has almost stopped working. The freezer half works fine - everything stays very cold. The bottom half, however, gets quite warm and has even had...
Push gently on the back wall of your freezer. If you hear a crunching sound resembling snow under foot or dry leaves being stepped on, you have a frost buildup. Your fan may still be working, but your entire refrigerator depends on that fan being able to draw air over those blocked and frosted up coils. The most common cause of this is a dead defrost thermostat. The second and third problems are the defrost timer or defrost heater. Spin your defrost timer (located near your Temperature control, it's in a small hole with no screw in it) till it clicks and check the freezer wall to see if the frost starts to steam and melt. If not, unplug the fridge2_bing.gif, then try disconnecting the defrost thermostat (usually clipped onto the main freezer coil at the top) and join those 2 wires together. Replug and see if the heater starts steaming. If it doesn't it is most likely the timer. The heater is usually the last thing to die, unless your heaters2_bing.gif are encased in glass. In which case a quick visual inspection for decay and separation will pinpoint the problem.
Mar 13, 2010 | GE Profile 21.6 cu. ft. Top Freezer...
We have water om the floor under the laft fronmt corner of our fridge/freezer . Model tbx 22pr
WHAT IS WRONG WITH YOUR REFRIGERATOR?
small_4_1.jpg For a detailed Refrigerator illustration, click below.
redarrow.gif Side by Side
redarrow.gif Freezer on Top
redarrow.gif Freezer on Bottom
redarrow.gif Under counter
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
It's stopped completely
It's not cool
Cooling is poor
It's noisy
It leaks
The freezer compartment is icing up
The food in the refrigerator freezes
There's water dripping inside the refrigerator
The refrigerator never cycles off
The ice maker has a problem
There's an ice- or water-dispensing problem
Try to check the defroster heater this cause the problem;
Jul 30, 2008 | GE Refrigerators
Variance in freezer compartment temperature
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost heater, defrost thermostat. If the heater and thermostat are ok it’ll be the control board.
Sep 04, 2009 | GE GSS20IEM Side by Side Refrigerator
Ge frig does not freeze on freezer side
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Aug 25, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
The refrigerator and the freezer is not working properly, the food is thawing in the freezer and the refrigerator is not staying cold. The compessor is running and blowing cool air. It just started...
Possible defrost problem. If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air.Since you've already replaced the motherboard Checkdefrost heater, defrost thermostat
Aug 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Each side won't get cold. food starts to spoil
Jul 13, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
We got home from work yesterday and the refrigerator was HOT inside.
How to check stuff
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Jul 10, 2009 | GE Profile PCF25PGW Side by Side...
I have just replaced the mother board in my GE side by side and it still does not seem to be cooling what else could be the problem.
check
Jul 06, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer works refrigerator doesn't ge tbx-25zle
Jun 25, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator 50degrees; freezer 10degrees suspect fan outage/ge
I bought a wine cooler but I want to change the door I would prefare the door frame to be black
May 26, 2009 | GE Refrigerators
GE (PSS26MSRSS) Side by Side Refrigerator Logo
183 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
