Question about Canon imageRUNNER 400S Copier
No print, e805 and e014
An error occur e 805 and sometimes e014 on my gp335, then on my gp225 there is no print but it has no error. anybody there? pls help me to solve my problem.
  • 37 Answers
The E 805 refers to a locked up fan motor, and the e014 is for the fuser (the part that get hot) not turning correctly. both of these problems require a technician to fix.
Posted on Jul 30, 2009
I have ir 2016j indicating E805, what is the cause and the solution
The heat discharge cooling fan failed to function. Problem is usually resolved by replacing the bad fan motor assy. If not, the DC power supply is probably bad.
Dec 03, 2014 | Office Equipment & Supplies
E805
Hello Peter; E805 is cooling fan problem;
0002& 0003is fuser fan, 0004 to 0006 is laser fan 0007 is exhaust fan, 0008 system fan, 0010 & 0011 low voltage fan, 0012 & 0013 reader fan, 0014 to 0016 drum fan, 0017 is controller fan, 0018 scanner fan.
Oct 06, 2012 | OCE 3140 Copier
CANON GP405 ERROR E014 PROBLEM
sir i have ir 400 photocopir machin than problem is e803,e805 than coad plese give me soulison...............
Jan 06, 2012 | Canon imageRUNNER 400S Copier
Canon xerox
E805 error code means failure of one of the many fans inside the copier. If there is not a dash with four numbers after the 805 code on the display, it is one of two fans - FM1 the transport bed fan or FM9 - the reversing fan just below the fuser assy. There are several checks that can be done but a too lengthy to be described. A tech maybe the best answer depending on your mechanical ability.
Jul 03, 2009 | Canon imageRUNNER 400S Copier
Ir400s cannon i am getting error 805
if you can go to service mode check the sub code of E 805 (means one fan motor is not working properly )the sub code tells
which fan is faulty
Jun 15, 2009 | Canon imageRUNNER 400S Copier
Canon ir 400 photocopier
i have ir400 in my machine. first e805 code has been displayed and after that it shows that to load paper. then after e803 code is displayed. please help
Jun 03, 2009 | Canon imageRUNNER 400S Copier
Error codes
E000 and E001 is due to the laser unit, I can explain in more details.
E014 is due to the Dc motor failing
Hope this helps?
Oct 17, 2008 | Canon imageCLASS MF8180C All-In-One Laser...
Error code
805 codes are usually associated with fixing exhaust fans not powering up. Usually due to a blown SMD (Surface Mount Device) fuse on the DC controller PCB.
Aug 29, 2008 | Canon imageRUNNER 400S Copier
Canon Error Message
An E805 code has to do with the failure of one of the many fans within the copier. If there is not a dash with four numbers after the 805 code on the display, it is one of two fans - FM1 the transport bed fan or FM9 - the reversing fan just below the fuser assy. There are several checks that can be done but a too lengthy to be described. A tech maybe the best answer depending on your mechanical ability.
Oct 14, 2007 | Canon imageRUNNER 400S Copier
Canon imageRUNNER 400S Copier Logo
442 people viewed this question
old marine
old marine
