Adding machine freezes, no buttonsvwork - Office Equipment & Supplies
    Sergeant:
  • 360 Answers
Uh... Mary, d'you mean you have an adding machine which freezes, or you're trying to add a machine to an existing system, and the system freezes, or what, please?
Either way, has it always done this or what's changed, please?
Posted on Nov 06, 2017
SOURCE:
My truck was running fine one DAy the next day it was blowing steam I looked under my truck no leak I checked the reserve for anti freeze it was empty I filledand the next thing you know antifreeze c
If there is a crack in the head leading into the crankcase the water could be dumping into the oil. Look at the dipstick. Also, water could be dumping into the exhaust ports. I think you need a mechanic smarter than you or me.
Feb 03, 2015 | 2005 Ford Explorer Sport Trac
My fd100 wont print but thinks it is. also some times it freezes
if you could check the paper that you are using. make sure thermal. also scratch the paper, if a black mark appears this is the side that goes down in the paper holder, if you don't see a black line you don't have thermal paper. also make sure it is credit card machine and not adding machine paper. if you have another roll try that one. if persist. make sure the paper is hitting the thermal reader. there is no ink
Jul 17, 2014 | FirstData First Data FD100 Thermal Paper...
How many gallons of antifreeze will it take ?
Anti freeze is mixed on a 50/50 basis. The coolant capacity varies so check the hand book for capacities and mix the anti freeze to water before adding to radiator. Drain radiator first so as not to mix different anti freeze products.
Nov 09, 2013 | 2005 Toyota Matrix
Should you add additional water to a 50 50 antifreeze mix ? My son it is ok but now my car is over heating
A 50/50 mix is a ideal. Antifreeze has two benefits when properly mixed. It protects the coolant from freezing down to -40 degrees Fahrenheit and it helps remove heat from the engine. Diluted coolant in the short term is not harmful. Long term it could lead to the accelerated corrosion of vital cooling system components. Anti freeze also offers lubrication to the water pump. Less concentration will equal less lubrication. If your son is adding water than there is a leak. Adding water until the leak is fixed is fine as long as the temps don't get below freezing and the problem is addressed as soon as possible.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Apr 09, 2013 | Cars & Trucks
What type of antifreeze for a 2001
Apr 09, 2013 | 2001 Hyundai Elantra
Wat will happen if my coolant light came on and all i had was regular anti freeze,the 50/50 and i put some in my 2002 745li bmw
If you are only adding a couple of litres, the freezing point of the coolant will be altered very slightly. The important thing to check is that the antifreeze you are adding is suitable for alloy engines. If you add water the freezing point of the coolant will be raised, again very slightly if you only add a couple of litres
Apr 03, 2013 | Cars & Trucks
What's the pretreatment phase in the freeze-drying process?
The pretreatment phase includes concentrating the product, adding components to increase stability. In many cases the decision to pretreat a product is based on the theoretical knowledge on the freeze-drying process. There are many method of pretreatment including freeze concentration, formulation to stabilize reactive products, formulation to Increase the surface area etc.
Aug 09, 2012 | Camping, Backpacking & Hiking
Antifreez type 1991 volvo? 4cyl
Volvo would like you to believe you need their o.e.m. and pricey anti-freeze to keep your cooling system from falling apart. NOT! Any good quality anti-freeze will perform well. Just be sure to mix it 50-50 with water when adding or changing, or using the 50-50 premix that's sold ready to use. More expensive because you're paying anti-freeze prices for water! I have used off-the-shelf anti-freeze in all my Volvos, which run 300,000 miles or more. You can extend the life of your radiator, water ump etc, but flushing the system every year or so, draining off the old coolant and adding a fresh mix.
Apr 19, 2010 | 1991 Volvo 740
Adding machine problems
how do I clean the printer roller on a Texas Instrument TI-5130 adding machine?
Apr 24, 2008 | Office Equipment & Supplies
k24674
Marvin
Marvin
