Question about Frigidaire Washing Machines
Is there suppose to be a spin cycle between the wash cycle and the rinse cycle on the LTF8000. My three week old machine does not and leaves soapy water during the final spin.
  • 2 more comments
  • bdeacy Jul 29, 2009
    Thank you for your prompt response. I did see that it is a reversing tumbling water pump-out but then only some small amount of water pours in from the top - not much and this repeats a few times but the soap is still there as it goes into final spin and there are times when the spin is noisy an sounds like something is vibrating and it does nopt sound like the clothes basket but something in or near the motor. We are careful not to over soap and we use HE soapas recommended. We first noticed this on the sanitary cycle where it did not even do a final spin.
    Thank You Dennis,
    I did prepare another response but it disapperared from my computer although you may have received it anyway. The machine is only three weeks old and we have only used the recommended biodegradable liquid soap in the specified amounts so there should not be any clogged soap in the lines. Apparently the rinse cycle is not suffucient to remove the soap. Further, how do we explain why there was no final spin cycle at the end of the long sanitary cycle?
    Thanks for now! I'll let you know how this gets resolved. Have a nice day
    Thanks for the quick answer. I am still working on an answer as to why there was no spin at all at the end of the sanitary cycle and why there is still soap in the rinse cycle and final spin when I did not put soap in the machine. I think that the clothes are holding soap and that the rinse is insufficient.
    President:
  • 1,124 Answers
Depending on the unit - there is usualy not much of a spin between wash & rins..
Some machines have a slow spin just before rinse..
I dont think you have anything to worry about..
Posted on Jul 29, 2009
    Brigadier General:
  • 4,090 Answers
Its not usually a real spin cycle it is more of a water pump out cycle of the wash water. the drum does rotate to achieve this of course but not usually strong enough to completely remova ALL water from the clothes
  • 1 more comment
  • dennis bullard Jul 29, 2009
    I see! This is a front load . But the problem will be the same .
    Let me try to explain what and why this may be happening. On the pump out cycle it pumps or appears to pump out most of the water, but as it slows ( thinking that it has completed its cycle due to the water sensor) it has back slosh and so water is returned to the basin.So if one was to inspect the inside there will be soapy water still unpumped from the machine.
    Now to the usual cause. the pump is encrusted with built up sludge from soap powder. Most times this pump has to be taken apart by a technichian and the pump replaced as well as the seals.
    Sometimes it can be fixed by running a very hot wash cycle without cloths ( if it has a suds return function bring the water back and run it from wash again. After sevral washes it should begin the wash out some of the restrictive soap buildup.
    If this does not help to improve the problem it will require proper intervention.
    How to avoid this in future... use a liquid soap ( Biodegradable is best ( new earth brand) and less of the soap powder types as these are the worst offenders and sell a lot of pumps for the repairshop.
    Do hope this is helpful to you
    dennis
    ohh! that makes it different How did i miss that!! I must go home and rest i think 14e hours on duty has sogged my obeservation powers
    Well if it isn;t soap then the only conclusion i could possibly arrive at is that some small object a little more than just lint is occluding the pump out (.tissues?) these are often left in pockets and disintegrate sufficiently to cause blockages.
    Regarding the loss of final spin , yes that is a definite problem that needs to be addressed. i assume you experience this all the time. If it has not done this properly from new, then i would be asking for it to be rectified by the repair people from the place you bought it. the machine is under warranty and one would it to work correctly when it is new. failure of one of the solenoids in the program is dysfunctional and needs rectification
    Found this on another site ...
    The reason the washer won’t spin is due to the either of the latches on the door.
    This model uses a two stage lock that latches the door when the
    load starts, and then when it is time to spin, the second lock engages
    to ensure the door is properly secured prior to beginning the spin.
    When this second lock engages, it also closes a set of switch contacts
    (the auxiliary door switch) telling the control board the door is
    closed and locked. If for some reason this switch is not closed, the
    washer will tumble during what would normally be the spin cycle until
    the entire cycle is complete.
    On the entire Frigidaire ATFxxxxxxx line of front load washers, if the secondary door lock fails,
    the unit will not spin. If you suspect this is the reason your washer
    is not spinning, do a check of the error log and you will find an E47
    error has been logged. This error indicates the control board thinks
    the wax motor has failed because the auxiliary switch never closed. The
    customer will not see this error in the display, but it will be stored
    in memory. A quick resistance check of the wax motor will tell you if
    it has failed. Expect 1K to 1.5K of resistance from most of the wax
    motor heaters.
The water is still soapy after many rinses. I am using very little soap
I am having the identical problem with a Maytag washer! The first 2 or 3 rinses are effective somewhat, (but not like the Whirlpool I had for 22 years) and I think, "one more for fabric softener"---but suddenly I have a full inch of bubbly white, white, very soapy suds! Picture half a washer of water with a cup of tide! It's that soapy and I cannot figure out where the soap is coming from! Tonight, I had not even used a regular soapy detergent in the previous 15 cycles, having switched to an eco detergent from Costco and used little. I even ran a few cycles with no laundry and no detergent--no soap then!
Btw, the washer has only cold water rinses--I had not noticed the tiny print on the front of the washer--or I'd never have bought it. We learned in fabric class that icy cold water (it's snow melt here in Oregon) shocks fabric as badly as hot water, and it fails to get soap out as well. And everything comes out scratchy stiff like cardboard, and hurts my face--skin even peeled before I began opening lid to check on rinse cycle. I got rashes and dry skin from all the soap and ice water...until I began doing 7 or 8 rinse cycles on the items like washclothes, towels etc. Clothing gets hardly any soap, or I hand wash it now--am exhausted and want new machine! Can't sell this junk tho.
Anyway, so the way I rinse with warm or cool (not melted snow) water is I stop the washer and start over the wash cycle to get warmer water for the rinse. Then, I move the dial to extra rinse cycle for the rest of the rinse, after the water has filled, so it cannot go on to do an ice water rinse after competing the "wash" cycle that's really a rinse cycle with no soap.
I would hurt the person who designed this washer! It seems to add soapy water back into the rinse on the 4th rinse cycle! Sounds bizarre, but I always think that everything is finally rinsed ok and one more with a little fabric softener will do it, but when I look inside to add the downey, there's an inch of suds on top! I don't have suds like that on my wash cycles! It's bizarre...I've wondered if neighbor's suds are coming in, or am I haunted?
Last week, I hand-rinsed my washcloths and kitchen towels and put them in washer for the spin cycle, at end of the rinse cycle, just to get water out of them for dryer.... To my dismay, the spray of water while spinning (have no idea why washers add icy snow melt to my warm rinsed laundry during the final spin but they all do, you can hear the spray) was soapier than my original wash cycle--which has a teensy bit of suds which is gone in a minute or 2! Honestly, my washcloths etc were fully soapy again! I'd rinsed them so well that immersing them in warm water left the water clear and clean, but after the spray, they were just as soapy as after the earlier rinse cycles that had the inch of suds... I had to take everything out and spend another hour hand rinsing and wringing befor the dryer....
I have taken to using pint-sized tupperware to get the suds off the top rather than letting it go into the laundry or washer. I skim it out and put it down the kitchen sink. It's so soapy I'd have to do dozens of rinse cycles to rinse it out, so I skim it out manually. So new soap must keep getting into the washer! It also does not seem to matter whether the wash is full or half. Tonight the previous rinse cycle had been full, and pretty clean. But when I o;pened the next one to add fabric softener, it was only half full of water, and an inch or soap suds. I had wondered if the soap was outside the basket, and came in through the holes, once water got that high, but no. Does not matter. And I had wondered if it was caused by suction from stopping the rinse cycle during spin...but I went load after load for 10 days, never stopping a cycle early and it still put all that soap in the 4th rinse cycle. Or in the 3 cycle's spin at the end of rinse, when it sprays water on the spinning laundry.... This is a horror. Maytag ignores my emails. The handyman says new washers are terrible and wants nothing to do with it. I wish I'd paid whatever it took to fix my old whirlpool. 22 years and never an issue ever, never more than 3 rinses and then only a 3d because I'd used double soap to get out dirt from gardening or road trips like Santa Fe in the winter when shih tzus got covered with red clay dirt used on snow and ice--that stuff is lethal! Normally I added fabric softener on 2d rinse cycle and things were so clean. Now things are not clean, come out ripped, or with pilling like they aged 10 years in one night. So I handwash anything I want to keep nice. Washcloths are getting frayed, towels look bleached or faded....and I am relating to my grandmothers on wash day. Sorry it's just more problems not solutions.
Jan 23, 2011 | Kenmore Washing Machines
Spinning cycle
Keeping in mind that the soap & bleach gets dispensed into your wash on the second to last rinse cycle and that most all rinse cycles are in cold water. Is your cold water valve screen plugged causing your washer to rinse poorly? Are you using the HE detergent? If not maybe the washer is sudsing up to much and having a hard time rinsing all the suds and bleach out and leaving the clothes soapy.
Fill the washer up with no clothes in it on a cold/cold wash setting does it take a long time to fill the washer up? Also when it is full and agitating is there suds in the washer?
Last suggestion is if the drain is hose is a lot higher than the top of the washer it might have a hard time draining out all of the soap water before the next load
Mar 23, 2008 | LG WM-2277HW Front Load Washer
The washing machine wont rinse - Kenmore echo care system
without more info its hard to tell but it sounds like a bad timer. can you advance it manually a few notches or run it in another rinse cycle.
Sep 04, 2009 | Washing Machines
Washing machine will not drain
TAKE THE HOSE OFF ON THE BACK {DISCHARGE HOSE} IF THE WATER FLOWS OUT IT IS THE PUMP MOTOR IF IT DOESN'T THERE IS SOMETHING BLOCKING THE OUTLET, SMALL CLOTHING ITEM
May 29, 2009 | Indesit W 123 Front Load Washer
Kenmore washer series 80, Clothes still soapy
If you are getting no water spray during the rinse cycle that would cause the soapy clothes issue.
Are you getting cold water during the wash/rinse cycles? If you have the machine set to warm/warm you may only be getting hot water while the final spin is calling for cold.
If you have cold water available then the timer is not calling for the water spray. The problem is either in the mixing valve or the timer.
Jan 10, 2009 | Kenmore 23822 Top Load Washer
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Maytag mah4000aww motor control board bad cannot tell which series it is serial 53312313yk
my front load washer is leaving water after done spin cycle can still ring water out of clothing....water is draining from hose and is spinning somewhat strange...like its not going through rinse properly sorta like its repeatedly doing same cycle pattern...spins for lil, stops makes running noses...spins sum more....soapy clothing...its 5 years old..but first time use this month finally connected it...when took bottom off to check hose connection noticed control board looked lil warped and brownish colored but not as meant to be..maybe its burnt out?
Apr 13, 2008 | Maytag Washing Machines
GE Washing machine won't spin in rinse cycle
Possible your outlet filter is blocked. This requires cleaning depending on your usage. Clean this out and refit. Good luck. Plug off the wall first.
Apr 17, 2007 | GE WJSR2070B Top Load Washer
Washing Machines Logo
106 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
