SOURCE: cannot open cd/dvd player--the player
If you examine the front of your cd/dvd drive, you'll see a small hole. Push a thin wire into that hole and the drive will open.cleaning the inside of the drive when it is open will also help.take care.
SOURCE: problem with cd player not playing
if the problem is with the lens and you can't get it clean, or the spindle motor does not spin, you'll need to replace the whole optical pickup. try mcm electronics. you may need to give them the actual part number from the pickup assembly.
SOURCE: Phillips Model #FWC85C3701 radio, CD player,
The drive belt might have gone brittle and broken or might have loosened itself. You will have to replace it. You can do it by yourself if you have the replacement part. You can get a replacement, but searching for an online purchase over the internet is a great wastage of time. You can never find such items on net. Instead contact your nearest dealer or repairman. You may just ask him where to get the part and he will direct you to the right shop in your locality.
Cheers. Thank You.
SOURCE: My seal hifi, model number w3 7rw when CD is put
The loading sequence is not completing the cycle when the tray door closes because of slipping belt, or the laser pickup assembly is faulty.
