Question about Ryobi Cultivator
We have a older Ryobi cultivator and the gas tank is leaking. We have tried everything to fix it.....Is there some place to buy a new tank? The tank has 2 holes coming out of it for hoses, I do not know how old the machine is, but I have had it for a long time.........Thanks
  • 376 Answers
Take it to an MTD dealer. MTD owns Ryobi now and they should be able to order you a new on. Not much has changed on them in the last 20 years.
Posted on Jul 29, 2009
Ryobi cultivator won't start. Just had the gas lines replaced
it could be a pin hole leak in the primer bulb.
Jun 21, 2010 | Ryobi Cultivator
Gas lines on ryobi cultivator 410aa fell off. replaced lines, tank, and the bulb. will not crank. need info on where line go
Exploded view:-
http://www.outdoordistributors.com/pdf/Ryobi/RYOBI-410.pdf
Did you replace the gasket (item 15 on the linked document) when replacing tank and lines, if you didn't and the old one has been torn it could be sucking in air, also the 4 carb mount screws need to be of equal tightness
Apr 23, 2010 | Ryobi Cultivator
Gas leaks
figure out where it's leaking from.. and fix it :/ or provide a little more detail on the issue
Aug 26, 2009 | Ryobi 15" Electric Factory Reconditioned...
Gas tank leaks on a 410r how do we take it off.
remove the screws holding the recoil cover off I would think and go here for parts and use your model numbers to find your unit.
www.ereplacementparts.com/ryobi-tiller-parts-c-7931_15702.html
Jul 01, 2009 | Ryobi Cultivator
Carburator floods as soon as you fill the gas tank . this is a ryobi 410r tiller.
you have a needle valve stuck open. i am not familiar with your model but if you can remove the float bowl and clean it out maybe replace the needle and seat and the float it should fix the problem good luck.
Apr 27, 2009 | Ryobi Cultivator
Gas problem
If it's a Ryobi it is 40:1. If you go to the store, you can buy small bottles that will give that mix if the entire bottle is put into 1 gallon of gas. Ryobi bottles are pretty easy to find. Home depot carries them.
Apr 26, 2009 | Ryobi Cultivator
Gas lines broken
does it have a pump bulb on the side of the carb? if so,it could have a pin hole in it a be sucking air.
Ryobi Cultivator Logo
146 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
