Question about Refrigerators
Hello, I own an Admiral Refrigerator (Admiral Ultima 2000) and the evaporator motor occassionally squeals. If I turn off the refrigerator for a while and turn it back on a few hours later, the fan will run for about a half hour before it starts to squeal again. I removed the back cover of the freezer compartment and you can see that the fan stops turning when it squeals. Can you please assist me in diagnosing what the problem is. Thanks
  • sam_pizzitel Jul 29, 2009
    Thank you. The odd thing is that several weeks ago the bottom part of the freezer compartment was freezing meat quite well (but if you left meat on the top portion it didn't seem to freeze as well) and the refrigerator wasn't working working well at all (i.e. refrigerator wasn't cold). Moreover the evaporator fan in the freezer compartment didn't seem to be working.
    Well a week or so ago the fan stating working and both the refrigerator and freezer seem to work fine when left on, except that the fan squeals and stops when hot. (Note, the fan does not come to a complete dead stop but stops for a few seconds here and starts again, stops for a few seconds, starts again etc). Does your diagnosis change in light of this?
    Thank you again
    T
  • 534 Answers
Motor bearings are more than likely going out. The fan spins until the bearings heat up. Suggest you replace motor take model and serial number to get part at the appliance parts house Good Luck
Dave
Posted on Jul 29, 2009
  • david berry Jul 30, 2009
    The squealing is where the diagnosis comes from. Usually when a motor starts to squeal thatr means lack of lubrication in eithr bearings or the windings are going bad. Whether or not the fan cycles intermittenly is not the reason for the diagnosis. The fan may very well be designed for the off/on cycle if the unit calls for this, however, the squealing is the key for me anyway. Good Luck
    Dave
I have maytag MTB2156GEQ. The freezer works fine, but not refrigerator. I also noticed that the evaporator fan on back of freezer did not work. I tried to remove the fan out, but I have difficult to remove the panel in front of the fan. Would you please kindly give me the instruction how to replace or check evaporator fan.
Posted on Mar 31, 2011
Admiral side by side refrigerator model GS 22X8D3 FRIDGE SECTION HAS A POOR COOLING PERFORMANCE, WHEREAS THE FREEZER SECTION WORKS FINE. MOTOR DOES NOT CYCLE ALWAYS ON.
Greetings,
in most self defrosting refrigerators..when the fresh food is warm, but freezer is ok...the first thing to look at is...a frosted or froze over evaporator in freezer. this is because, the cold air comes from freezer into ff section. it comes in and drops to floor of ff and is drawn back into freezer thru coil and if its frozen,,,no air can circulate...remove rear freezer panel and look for ice blockage
There are several other things. A fan motor not coming on will do this.. a stuck closed baffle in ff section can keep air out. check it and if froze up..there is a reason, and you need to find out why or it will happen again...check heater, defrost thermostat, check defrost control
Feb 03, 2011 | Admiral 26 cu. ft. Side-By-Side...
Side-by-side refrigerator - freezer is working just fine, but the refrigerator is not cooling.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 27, 2010 | GE GSL25JFPBS Side by Side Refrigerator
Moved refrig this morning and now it is not cooling... freezer works great
Hih, Check and see if something has stopped the condenser fan motor down by the compressor from turning. Sometimes this happens in a move.
Also make sure the controls didn't get turned to wrong settings. Make sure evaporator fan motor is working in freezer and that there is no frost building up on the rear panel.
Just some ideas to help you.
lease let me know if I can assist you further.
Thanks
Vic
May 30, 2009 | Admiral 26 cu. ft. Side-By-Side...
Water leaking from bottom of refrigerator
hello there,
well,if you can buy to replace the evaporator tray in order to solve the leak,you can buy this from refrigeration supply near your place,or have to fix or repair if can do so,have a glue gun and try to weld the crack in order to hold the water defrosted from evaporator and leak will not appear.you can buy glue gun from school supply or hardware near your location or in mall.have a nice day,don't forget to rate me.thank's alot
May 08, 2009 | Admiral 26 cu. ft. Side-By-Side...
LG LRFC25750 Refrigerator French Door
Freezer section evaporator fan motor bearing are going out. This would be indicted by a high pitched squealing noise. Have the fan motor replaced and it should solve your problem.
Jul 31, 2008 | LG LRFC25750 Refrigerator French Door
Admiral Side by Side Fridge is warm at top, cold at bottom
CHECK TO SEE IF THE EVAPORATOR FAN MOTOR IS RUNNING, ITS IN THE BACK OF THE FREEZER SIDE, MOTOR MAY BE BAD OR SOMETHING COULD BE BLOCKING IT...
Feb 07, 2008 | Admiral 26 cu. ft. Side-By-Side...
Side by side refrigerator
- Check your temperature setting.
- Check if no ice present in the evaporator, try the defrosting
- Check vents if air is present if no then check your blower if running or icing evaporator.
- Check your vents if not obstructed with stocks, or the unit is not overloaded with stocks.
- Check if compressor is running continues, if not then you need a qualified technician.
Feb 05, 2008 | Admiral 26 cu. ft. Side-By-Side...
Whirlpool Refrigerator squealing in the freezer section
On the refrigerator, most likely it's one of the fans, If its coming from the back of the refer it would be the condensor fan. If it's coming from inside the freezer, it would be the evaporator fan.
Jun 13, 2006 | Kenmore 24872 Top Load Washer
Refrigerators Logo
184 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
