Question about HP Pavilion dv4000 Notebook
When starting my DV4000 - the screen is dark other than a cursor in the left corner.
When I start my HP Pavillion DV4000 - the screen is dark and a flashing cursor appears in the top left corner.
A friend helped run a systems check and it resulted in a "#2-07 Fail" message. I couldn't get beyond that point and the device still doesn't work.
Any ideas ?
  • scrapper52 Jan 08, 2008
    My HP 4000 won't boot up. When I go to PhoenixBIOS Setup Utility and run the hard drive test I get a Test Status: #1- 07 Fail
    Are there any other tests I can run? I don't want to buy another hard drive if something else is wrong. Thanks
  • pabsdelhierr Dec 06, 2008
    same problem test fail #2-07 Fail and I have a HP dv2315nr.Please Help I lost my files.
  • 64 Answers
That error indicates a hard drive problem. You probably have to replace the hard drive.
Posted on Nov 24, 2007
The blinking curser indicates searching for next instruction.so more than likely you are missing instruction data (win32 for instance) try to install fresh os or repair existing one.....
have os disk in drive ,rebooot , install from cd.
Posted on Mar 24, 2008
    Problem Solver:
  • 7 Answers
This is a known problem with certain HPWhen starting my DV4000 - the screen is dark other - 1.gif and Compaq laptops. Check out the link below to see if you qualify for the free service enhancement program. The same thing happened to me and HP is sending me a postage paid box to mail my laptop to them and they are going to fix it and mail it back.
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=c01087277&dlc=en&lc=en&cc=us#c01087277_bios
Posted on Mar 23, 2008
    Problem Solver:
  • 12 Answers
Hi Friends,
Problem with HP Notebook Or Laptops? Follow the links.
For Software problems you can visit a link by just Click Here .
For Hardware problems with this Notebook you can Click Here
Posted on Jul 23, 2010
  • 520 Answers
Hard drive probably ok . reinstall xp(os)
cd in drive ,startup ,boot from disk,install windows,delete partition,create partition,format partition install windows
Posted on Mar 29, 2008
White cursor in upper left corner
Remove ALL media, DVD, CD, USB, etc. Unplug, remove battery, plug in, reboot, at boot start tapping F-10 to do a System Restore, use this procedure to restore to a date before this issue: http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&prodSeriesId=3832468&objectID=c01634414#A1 Post results.
Feb 02, 2013 | HP Mini 1000 Netbook
Hp pavilion dv4000 pc notebook cant install windows xp from usb there is a continues blink cursor on the top left corner
You need to make the USB first boot in BIOS, or use the boot menu selection. Both are noted during start up.
Then there is the issue of the USB install is it bootable? You need software like Novicorp to make an USB Installer. gl
Dec 12, 2012 | HP Pavilion dv4000 Notebook
My HP Pavillion DV6000 laptop starts up fine and after a few minutes the screen turns black. I can still see the desktop image in the background but barely. If I reboot the screen looks normal again but...
That means your backlight is going out. The fact that it's happening intermittently like that suggests that you have a faulty screen inverter (a small circuit behind the screen that converts DC power to AC, in order to light the florescent backlight).
I suggest replacing it. Here are some on abay for pretty cheap:
http://shop.ebay.com/i.html?_trkparms=65%253A12%257C66%253A2%257C39%253A1%257C72%253A2608&_nkw=Pavilion+dv4000+inverter&_ipg=&_sticky=1&_trksid=p3286.c0.m14&_sop=15&_sc=1
Mar 24, 2010 | HP Pavilion dv4000 Notebook
HP Pavillion DV4000 notebook display shading
It sounds very much like an inverter issue. The inverter sits under the lcd screen in the screen plastics. It is replaceable, but obviously there is a danger the screen may get damaged.
Nov 21, 2009 | HP Computers & Internet
Cannot get windows vista to load on my hp pavillion a 6400f
have you prepared a recovery cd or dvd, since vista software asks you to write a recovery cd first itself.if you have one, use that cd or dvd to reboot your system
May 27, 2009 | Computers & Internet
Hp dv4000 screen turned pink now black
If its not the backlight inverter or cable. It will be the LCD screen itself. It seems the shop you took it to isn't really up on laptop repair, as this is a common issue I see often. Get on Ebay and find a screen for your model and replace it. I asure you this will fix your problem.
May 19, 2009 | HP Pavilion dv4000 Notebook
Dv4000 hp pavilion dark screen
Have you replace the lcd inverter? if it works on external monitor, given the screen is new, then it leaves the inverter. Usually in the case of dark screen, it should be the first thing to check/replace.
Apr 07, 2009 | HP Pavilion dv4000 Notebook
My frozen HP blue screen
hi,
the problem may be due to error in software , try to reinstall the operating system
Dec 15, 2008 | HP Pavilion dv4000 Notebook
HP Pavilion dv4000 Notebook Logo
882 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
