Question about Radio Communications
My headset is beeping when I first push the headset button to make a call.
This can sometimes mean the battery is flat?
Posted on Jul 29, 2009
Blue Parrott Road Warrior B250XT, will not stay connected to my phone, The phone is a Motorolai335, it will connect and disconnect just when ever some times every 3 to 5 minutes and will reconnect within...
These steps are for a headset that is already paired to you cell phone and is stored in the phones trusted device / history list.
Look at the lights on the Multi-Function Button of the headset (the top / largest button of the three buttons); the light will be blinking Red if not connected and blue if connected (paired and connected are two different things). Push the volume up (middle button) 2 times, you should hear a beep each time you press it. If you hear the beeps go to the next paragraph. If you hear no beeps at all you will need to call 1-800-742-8588 for an RA # (Return Authorization Number) for warranty and non warranty repairs.
Look at the lights on the Multi-Function Button on the headset (the top / largest button of the three buttons); the light should be blinking Red if not connected and Blue if connected (paired and connected are two different things). Plug the headset into the power adaptor with power applied. Make sure your cell phone is on and the Bluetooth power of the PHONE is turned on. After 5 seconds unplug the headset from the charger and do not press any buttons. You should get a slow Red blinking light at first. Allow the headset to connect automatically to the cell phone, this may take up to 10 seconds. Once the connection has occurred the Blue light on the Multi-Function Button will blink once every second.
If after 10 seconds the light is still blinking Red once every 5 seconds you will need to press either the Multi-Function Button of the headset once to connect to the cell phone, or, your phone may be set up requiring you press a designated button or sequence in the phone to connect to the headset (meaning your cell phone is not set with or does not support automatic connect).
*NOTE* Most newer model cell phones have an automatic connect feature. Some phones have the categories of "Headset", and "Hands Free" in their Bluetooth menu. Some companies use the term Auto-Connect under the "Hands Free" category in their Bluetooth menu to indicate the set up for use with the Bluetooth system in an AUTOMOBILE.
Automatic connection under the "Headset" category and Auto-connect under the "Hands Free" category are not the same thing. When dealing with the headset you want to work in the "Headset" menu and make sure the Auto-connect of the "Hands Free" menu is turned off.
If this doesn't correct the issue I'd recommend calling VXi at 800-742-8588 for additional clear and reset instructions and the possability of warranty repair options.
Aug 29, 2011 | VXI Corporation Blueparrott B250-XT...
The Headset Lifter won't pick up the calls. Nothing happens when I push the ear button to lift it up. I thought maybe it wasn't fully charged when I tried it yesterday. At that point, I made...
If the CS70 headset has a charge and beeps when you press the call control button, you may just need to re-pair or re-subscribe the headset to the base unit. Here is a link for the pairing / subscription instructions:
Plantronics CS70 Pairing Instructions
If the headset is not charging, the internal battery may be worn out and the headset may need to be replaced (the battery is hard wired and is not replaceable). The replacement headset is model 72910-01. Below is a link where you can purchase the replacement headset.
Plantronics CS70 Replacement Headset
Good luck from Headsets Direct!
Jun 24, 2011 | Plantronics CS70 Wireless Headset
Have new headset, why is the base unit keep beeping at me
Here is an explanation of the beeps you are hearing:
• One beep every 10 seconds is caused by a low battery
warning. Recharge battery by returning it to the base charge
cradle for one to three hours until charge light stays lit or
quits blinking.
• Two beeps is an out of range warning. Move closer to the base.
• Three rapid beeps every 30 seconds indicates your mute is
on. Press the mute button once to turn mute off.
• When an optional lifter is connected, three repetitive beeps
indicate a call is coming into the headset. Press the call
control button on the headset to answer the call.
Plantronics CS70 User's Guide
May 19, 2011 | Plantronics CS70 Wireless Headset
I have a Motorola Blue Tooth ear piece that I bought 4 years ago and never used. I have charged it, but I don't know how to link it to my new phone, which is a Verizon LG Phone. The only buttons on the...
Usually you get the headset into pairing mode by pressing and holding the answer button for about 4 seconds, or until the headset beeps. Once you hear the beep you can attempt to pair to it with your phone. It may ask for a passcode which is sometimes '0000' or '1234'. If you could give me the model number of the headset I may be able to find a user guide for you.
Hope this helps
Ray
May 15, 2011 | Motorola Cell Phones
I've been using my Motorola H700 with my LG phone for over 1 year with no problems. Now it will no longer connect, I've charged it till the light is bright green but my phone is not able to connect to it....
You should remove this item from the phone and reconnect / pair it again. In the manual for the headset you have information on how to reconnect the headset to the phone and the phone have to be in "discover" mode for bluetooth
Jan 02, 2011 | Motorola Mobility H700 Wireless Headset
Computer headset problems
It sounds like something in the control panel on your computer, Go into the sound settings and pick your device.
Below is the link for Explorer 300 Series User's Guide.
Plantronics Explorer 300 Series User's Guide
Jan 17, 2009 | Plantronics Explorer 330 Headset
Where can i get an online Manual for a Voice Star VS700 Bluetooth
Hold the power button down, once it beeps, keep holding down the power button but push in the volume up button, once it beeps let go of the volume up button and while still holding the power button push in the volume down button. the pass code is "0000".
Dec 11, 2008 | Radio Communications
H700 headset can't hear me!
Push both volume buttons at once to turn Mute off. You should hear two beeps, ascending in pitch to indicate mute is off. If they go down in pitch mute is being turned on.
May 09, 2007 | Motorola Mobility H700 Wireless Headset
Echo when using the headset
If you are having echo problems while not on a call (you are wearing the headset, it is active, but you are not currently on the phone with anyone), there are 3 ways to counteract this: -When you are done with a call, you can click your Multifunction button on your headset (middle one inbetween the volume controls). -Move the microphone away from your mouth when you are not on a call. -A more permanent solution: decrease the sensitivity of your microphone. To do this, click and hold the increase and decrease volume buttons on your headset ( + & - ) for 3 seconds. Let the buttons up after 3 seconds and push the lower volume button 2 or 3 times. Wait 6 more seconds and it will beep at you. After you have done this, make a call to someone in the office to be sure the sensitivity has not been lowered so much that others can?t hear you.
Jan 08, 2007 | GN Netcom GN 9120 Professional Headset
Radio Communications Logo
400 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
